You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
so today was the first time i took the z to the track...muggy 86 degrees so basically everyone had crappy times...i could not get any better than a 14.413 at 98.48 mph and my 60 foot could have been better than a 2.332....all i have is a popcharger....should i be doing a lot better or am i near what i should be doing?
For your first time, the 14.413 @ 98.48 with a 60' of 2.332 for your best isn't unacceptable. You have much room for improvement. Keep practicing and you'll eventually get a much lower time even with worse weather conditions. Your 60' is most likely the main problem. Post up your time slip for a full evaluation.
Clearly your 60-foot time is hurting your ET. Sometimes with 80 percent plus humidity and poor staging pad preparation, the best that you can do is 2.3 seconds. A couple of suggestions:
a. Change lanes.
b. Look at the tires marks on the staging pad. Stage to the left or right of those marks.
c. Drop tire pressure to 30 psi
a. Change lanes.
Be safe and have fun.
if you are telling him to get out of the groove, i am going to have to disagree
Debate is good.
I am suggesting changing something: either the lane or the groove. If I follow a car with 10.5 racing slicks, my tires are in-the-groove. If I am having a difficult time with 60-foot time, then I experiment to the right or left.
the thing he needs to change is the way he launches the car. even with a poorly prepped track, the worst 60's should be in the 2.0s, it helps to learn from someone of course, i was stuck in the 2.3s for a year.
lining up out of the groove is where fluids and dirt tend to build up down the track
