Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Drag
Old 04-03-2008, 03:46 PM   #1
ricochet's Avatar
Analyze and advise time slip
I've figuratively hit a wall in dragging my 2003 Touring Z and could really use some actionable advise for improving my times... this is an ancient time slip:
Capitol Raceway
Temp 77F (I think their thermometer/barometer was broken)
Rel Hum 0
Abs Baro 0
60'...2.197
330...6.130
1/8...9.301
MPH...78.01
1000...11.965
1/4...14.217
MPH...100.77
-tire pressure: 35psi F, 28psi R
-1/4 tank gas, 93 Octane, spare-in trunk
-2500-2800RPM launch
-7100 RPM shift
-Getting wheelspin on shift 1st-2nd, 2nd-3rd... I've heard it robs upto .1s at the end each time I spin
-mods:JWT popcharger, 18" NISMO wheels/BFG KDWs, NISMO exhaust, Stillen headers
-Help!
ricochet is offline   Reply With Quote
Old 04-03-2008, 03:54 PM   #2
350Z400rwhp's Avatar
A 100mph trap speed with a 14.2 is very good. 100mph usually = a 14.0 run. I know in my 03' stock I was getting 2.0 60ft times even with wheel hop. I bet if you could get a better launch you would see a 13.9 @ 101. Might just depend on how well they are prepping the track. I was able to launch mine around 4000. What RPM are you shifting in each gear?
__________________
03' Touring 6MT / Black / Black / Vortech 3.12 Pulley / Powerlab 3/8" Spacer / 6 Wire Earthing Ground Kit / JWT Clutch / SS Clutch Line / Utec / DeatschWerks 600cc's / Walboro 255 / Megan Resonated Downpipes / AAM Uego / Autometer Boost / JWT Oil Pan Spacer / Snow Performance Stage 2 Meth Injection / Tuned by FORGED! 330whp on the Heartbreaker.
350Z400rwhp is offline   Reply With Quote
Old 04-03-2008, 05:40 PM   #3
Chasecbc's Avatar
hmm i would think that the kdws would hook pretty good
you had more mph that me but i had a better time. I ran a 14.06 at 99.6
Chasecbc is offline   Reply With Quote
Old 04-03-2008, 05:46 PM   #4
SHIFT_Blah
Alberto's Avatar
I assume its a Revup?
60ft is "ok"
1/8 is horrible, about .5 off my stock pace with the same 60ft. Answer?
Your shifting on 1-2 and 2-3 gears is very slow, and it needs work. Improve that and you can go 13.8's with 2.1 60ft's stock....
__________________
11.1@126mph old set-up low boost
**Wanna see my Z go 170+mph?** Click Me
*More Videos*
Fixed & Tuned by PFSUPERCARS
Alberto is offline   Reply With Quote
Old 04-03-2008, 07:12 PM   #5
its typical to get a higher MPH with a slower speed when all things are the same. if you hook really well and therefore run a faster time, you will likely have a lower MPH. that mph with that ET makes me wonder about the rest of the coniditions. what elevation are you at? since the baro and humidity readings arent there, was it cloudy? is the air humid or dry? just a couple things, those runs look to me like runs in hot/humid air or high elevation. do you warm the tires at all? thats something thats always worked for me on streets, but it seems to be a preference thing
Hoooper is online now   Reply With Quote
Old 04-03-2008, 08:04 PM   #6
The 350Z is running strong picking up 22.7 MPH in the second 660 feet. 9.3 second 1/8 mile time shows mediocre acceleration during the first 660 feet. If you begin with a 2.19 second 60 foot time, its difficult to break 14.0 seconds. And yes 2.0 seconds is possible with street tires.
Here is an example above with a 0.08 second difference in 60 foot time. 0.08 seconds will make a big difference in ET.
__________________
350Z 2004 Enthusiast: K&N Typhoon Air Intake - Motordyne Plenum Spacer - Alphawerks Stainless Steel Headers - Helix SS Test Pipes - Injen Super SES Cat-Back Exhaust System - 6 Pad Puck Ceramic Clutch and Forged Steel Flywheel by Competition Clutch - WedsSport SA-70
davidv is offline   Reply With Quote
Old 04-03-2008, 08:16 PM   #7
Here is a better example above. 60 foot time is the same. The difference is the first to second gear shift.
__________________
Old 04-04-2008, 03:26 AM   #8
ricochet's Avatar
Quote:
60ft is "ok"
Alberto, could my slow shifting be causing the wheelslip I get shifting 1-2 and 2-3, and causing my poor ET? Also is there a good post on shifting technique that I can practice? (too lazy to search...)
Old 04-04-2008, 07:21 AM   #9
SHIFT_Blah
Alberto's Avatar
If your breaking traction on 1-2 and 2-3 with bolt-ons tires are an issue, or your not going around the water box and making your run worse by trailing water to the line. Practice makes perfect, the more seat time you get the better you will get.
What year is your car? 7100rpm's is only available in a Revup or a reflashed car. I dont think you have an HR....
__________________
*More Videos*
Old 04-04-2008, 07:43 AM   #10
ricochet's Avatar
You're spot on on both counts! I don't think there's room to drive around the water box at capitol raceway... and I did get a reflash on my '03 to bump up the rev-limiter to 7100(?)... That said should I do a longer burn-out on my street tires to get more of the water off (vs just cleaning off the debris?) Tho' I'm starting to think I'll get better times if I knew how to shift...better
Old 04-04-2008, 08:47 AM   #11
What mods do you have?
__________________
Old 04-04-2008, 09:33 AM   #12
I never have room to go around....first gear burnout for 20 feet or so (5 seconds maybe?) has always dried my tires for me.
__________________
*stock* 2007 SMB 6-speed Enthusiast - 13.239 @ 105.67 and going for more
Peak350 is offline   Reply With Quote
Old 04-04-2008, 10:15 AM   #13
warming street tires for a couple seconds has always worked for me too, worth a try
Old 04-04-2008, 04:58 PM   #14
ricochet's Avatar
Quote:
just bolt-ons...JWT popcharger, nismo exhaust, stillen headers, and reflash for rev-limit bump to 7100RPM
Old 04-04-2008, 06:02 PM   #15
Quote:
Careful saying warming, most people don't understand the difference between a thorough tire scrub and warming tires.
They take a slicks style burnout to be warming (which it is) and 5 revolutions of the tires to be cleaning.
I've never tried REALLY short burnouts because if you watch street tires during a burnout (good ones only) they burn a dark color for a second then get lighter. When they burn lighter they are clean...thats about the point I burn to.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
