Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Drag
Old 04-20-2008, 04:56 PM   #1
chefrey's Avatar
drag radials
i recently have realized i am going to have big problems hooking at the track especially when on the juice.
my soultion seems to be a good set of dr's but im trying to use my 18 stock 03 rims. (i know bad idea but its all i have to work with for right now).
iam having problems finding a set that will fit the 8.5 rear rims cause bfg drag radials only come in a 275,35,18 which isnt recomended for that size rim. i have searched the web and found info on mickey thompson et street radials in 265,40,18 which seems to be a great fit but the only problem is all i found was info.
does anyone know where i can purchase a set of these
if im not in the right section feel free to move
chefrey is offline   Reply With Quote
Old 04-21-2008, 12:06 AM   #2
you arent likely to find anything really worth using in that diameter. you will either end up with a super tall tire or no sidewall. just keep on the lookout for a cheap set of wheels. maybe look into a set of z32tt rears
Hoooper is online now   Reply With Quote
Old 04-22-2008, 09:45 AM   #3
scotts300's Avatar
or BFG: http://www.jegs.com/p/BF+Goodrich/750350/10002/-1/36677
__________________
94' Z32TT (drag/track/show); 03' 350 (track); 04' 350ZR (DD); 04' Titan (Z-Hauler). Love cars, love life, love people in Zs.
scotts300 is offline   Reply With Quote
Old 04-22-2008, 03:41 PM   #4
chefrey's Avatar
Quote:
Originally Posted by scotts300
nothing there that is rated to fit on the stock 18inch rim or am i missing something?
Old 04-23-2008, 02:41 PM   #5
scotts300's Avatar
Quote:
I have seen many people put a 275 on an 8 or 8.5" wheel. 9" is the quoted minimum, but it has been done successfully. Ask any autocrosser.
__________________
Old 04-23-2008, 10:26 PM   #6
chefrey's Avatar
i have seen it done to but usually there is a little more sidewall involved then there is in this situation that is the part that bothers me about trying it, especially if i drop the tire pressure some to try and get better grip out of them.
Old 04-30-2008, 05:20 PM   #7
This combo makes a good cheap set up.
http://www.my350z.com/forum/showthre...ickey+Thompson
__________________
2007 350Z (San Marino Blue) 6 speed *stock* Best 1/4 so far, 13.157, Best Trap, 107.19. 2002 I35 Sport *stock* 2005 Armada SE *stock*
VeeTec is offline   Reply With Quote
Old 08-10-2008, 05:09 AM   #8
- - A d m i n i s t r a t o r - -
3hree5ive0ero's Avatar
So, I'm guessing 295s are out of the question for the stock 18" (from an '03), huh?
3hree5ive0ero is offline   Reply With Quote
Old 08-10-2008, 01:52 PM   #9
Question
What did you get?
How are you 60 foot times?
__________________
350Z 2004 Enthusiast: K&N Typhoon Air Intake - Motordyne Plenum Spacer - Alphawerks Stainless Steel Headers - Helix SS Test Pipes - Injen Super SES Cat-Back Exhaust System - 6 Pad Puck Ceramic Clutch and Forged Steel Flywheel by Competition Clutch - WedsSport SA-70
davidv is offline   Reply With Quote
Old 08-10-2008, 02:42 PM   #10
Davidv, if you're asking me, I didn't get anything. My short time is around 2.0-2.1 on average on street tires - still the same, just not as consistent as I used to be due to lack of practice.
Old 08-10-2008, 08:22 PM   #11
LOL. No. The question is for chefrey. It's been 3 months.
__________________
Old 08-12-2008, 12:12 PM   #12
95snoozer's Avatar
the 275 is fine on the 18 inch rim if the OP has not gotten them. I have seen 315 DRs on an 8 x17.... now that is stretching it.
__________________
"i forgot you suck at drag racing anyway. sucking at something that takes no skill must really suck" - jackie chan
95snoozer is offline   Reply With Quote
Old 08-12-2008, 12:24 PM   #13
Quote:
Is that even helpful at that point? I was contemplating whether or not I should get 295s for my stock 18"x8", but damn.
Old 08-13-2008, 12:52 PM   #14
athenG's Avatar
/\ maybe not to the OP but for others I was going to make a thread about this but I guess I'll just add to this one. Anyone else mounted a 275 or higher on an 18x8 wheels? My other option is to just mount a 245 but not sure if that is enough to handle mid to high 300whp.
athenG is offline   Reply With Quote
Old 08-13-2008, 12:56 PM   #15
Lovin Life
coachk's Avatar
I've put a 275 on a 15x8 with no problems
__________________
2003 PPW 5AT.....Lovin Life www.performancefactory.com
coachk is offline   Reply With Quote
Old 08-13-2008, 01:04 PM   #16
athenG's Avatar
Quote:
But thats in the manufacturer's safety range. Most 15" will not have a problem with 275 since 275 has a range of 7.5'' - 9.5'' for the 15" wheels.
Old 08-13-2008, 05:44 PM   #17
Lovin Life
coachk's Avatar
Quote:
I did not know that...then what range would a 275 have for an 18" wheel?
After researching you are absolutely correct.....In order to use a 275 on a 18" wheel it is recommended to use a 9"-11" width
__________________
Old 08-13-2008, 06:37 PM   #18
How detrimental would it really be to mount a tire on a wheel that is smaller than the recommended width for the tire?
I'm sure the grip and the top end would suffer, the tire would probably wear out unnaturally.. safety-wise, I don't think there'd be a problem, no?
Old 08-14-2008, 09:46 PM   #19
Z + Rear Seat
__jb's Avatar
If the width of the tire stays the same and the rear wheel gets narrower, the car will sway more... especially if you run lower air pressures.
If the width of the tire stays the same and the sidewall gets thinner, the width of the wheel will/should increase.
__________________
Florida G Club, President
2k5 LR G35 Coupe 6MT
CrawfordZ Plenum, Headers, HFC | HKS TI | Carbonetics LSD | 4.083 FD
Haltech | Osiris | JE, Eagle, JWT Cams | Performance Factory VQ35DE 312 rwhp
__jb is offline   Reply With Quote
Old 08-15-2008, 05:25 PM   #20
blktrack350's Avatar
i had a set of 245/45/18 bfg drag radials about 1 year ago, i dont know if they just stoped making them in that size or something. but the drag radial in your pic is a mickey thompson et street. check ebay i have found are size on there.
__________________
99% of Z owners have gotten a Speed Related Traffic Citation. If you are part of the 1% who has NOT, Put this in your sig!
blktrack350 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
