Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Drag
Old 06-21-2008, 08:05 AM   #1
first time running my 03 Z Touring
Best time of the day was a 14.288, was at New England Dragway, it was about 98 degrees out, lots of humitidity, i dont know how badly the heat affected my time. Its a 2003 350z Touring, bone stock down to the tires, 42,000 miles on it. I weighed in at 3188lbs with me in the car.
TopNotch is offline   Reply With Quote
Old 06-21-2008, 11:16 AM   #2
skaterbasist's Avatar
Good times for the weather. That track usually yields good times... its only 80 feet above sea level.
On colder weather, you would be high 13's.
skaterbasist is offline   Reply With Quote
Old 06-21-2008, 11:35 AM   #3
Doesn't appear as though temperature had a significant effect on trap speed: you are picking up 21.6 MPH in the second 660 feet.
I would like to see a 2.0 second 60 foot time with 9.1 second 1/8 mile time. That would give you a 13.XX second final ET. The Z has the potential.
__________________
350Z 2004 Enthusiast: K&N Typhoon Air Intake - Motordyne Plenum Spacer - Alphawerks Stainless Steel Headers - Helix SS Test Pipes - Injen Super SES Cat-Back Exhaust System - 6 Pad Puck Ceramic Clutch and Forged Steel Flywheel by Competition Clutch - WedsSport SA-70
davidv is offline   Reply With Quote
Old 06-21-2008, 02:03 PM   #4
any other z's there to compare trap speed to. and was that one of you faster traps. do you feel your shifting fast and not hitting rev limiter. a friend of mine was upset about his results and let another friend drive. the second driver went slower in 60' and picked up a little over 2mph in trap and dropped .3 off e.t.
hopefully we can roll deep next time to the track
__________________
12.932 @ 109.184 w/ 1.814 60' n/a e36 m3 w/ driver ~2600lbs
97ltw///m3 is offline   Reply With Quote
Old 06-21-2008, 02:44 PM   #5
Actually my fastest trap of the day was 100.90, but was a 14.312, 60' time was a 2.209. I did feel i was shifting fast enough, no rev limiter interuptions etc etc. I was not launching it very hard tho, it was mainly a 3,500 rpm slipping the clutch out (not poping the clutch). Traction was decent, but like i said it was hot as hell out that day. A kid that was with me with a modded bmw 335xi who usually runs 13.0's couldnt break 13.4's, (let alone his oil temp was sky high).
Unfortunatly there were no other Z's or G's there to compare my times/traps with, it was a Camaro Firebird day. The only non camaro's/firebirds were me, a 335xi, 1 wrx, 1 sti, and 2 srt4's.
When ever you wanna go LTW!! You let me know, either NH or NJ, i wanna do NJ on a friday so we can hit the track at night, the gates open for Time Trials at 5pm fridays and wednesdays.
Old 06-21-2008, 02:48 PM   #6
z_mini's Avatar
Not bad timing.
My best time was 14.1. I have 03 touring with (5at)
CAI and spacer.
z_mini is offline   Reply With Quote
Old 06-22-2008, 10:21 AM   #7
mw9
mw9's Avatar
Here's my best 03 touring on kdw,s 245/45/18. I expected alittle better. Utec was not turned on, no tune yet. any other suggestions on getting 60' foot time down. There was another Z there today, didn't get a chance to talk to him, looked like an 06, his best was a 13.1. RIGHT LANE
__________________
KJR pulley, motordyne 5/16 spacer, rogue short shifter, all amsoil fluids, JWT popcharger, 350evo sways, AAM ypipe, helix tps, UTEC, Tokico HP blue, Tein S
mw9 is offline   Reply With Quote
Old 06-24-2008, 01:05 PM   #8
I dont know
aceman's Avatar
Quote:
Are you sure your car is stock..
This is what the weight of a 03 Touring should be...
Touring (mt) 3247 (at) 3239
Later
Todd
__________________
13.005@106.55mph Best Trap 108.54mph 03 Daytona Blue 6spd --XBOX 360 SCREEN NAME ( ACEMAN350Z ) TEAM DNF
1.Crawford Plenum.. 2. Bored Throttle Body.. 3.Larger MAF housing.. 4.Modified stock air box(K&N filter).. 5.UR PULLEY.. 6.JUN FLYWHEEL.. 7.KINETIX RACE PIPES.. 8.DC SPORT HEADERS.. 9.FAST INTENTIONS EXHAUST.. 10.NISMO CLUTCH.. 11.UTEC TUNED BY ME.. 12. 4.083 Gears
aceman is offline   Reply With Quote
Old 06-24-2008, 05:25 PM   #9
Later
Todd
Totally positive, the only thing that i removed out of the car was spare tire, and the trunk mat. Weighed in with exactly 1/4 tank of gas @ 3188lbs with me in it, i talked to the workers at the booth at the strip and they said their scale is calibrated down to the 1lb. I only weight 130lbs myself. Leaving my car to weigh 3058lbs, next time i'll go with an 1/8th tank of gas to make it a lil lighter.
I think i could have definitely launched the car alot harder, i was just scared to break something since its a 3 hour drive back home and it was more of a base stock run anyway. Next time, there will be no mercy...
Old 06-24-2008, 06:00 PM   #10
bacalhau16's Avatar
NED is a pretty fair track. I ran a 13.9 there in my Z with a few mods and 2.2 60'. If you go to the right events its prepped really good. If you go to time trials on Wednesdays or Fridays, they dont usually use the sticky spray stuff, (EET or something like that.)
__________________
Third times a charm. Im not giving up this Z. Parts are on their way already!!!
bacalhau16 is offline   Reply With Quote
Old 06-25-2008, 04:20 AM   #11
Quote:
Yea i went on a Saturday Camaro/Firebird day and they spent all morning spraying down the VHT (sticky stuff), it actually worked real well but made me afraid to launch my car too hard and break something haha. Not worth it for a base run.
Old 06-26-2008, 03:22 AM   #12
bacalhau16's Avatar
If you dont wheel hop, chances are your not gonna break anything stock. If it ends up gripping that good. Your either just gonna bog because your not giving enough gas, or your stock clutch is gonna get a little angry and slip a little. Or ofcourse you'll just have an awesome launch. But shouldnt be any breaking really.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
