Thread Tools |
#1 |
First time and I suck:(
Hey all,
Car is a 2003 Touring 350Z MT, bonestock Mine is the one on the right
#2 |
u did 15 secs ? wow dont worry man juss practice
__________________
pffft: if you build it they will come |
#3 |
Search is your friend.
anywho, short answers: 1. Only briefly, not to heat them up, but to remove debris. 2. Some leave the PSI alone, some swear by dropping the tire pressure for more traction. I myself leave it alone, the tire is made to preform at the recommended psi, imo. Your reaction time doesn't affect your 1/4 mile times, You need to work on shifting quicker and on your launch, even with that 60 ft you should be in the HIGH 14's.
__________________
03 Super Black 6MT _GO GATORS! |
#4 |
Actually, my first stage was 16.9, then 15.7 and a 15.3. It's gradually going down. I have read a couple of tips here and there in the drag section of the forum. What RPM do you guys shift from 1st 2nd 3rd? Do you maximize it and shift at 6700RPM? Can you explain how to shift quicker? I'm new at this so go easy one me
#5 |
Are you pressing on the gas peddle? The one on the far right?
__________________
350Z 2004 Enthusiast: K&N Typhoon Air Intake - Motordyne Plenum Spacer - Alphawerks Stainless Steel Headers - Helix SS Test Pipes - Injen Super SES Cat-Back Exhaust System - 6 Pad Puck Ceramic Clutch and Forged Steel Flywheel by Competition Clutch - WedsSport SA-70 |
#6 |
Your trap speed seems low. Were you spinning down the track, on the throttle all the way, waiting for the revs to match between shifts?
Traction control off? Should have at LEAST another 5-8 mph on that trap, and another 4-6 on your 1/8th mile speed.
__________________
*stock* 2007 SMB 6-speed Enthusiast - 13.239 @ 105.67 and going for more |
#7 |
dont worry man ive been to the track in boise, d.a. usually = 3500+ (teh suck for my stocker @ the time w/ bigger wheels and tires), about 4 times (15 or so passes) and my best is 14.7+ @ 94.xx.
make sure vdc is off, start off a little slow (2500 rpm), and rather than trying to "power shift" just shift cleanly @ ~6500 or so. once you get the hang of it start picking up other things everybody sux @ the beginning you just need seat time
__________________
Titek AutoTeknic Hoosier K&N Volk BFG Berk RAYS MD Varis http://www.cardomain.com/ride/2582203/1 SRRSCCA #24 B.oner in S.weat P.ants |
#8 | |
Quote:
#9 | |
Quote:
#10 | |
Quote:
#11 |
Deft Azn
god sucked my first time too but i managed to get a couple of mid 14's in.
launch at 2500rpm, easily letting off the clutch, just dont drop it. dont forget to have the clutch semi loaded to reduce drive train shock. no power shifting for now, just shift at 6700rpm for a 07. try not to be nervous and have fun.
__________________
Greddy, HKS, Volk, Haltech, Motordyne....
#12 |
^ " the nervous" is hard to get over too, i'm still not over it but for me its more adrenaline than nervousness
__________________
#13 |
Brand Whore
everyone one starts somewhere. At least you got out there and tried. Like most said, more practice. When i dropped the PSI in my tires, i did so much better. I just feather my clutch off the line and shift really fast. You will do better. I do get nervous because everyone is watching you.
__________________
#14 |
I plan on going out again to get better at it but a quick question though, has anyone ever broke/snap a drive shaft on a 350z before? If so, were you using slicks?
#15 |
'03 BYR
You will most likely brake an axel first.
__________________
2003 Brickyard Red Touring 6 Speed 13.201@103.52mph 265HP/249TQ sae corrected Ported Lower Plenum, Kinetix V+ Plenum, JWT Pop Charger, "Z-Xtreme" grounding kit, UR Pulley, ACT Clutch & Flywheel, Fast Intentions "Intimidator" 2.5" dual exhaust, Test Pipes, OSIRIS tuned Stillen "Series II" Front Bumper, Volk Racing SF Challenges
#16 | |
Quote:
Don't drop your tire pressures - its a placebo effect on street tires. Launch from a low RPM (say 1,500-2,000) slipping the clutch until you get the feel for how the car responds at launch and when to launch, etc. Then up the RPM's to 3,000+, find what works for the car and conditions. I typically launch at over 5,000 (if the track will hold it). If you get wheelspin lift at least partially until you regain traction and then smoothly reapply throttle. You obviously aren't putting power down (from your timeslips) and controlling wheelspin will help you immensely. A smooth (even slow) launch will put you ~ a 2.2-2.3 60' and set up for a low mid 14. Once you get used to that you can slowly chop away your 60' and watch your time come down. Good luck and have fun.
__________________
#17 |
60ft is high, just need to work on launches it looks like, probably spinning the whole time
__________________
日本で買った車を運転するのが大好き。 |
#18 | |
Quote:
__________________
#19 | |
Quote:
__________________
350Z 2004 Enthusiast: K&N Typhoon Air Intake - Motordyne Plenum Spacer - Alphawerks Stainless Steel Headers - Helix SS Test Pipes - Injen Super SES Cat-Back Exhaust System - 6 Pad Puck Ceramic Clutch and Forged Steel Flywheel by Competition Clutch - WedsSport SA-70 Last edited by davidv; 03-31-2008 at 06:45 AM. |
#20 |
Ususally I'd say somthing like everybodies first time is their worst but that is pretty bad man. Practice makes perfect.
__________________
04 Touring 13.849@101mph AUTO Stock l 13.517@102.30 Modded |
| Thread Tools | |
