Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > The Lounge (Off Topic) > Computer/Tech
Old 07-30-2008, 12:28 PM   #1
playa6tnine's Avatar
Windows Activation Code
I have a legit copy of Windows XP from my old computer. I'm trying to install it on my new computer, but its asking me for and activation code. Product key works fine and everything, I just need the damn Activation Key. I called Windows support and they said they cannot give it to me, I would have to buy a new copy of windows.
Does anyone know how i can obtain this activation key?
playa6tnine is offline   Reply With Quote
Old 07-30-2008, 12:38 PM   #2
ny300z's Avatar
no, heres what u do
call MS tell them exactly what happened. They will ask you to read the code the activation thing gives you. They will then give you a good code which will activate it.
i have done this a million times
__________________
NFL CHAMPS .............Haters
ny300z is offline   Reply With Quote
Old 07-30-2008, 12:54 PM   #3
IllumEstVeritas's Avatar
Quote:
Originally Posted by ny300z
no, heres what u do
+1 - let them know that the old computer is not up and running and that usually does the trick. I had some crazy problems with an upgrade I did and probably reinstalled 4 times in a month. Big red flag, but they helped me the last two times I tried.
GL.
IllumEstVeritas is offline   Reply With Quote
Old 07-30-2008, 01:00 PM   #4
Highway Riding's Avatar
Now it all depends on what u call a legit copy. was it a dell/hp restore disk with a full version of XP or is it a copy that was purchased in the store aside from the pc? If it's a restore disk WPA kill might be the only thing that'll work but will not allow any updates..
__________________
The Sun Rises In The EAST!
Highway Riding is offline   Reply With Quote
Old 07-30-2008, 04:03 PM   #5
jesseenglish's Avatar
If you're trying to move an OEM license key to another computer, it is not a legit copy. OEM licenses are only for use on the original computer it was installed on. You can't legally move it to another computer.
__________________
History is not going to be kind to liberals. With their mindless programs, they've managed to do to Black Americans what slavery, Reconstruction, and rank racism found impossible: destroy their family and work ethic. - Walter Williams
jesseenglish is offline   Reply With Quote
Old 07-30-2008, 05:11 PM   #6
jdfong's Avatar
did you already format over your old partition? if not try this:
1. Double-click My Computer
2. Double-click on the "C" drive
3. Go to the C:\Windows\System32 folder (you may have to click on the link that says "Show The contents of this folder")
4. Find the files "wpa.dbl" and "wpa.bak" and copy them to a safe location. You can copy them on a floppy drive or burn it onto a CD or DVD.
5. After you have reinstalled Windows XP on your reformatted hard drive, click "No" when asked if you want to go ahead and go through the activation process
6. Reboot your computer into SafeMode (you can either press F8 as Windows is booting up to see the Windows Advanced Options menu and select SAFEBOOT_OPTION=Minimal or follow the instructions in Starting Windows XP in SafeMode
7. Double-click My Computer
8. Double-click on the "C" drive
9. Go to the C:\Windows\System32 folder (you may have to click on the link that says "Show The contents of this folder")
10. Find the file "wpa.dbl" and "wpa.bak" (if it exists) and rename them to "wpadbl.new" and "wpabak.new"
11. Copy your original "wpa.dbl" and "wpa.bak" files from your floppy disk, CD or DVD into the C:\Windows\System32 folder
12. Restart your system (if you followed the directions in Starting Windows XP in SafeMode you may need to go back into MSCONFIG to turn off booting into SafeMode)
http://netsecurity.about.com/od/wind...twinxp0829.htm
jdfong is offline   Reply With Quote
Old 07-30-2008, 05:59 PM   #7
Low J.'s Avatar
I ran into this too.....I had a legit copy of XP that I bought for an old PC that I had since parted out and sh!tcanned. I found out that Microsoft changed their policies and activation processes recently and they won't let you activate a copy of windows that had ever been activated before on another CPU. I just gave up on it finally because there was no way I was going to pay for it again so I just removed windows from VMware and don't miss it at all.
__________________
'08 VW R32 | '08 Audi A4 2.0T Quattro S-Line
Low J. is offline   Reply With Quote
Old 07-30-2008, 06:40 PM   #8
OEM licenses have always been tied to the computer they were first installed on. Retail licenses can be moved to as many computers as you please as long as it's only installed on one computer at a time.
__________________
Old 07-30-2008, 08:04 PM   #9
I've called microsoft and said that I upgraded the RAM and changed the hard drive. If you have an activated computer and you change around some components it will require re-activation by calling microsoft. If you want to switch windows to another computer, you can call them and tell them that you just upgraded the ram and now it wants you to activate. It's always worked for me.
cbeneke is offline   Reply With Quote
Old 07-30-2008, 10:10 PM   #10
350ZTheStandard's Avatar
Just call Microsoft already, it is what a smart person would do. Remember to only give specific info, don't give more info than they ask for, just in case.
__________________
ZZZ's a lifestyle
Team Anti-DNF down with furious clickety clackers
350ZTheStandard is online now   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
