DRAG RACE FORUM: Listen up..
on
I didn't know there were any fast tracks in TX. I thought I was stuck with the crappy conditions, slow track, so-so prep, etc. I guess I'll have to make a 5+ hr trip to HRP if I want to set any ridiculous records.
on
Originally Posted by Dave B
Okay. When I raced my 96 Maxima at MO-KAN Dragway (Joplin, MO) on three different occasions, the car was consistently 0.4 seconds and 3mph slower than KCIR. When my friend from Joplin, MO ran his car at KCIR, it was 0.3 seconds and 3mph faster. People that run at KCIR and MO-KAN Dragway notice the same exact thing.
A few years back prior to KCIR getting resurfaced, the left lane consistently showed 3mph slower 1/4 trap speeds, but the 1/8 mile ET/MPH and 1/4 ET were dead on between the two lanes. Once the track was resurfaced, the trap boxes read identical.
Retired Admin
The night I ran my 13.212@104.75, I could've lowered it to 13.1 with a low 1.8 60'. I regret for following the others out of the track to leave early. I did well considering it was my 2nd or 3rd run ever on slicks.
As much as I want to run 12s with my current state (same as the 13.212), I also don't want to drive 5+ hours just to race/set a new PB. I'm no drag racer (just a hobby for me), so that would be a waste of time, efforts, gas, etc for me.
Given that the conditions yield a great DA at my regular track, I should be able to dip into the 12s though. Too bad that'll never happen.
Originally Posted by TheCajunStyle
Interesting! I've seen instances when trap speed was higher or lower by a substantial amount--but it was random. I think the timing system at my local track reported 126mph (I wish) on one of my runs...interesting because I had just shifted into 5th gear before I crossed the finish (~112mph). So how does a timing system, such as Portatree measure trap speed?
Trap speed is standardised at all NHRA sanctioned tracks. Its the average speed over the last 66 feet. You can see the buckets for the trap timer and ET above. The distance between the two is 66 feet.
Cranky FI Owner
Most people that leisurly drag race dont know what the hell DA is or how to get it. $hit I didnt even start calculating it till the last time I ran my car. To ask most of these guys to add that in their posts is silly. Makes you guys with bad tracks sound like haters "well he runs good times cuz his DA is XXX", "his track is fast-blah blah"-well even at our fast tracks people run 14.5's in mod'd Z's so what!?! Let the times speak for themselves, obviously some poor guy at 5000ft altitude wont be running crazy fast times. Track times are like dyno numbers, all different. Any of the top 5 drag racers on the forums could likely jump in each others cars and run within .1 of each other boo hoo...
Professional
on
Great rant Chris. The drag strip is not the place to be trying out bad advice. You can get hurt and should always play it safe. Experience is the best tool to use when going after anything and in this case you just need to spend time PRATICING.
PS: Chris cool temps when are we going back to the track?
Retired Admin
on
Retired Admin
I didn't specifically state that only DA was acceptable. I also mentioned that conditions are also good, as that'll help others take into consideration that they may not be doing as bad as some people make it out to be. If they really wanted their times analyzed and wanted in-depth responses, the least they could do is look up their local climate conditions. Plus, it was merely a suggestion, not a command.
BTW, times can't really speak for themselves, if the conditions sucked *** (i.e., 4000 DA). Thus, the addition of the climate factors helps out when analyzing time slips.
on
on
Originally Posted by SergEK
But without DA factored the top 5 will always be from sea level tracks in good air with negative DA numbers....especially the naturally aspirated lists
Retired Admin
Originally Posted by Peak350
I agree and disagree. I've gained about .25 from conditions changing to be more in my favor. I gained the other .25 from learning how to get not only my 60' down, but my 330' down. I stopped watching my 60' so closely and figured out what the car wanted on the whole 1-2 range and my times improved a lot. Most people struggle on launch and once they get down not spinning they still have more bog than they expect. Even in terrible conditions I doubt I'd be running 14's ALL night, although I don't expect I'd better a 13.7/1.8, I still think I could get there because I've run in 2800 DA's and gotten a 13.6, in 400-500 DA's I got a 13.3, and I never pulled the DA for my 13.2, but I imagine it was ~100.
What I meant was that people like the ones in MD won't have such bad times no matter what the DA, but people in AZ or CO are different. Their times often do not get recognized or even stand out when compared to some of the low 13 sec runs. For those folks, I was just saying that the addition of conditions or even DA, if possible, may help them get more recognition that they deserve for a 14 sec run. Even the most experienced racers sometimes forget about the conditions when analyzing time slips. Again, it was merely a suggestion.
on
I'm not sure what you're agreeing and disagreeing about.
on
DA has a huge influence over the performane of the car. The first time I ran my G35, the DA was in the 1,700' range which isn't bad for Kansas City which is situated at about 1,100'. The G ran a best of a 14.49@97.6mph with a mid 2.1 60'. I ran the car again in the fall in near sea level DA and the car went 14.32@98.5mph with a mid 2.1 60'. Same track, no changes to the car.
Now if I were to have run in the negative DA (-1,000 to -2,000) like many of the coastal northeastern tracks experience in the fall and spring, my stock G35 could have gone 14.1s@100mph with no changes in driving or 60'. A 14.1@100mph in a stock 03 G35 5AT would be freakishly fast, but it would be entirely possible when the power content of the air is about 110%.
Also, negative DA is the reason for all these "freak" cars. No one has a freak car these days. It's the conditions and track. The build tolerances are just way too tight these days. In the 60's and 70's it was true, but not with later model cars.
#38
Cranky FI Owner
With my TN I ran 11.98 in 45 degree temps, and then 11.99 back to back in dead summer with 100 degree temps w/humid conditions I ran right after they dried the track after a rain storm! All of my friends that can drive always run within .1-.2 of their best regardless of the weather/humidity/etc...but you guys wouldnt beleive me. Tons of local Z owners have seen me though. I think weather is an overused excuse for most people. They dont know how to launch in different conditions, cold, hot, humid, and the runs go to $hit....
#39
Retired Admin
I don't think its necessary because (and I say this with a caveat) - I almost always look at a slip. Note the trap speed, which has little to do with the driver, note the 1/8th mile trap speed, which has to do with whether the car bogged the launch or not, and then look at the 60' to see if they spun or not. If the 60' sucks then its not a fault of DA, possibly track prep, but 99% of the time its honestly just an issue with the guy (or gal) behind the wheel. I've encountered bad track prep and still mustered good 60' times by trying a difference launch. You CAN'T work around bad air, but a common trend I've seen in the NA times is that slow times also include either a slower than expected 1/8th mile trap speed, or a higher than "good" 60' time. Either of those makes me less sympathetic based on conditions, and makes me say "ok thats a mid 13's run at a perfect track." I don't have to see conditions to understand where the car should be - the 1/4 trap speed tells you all about the conditions and how the car is running.
#40
on
My friend's EVO and STI are simply not effected by poor DAs. They run mid 12s whether it's 90 out or 50 just like you. However, my friends with NA cars see wild swings between running poor and good DA.
I'm really surprised you don't know this stuff seeing that you're an avid drag racer.
