You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Another try at the 1/4, better but no track prep still. :(
So I had no traction in 1st gear. UGGG! My first few times were better than the rest of them. Our track is 600ft above SL. I did better than some LS1 powered cars and a 370z. The 370z stock 6mt, was only able to pull of 14.0-14.4s at 101-104s that night. I think he got one 13.9.
My best of the night for was 13.8900 at 101.79. 60ft was 9.0646.
My best MPH was 104.51
All my runs I had wheel hop and tire spin no matter what RPM I tried. I tried 2k, 3k, 4k, clutch slipping, everything and nothing worked. I tried pressures from 25-35. By the end of the evening my car was starting to get heatsoaked, and was running slower and slower. So I stopped and let it cool and ran the last run of 13.9.
My car only had K&N Drop ins, HFCs and UPREV Tune. 1/4 tank of gas. I did not remove anything from the car. Tell me what you guys think....
interesting runs. did u go with some more Z's or just randomly? we should meet up there some time. I went like one week before u. but i only ran a 14.47 at best. (im a noob)
how often do you go? I was thinkin bout going in a couple weeks again (after i get my clutch installed).
__________________
04 CS touring 6spd. LED license plate+map+parking lights, JWT popcharger, Stoptech slotted rotors with Hawk HPS pads, Berk Technology HFC, Powerlab 3/8" Spacer, 19" G35 wheels, JDM clear corners, Borla TD and a Texas A&M badge more coming when $$ permits!!
haha nice i've only gone twice in two years of having my car as well lol but i feel like i did horrible last time so I wanted to go atleast once or twice more this summer to redeem myself lol. I ran a 14.2 the first time I went so i wanted to atleast beat that lol. I'll prob go once after the clutch/flywheel install. and once in july/august if I get a tune from uprev.
but ill let u know for sure
__________________
do everything he says, but you have to experiment with the burn out to see what your tires like. that being said, you absolutely must do at least a little 1-2 second burn out to clean the debris off your tires, especially after the first run. the vht makes your tires sticky to the touch, and they pic up a bunch of little rocks that you end up "spinning" off when you launch of you don't clean them off with a short little burnout before.
the link above is more aimed towards vette's, but the same principles can be applied to any decently powerful rwd car on street tires...
__________________
no matter how awesome a car is, you can always do an el es huan swap and make it awesomer
My best time is at 13.7 at 102.85 with just Injen CAI and greddy Ti-C dual on a 08 base model on street tires. I want to get the Uprev tune soon and go to a better track... i keep my tires at 25 to 26 psi
__________________
08 Base 282rwhp on PRS mustang dyno, Injen, Greddy,Berk, Uprev. OZOC CSC Fixed by Zspeedperformance.com
04 Enthusiast, intake, plenum spacer, test pipes, xyz pipe, and shockwave single exit. The baldest tires on earth, and the air was horrible last Friday.
All in all that isn't a horrible time... but my guess is your launch included bogging on take off? You just need a lot of practice slipping the clutch out man... I think your shifting is spot on (looks like you are gaining MPH like you should after you get moving) but you are not leaving the line clean enough.
The link posted above (Ranger Acceleration) has information that really does work. In fact that is the same method used by the 'record holders' around the country (including the HR owners on this site if I am not mistaken). It's very hard to get perfect but I ran my best time using this method on the 4th pass of the day (on a hotlap... pass just before it was a 13.2 @ 107)... I showed the fiancee what I was talking about and told her exactly what to try... on her 3rd pass at the dragstrip (ever) she pulled off a 13.1 @ 105mph in my car. (you could smell the clutch after she left the line but she pulled a 1.99 60ft )..
My car has 50~60+ passes on it slipping the clutch and I am sitting at 104,000miles on the car with the factory clutch still in it. Nothing to worry about man. You will hurt your car worse spinning and wheelhopping than you will slipping the clutch out.
