Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Drag
Old 07-27-2008, 04:30 PM   #1
h0pes's Avatar
Leave it in Drive or shift "manually" with AT?
Whats the best technique with an auto to get low 1/4 mile times?
If it's better to shift the gears manually, what RPM should I shift at? Peak HP is at 6800 RPM in the '07/'08 models so would that be ideal? That's what I've been shifting around.
I also notice it takes a split second between me shifting up and for it to actually occur, so I've started shifting a little earlier to avoid going over 6800.
I'm a noob.
__________________
Black '07 Touring | Nismo Intake & Exhaust |
h0pes is offline   Reply With Quote
Old 07-27-2008, 04:56 PM   #2
Quote:
So post a time slip and lets see how that method is working for you.
__________________
350Z 2004 Enthusiast: K&N Typhoon Air Intake - Motordyne Plenum Spacer - Alphawerks Stainless Steel Headers - Helix SS Test Pipes - Injen Super SES Cat-Back Exhaust System - 6 Pad Puck Ceramic Clutch and Forged Steel Flywheel by Competition Clutch - WedsSport SA-70
davidv is offline   Reply With Quote
Old 07-27-2008, 05:30 PM   #3
ajcool2's Avatar
I've never raced my car in D when at the track.
__________________
04 Touring 13.849@101mph AUTO Stock l 13.517@102.30 Modded
ajcool2 is offline   Reply With Quote
Old 07-27-2008, 07:22 PM   #4
Get_Zwole's Avatar
07's redline at 7500 right? Shift at 7500 then. They picked that redline for a reason.
__________________
06 SA Coupe 6mt, not enough mods.
DNF
Bawlz in yo mouf
XBL= Get Zwole
www.boostedimports.com www,mygtr,com
Get_Zwole is offline   Reply With Quote
Old 07-27-2008, 08:56 PM   #5
h0pes's Avatar
Quote:
And judging by your sig, you race your auto pretty well. Around what RPMs do you shift?
__________________
Old 07-27-2008, 08:57 PM   #6
h0pes's Avatar
Quote:
I haven't gone to the track yet, davidv.
__________________
Old 07-27-2008, 10:18 PM   #7
Slurrp!!!
fowlman01's Avatar
Shift manually, it should shift instantly. If you shift at redline it will go up a couple hundred rpms, so you are probably hitting the rev limiter, which will slow your shifts by about 1/10th of a second.
__________________
NISMOS / WORK VSXX/PILOT SPORTS/ BORLA/ STILLEN SHIFT KIT / VORTECH/ ROTORA/ HAWK/ DC /DEFI/KurumaZ
The race
fowlman01 is offline   Reply With Quote
Old 07-28-2008, 12:37 AM   #8
Try each and see what works best for you. Automatic racers also remove the brake fuse or brake light. Has something to do with power-braking. So go to the dragstrip and have fun.
__________________
Old 07-28-2008, 06:53 AM   #9
Slurrp!!!
fowlman01's Avatar
Forgot that. Yes, remove the brake light fuse or you will lose power if you power brake before launch. It tells the ECU that there is an unsafe condition and cuts the power by about 30%. Removing the fuse fools it. If you run in drive expect to turn about 3-5 tenths slower.
__________________
The race
Old 07-29-2008, 10:09 AM   #10
ajcool2's Avatar
Basically the same as fowlman01 said. I havent run without the brake fuse yet though. I forgot to remove it last week when I ran. I'll try it out this friday when I go and post my results.
__________________
Old 08-01-2008, 05:39 AM   #11
Performance Factory
Audible Mayhem's Avatar
i would ask coach k and do whatever he is doing.
he has the fastest recorded 5AT that anyone has posted on here....
and thats on a stock block!!
__________________
Jeremy Tibbs, Orlando, Florida HKS Pro Dealer Deatschwerks dealer
sales@performancefactory.com 1-877-375-RACE 407-251-6556 (local) JWT licensed dealer
www.performancefactory.com Licensed Vortech Supercharger Dealer Powerlab Dealer Haltech Dealer
Audible Mayhem is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
