You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Finally got a chance to install line locks to warm up my tires at the track. I will probably catch some crap for putting them in the wheel wells but I'm working on a cover to protect the solenoids from the elements while still allowing them to cool off.
Here are some pics of the install
here are the part numbers do some shopping around and you should be able to find it under $175
xrp fittings
(4) 982203 elbow 90 #3flare-1/8 npt
(1) 410103 3 male to m10x1.0mm female (pair)
(1) 420003 3 male to m10x1.0mm male (pair)
(4) 630009 strait 3 to straight 9" hose
wow those times are insane. guess my car is too heavy. If you compare the na top 25 on driver Im in spot 4 or 5. on my 350z im not even on any list wow. oh well it hooks like crazy
What's your backspacing for your fronts and rears? I'd appreciate it if you could share the entire spec for both fronts and rears. I had 15x8 Weld Draglites with 5.5" BS a couple of years ago, but I sold them.
Also, what does your short time look like? Can you post your best time slip to date?
BTW, G35Driver has a LOT to catch up in many respects. Hurry up and get on the list.
The welds are 15x9 w/ 6 bs and 15x3 w/ 1.5 bs The only thing is the offset is a little wacky. I have to make spacers at my machine shop and as well machine my lugnuts its a little hard to explain let me go get some pics
I have 305/35-18's et streets and they are sweet. I'd like to go down to some 15's or something in the rear. How do you get them to fit over your brembos?
