Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Drag
Old 04-18-2008, 09:21 PM   #1
Spinning problem plz help.
I went to the drag strip today and i cant go under 14.4 @ 104.5mph with my 04 6spd 350z.
I was spinning only 1 tires everytime. first,second en third speed with a tire spining.
I got 285/40/18 and it still not have traction.
Another guy with a oem 350z 03 oem wheels did 14.2 .
Can someone explain this to me and is the best thing to do is to buy a real lsd?
bovi is offline   Reply With Quote
Old 04-18-2008, 10:22 PM   #2
104.5mph is exceptional. Scan and post time slip. Thanks.
__________________
350Z 2004 Enthusiast: K&N Typhoon Air Intake - Motordyne Plenum Spacer - Alphawerks Stainless Steel Headers - Helix SS Test Pipes - Injen Super SES Cat-Back Exhaust System - 6 Pad Puck Ceramic Clutch and Forged Steel Flywheel by Competition Clutch - WedsSport SA-70
davidv is offline   Reply With Quote
Old 04-19-2008, 12:58 AM   #3
"BRICK" OTSZ
rx7/350z's Avatar
Quote:
Mph is always a little higher when your spinning off the line!
__________________
Brickyard 350z-Amuse/Nismo kit-3.12 Vortech-14" 6-pot stoptech-Power Enterprise oil pan-Craftsquare mirrors-Arc panel/oil cap-Cusco sways/brace-z1 endlinks-Tein coils-Hks exhaust-Kinetix plenum/cats-seibon hood-Privat wheels-Spc stuff-Defi stuff-Zeetoys-Kenwood-Jl
rx7/350z is offline   Reply With Quote
Old 04-19-2008, 01:34 AM   #4
so many uses
Motormouth's Avatar
at least you spelled spinning right, unlike the last thirty guys who posted this thread.
__________________
It is my firm belief that it is a mistake to hold firm beliefs
Motormouth is offline   Reply With Quote
Old 04-19-2008, 05:11 AM   #5
CSF
CSF's Avatar
Quote:
almost spelled it right all the time
Quote:
a better LSD wouldn't hurt
CSF is offline   Reply With Quote
Old 04-19-2008, 10:55 AM   #6
Don't shift so hard...its simple, if you get spin you just don't drop the clutch so hard off the shift until you don't get spin. You are accelerating much more slowly if you're spinning - so avoid it.
__________________
*stock* 2007 SMB 6-speed Enthusiast - 13.239 @ 105.67 and going for more
Peak350 is offline   Reply With Quote
Old 04-20-2008, 10:57 AM   #7
Im not stupid, I did every kind of start and its all the same. I start in second speed and i did 14.4 also. Anyway, probably the cold track and the cement dont help and the crappy vlsd too lolll... Anyway, got a supercharger on the way now so maybe it will help a bit.
Old 04-20-2008, 11:02 AM   #8
Thats obviously not true - you might not be stupid, but you CAN get better results. If the track can't hold 100% of the power the car can make you need to not give 100% throttle. You will see faster times from it. I've had to avoid going full throttle coming off of shifts and out of the hole before because the track was slick. I can still run good times....
__________________
Old 04-20-2008, 11:18 AM   #9
so many uses
Motormouth's Avatar
oh lord, FAIL.
I only read the title. lol. good catch.
__________________
Old 04-20-2008, 02:29 PM   #10
Peak350, all my runs are between 14.4 and 14.6, depending of the start ,rpm everything. Its about 5 degrees outta here and the first 100 ft of the track is in Cement so it might be a problem with my BF goodrich G-force, not enough hot maybe. Well, i got a 6 spd Z and i wasnt having any traction at all. 1-2-3 gear
Old 04-20-2008, 03:55 PM   #11
I've run my old car in 35 degrees (F) on a track with over the first 300 feet in concrete and know what you mean, but less throttle and burning more clutch will eventually net you grip.
I'm also curious how if you have a VLSD its letting you spin one tire, I've never had that issue.
__________________
Old 04-20-2008, 06:26 PM   #12
Maybe my tires are too wide for the stock power, i got 285 wide 18 inches.
Old 04-20-2008, 08:00 PM   #13
How would your tires being too wide make you spin?
__________________
Old 04-21-2008, 06:42 AM   #14
Nismofo
WalkerT's Avatar
I had 285 rears on my 05 and the vlsd would not last but one run. To much traction on one wheel will over load the fluid. All so it depends on the age of your Viscous. The fluid can only be broken down so many times before it gets real weak. I think sport compact car did a write up on the VLSD and had problems with theirs after just a short time. They said that it got scary because it would just decide to work when it wanted to even in the middle of a turn. It should be on their website under project cars.
__________________
07 Redline base
light weight = 3150 _ rwhp = 284 on the dyno http://www.youtube.com/watch?v=cotNSV7XyQg 13.4 @ 105
WalkerT is offline   Reply With Quote
Old 04-21-2008, 01:10 PM   #15
Know it all
07JimmyZ's Avatar
Quote:
I remember reading that issue as well. I believe they also said that at around 60k or depending on the wear, it will eventually act as an open diff.
__________________
07Ings TS-06MichelinNismoBerk BC Mastergrade
07JimmyZ is offline   Reply With Quote
Old 04-21-2008, 08:07 PM   #16
Sucks, gotta buy a new one . Got a supercharger on the way.
Old 04-21-2008, 08:29 PM   #17
Hmm, might be time to look for a base diff and transplant a real LSD.
__________________
Old 04-21-2008, 08:45 PM   #18
\Anyway, got a supercharger on the way now so maybe it will help a bit.
Congrats, now you'll get in the high 13's.
Motero is offline   Reply With Quote
Old 04-22-2008, 11:09 AM   #19
lolll....Yah right!! And yes, i'll get a new lsd.
Old 04-22-2008, 03:19 PM   #20
Doesn't look like I am going to see this time slip.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
