Thread Tools |
#1 |
DILLIGAF
New to building / Will this work?
![]() That's what I have so far, I'm just not sure if it will all work together or if there are better options. I don't really do anything intensive on my comp, just iTunes, Auto Cad, and I play the Sims occasionally. Will this setup work? Are there better motherboard/processor combos for what I need? Also I'm clueless about memory...
__________________
AAM / AEM / APS / ARC / CUSCO / CWEST / DEFI / GREDDY / GT SPEC / HKS / JIC / KENWOOD / KOYO / NISMO / NITTO / PROJECT KICS / PROJECT MU / RAYS / SAMCO / STOPTECH / TAKATA / VARIS / VERTEX / WORKS BELL / ZEX |
#2 |
the motherboard will fit into the case. I'm sure the motherboard has a pci express slot. Check is the motherboard cpu socket is compatible with the cpu
#3 |
i would go with a ATi GPU if your going the AMD route...
#4 |
DILLIGAF
Really? Well I guess AMD does make ATi huh.
__________________
#5 | |
Lead farmer
It will work, yes.
Do you really need or want the Nvidia chipset? If you don't need it (or don't really want SLI), I'd opt for an Intel or even AMD chipset. More reliable and runs cooler. As for the case, know that it is a full tower. When you receive it, if you're not familiar with computers, the case will seem huge to you. The most popular size is midtower, and that fits plenty of hardware. The AMD/ATI connection is not necessary.
__________________
Ben
Quote:
#6 | |
DILLIGAF
Quote:
What would be some good ideas for motherboards? ASUS is really good right? I do know it's a full tower, do you think that might be too big? I like the Antec 900 too, and it's a mid.
__________________
#7 | |
Lead farmer
I have the Antec 900 and it is nice. Plenty of room, sturdy, and looks sweet. Not to mention it has amazing cooling. Just buy 2 more fans with the case to fill all the spare fan spots.
![]() As for the motherboard, I'm assuming you'd like to stay with AMD to keep costs down?
__________________
Ben
Quote:
#8 |
DILLIGAF
That's pretty sick.
Eh not really the cost I guess I just though AMD Phenoms were good? Are Intels much more expensive? Are they better?
__________________
#9 | |
Lead farmer
An Intel setup would probably run you about $50-100 more.
IMO, Intel is a step ahead of AMD. I did a bunch of research prior to building my computer, and I concluded that AMD is a little behind.
__________________
Ben
Quote:
#10 | |
Kristi's Twin
Quote:
ATI on the other hand, not so much behind NVidia. The new 48 series cards are very slick and 2x 4850's will give you significantly more performance than a GTX 280 at a cheaper price. Not to mention the 4850's will clock to 700mhz easily. The gotcha is your best performance will be on an AMD chipset motherboard - which means running AMD.
__________________
I stole his grape drank
#11 |
DILLIGAF
Thanks for the help guys.
If I would go with an Intel setup, which processor/board would you guys recommend?
__________________
#12 |
Hey bud...let me know if you need any help.
#13 |
Ok... NO QUESTION you need to get an ATI 4850 for around $150AMIR
E7200 or E8400,E8500 depending on what you're looking to spend. I am partial to DFI motherboards. Mine is SOLID Antec 900 is a GREAT case. |
#14 |
DILLIGAF
Alright here is my new part list. Does this seem better?
__________________
#15 |
looks good but does that case come with a power supply? most likely not, get at least a 600 watt power supply (i usually go for the highest rated best deal\brand) . $165 seems a lot for a case to me i got my cooler master centurion for like $80 shipped off newegg.
#16 |
DILLIGAF
It doesn't but I was just going to use the one I have now, a Enermax 650.
Is your case a full or mid?
__________________
#17 | |
Lead farmer
THe build looks MUCH better.
Personally, as it stands right now, I'd go for an Intel X48 chipset and an ATI HD 4870 GPU (Runs about $250). But since you have the X48 chipset, you'll be able to pick up another HD 4870 in the future for a Crossfire setup to gain a big performance gain. Like David stated, ATI isn't far behind Nvidia at all. Their newer cards give a LOT more performance for your dollar at the moment.
__________________
Ben
Quote:
| Thread Tools | |
