You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Your trap def puts you in 11's. Although removing weight will help, the biggest issue for you will be to get your 60' down. Drag radials will def do that. What tire psi are you set at with your street tires? Also what specs on the street tires?
Can you soften the suspension for weight transfer to help the 60' with the drag radials? That'll blow your $300 budget anyway.
__________________
Quote:
Originally Posted by solidfish
Hey scott. Thanks for the ride by the way. Your car and driving is sick. Literally, I was sick. It was like riding a mad rollercoaster. The car turns like its on rails. And the braking was unreal. So many times I thought we were going to fly off the track. Absolutely nuts, but it was great fun.
i have 255/40/18 kdw on the rear which i lower the psi to 15 but that was a mistake.. i got 2.4 60' with that. when i up the pressure to 35 it went down to 2.1-2.2
i had a 1.8 60' with street tires b4 on some 275/40/18 continentals.. dont know how that happened!!
i def need dr or slicks!!
__________________
VQ35DE ENGINE PARTS FOR SALE!! LMK WHAT YOU NEED
i would never go below 20-22 on a street tire. I run ~24 and that nets me the best results, but you are going to need the dr's or slicks to get to the 1.8's with boost. Good luck
__________________
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
just remove the spare tire and etc. and get a good set of tires to bring along and mount on.. et streets mounted on a flix ftd lightweight 17" wheel are what i run at 400whp and have no trac. issues and pull 1.6's
__________________
vortech 03 touring 6spd 1.664 60ft..11.78@117.15..3.12 pulley (9-10psi) ..stock block..stock internals....time to part out and start over..
