Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Drag
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 08-24-2009, 09:42 AM   #1
widerisbetter
widerisbetter's Avatar
Points: 2,360, Level: 29
Points: 2,360, Level: 29 Points: 2,360, Level: 29 Points: 2,360, Level: 29
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default First time dragging the Z
I have dragged cars before but none have been this difficult.
A quick run down on the car
TT JWT 575whp on pump
18 inch NIsmo lmgt4s with BF GW TA's 295's at 31psi
It was an 1/8 mile strip and my best time was 8.65 at 91.27 mph. My 60 foot was a joke with a best of 2.3. I preloaded the drive line using the emergency brake also.
I know the car is ALOT faster but wheel hop and spin was killing me. That and I didnt want to push the stock axles and diff bolt too much. The car is setup for roadcourse but just thought it would be fun to go to the strip for a day.
What do you think I should run with good tires and such?
__________________
Cant we all just get along
widerisbetter is offline   Reply With Quote
Old 08-24-2009, 02:52 PM   #2
Points: 9,435, Level: 65
Points: 9,435, Level: 65 Points: 9,435, Level: 65 Points: 9,435, Level: 65
Today's Activity: 99.9%
Today's Activity: 99.9% Today's Activity: 99.9% Today's Activity: 99.9%
Time slip appreciated. Thanks.
__________________
370Z 2009 Sport Package
davidv is online now   Reply With Quote
Old 08-24-2009, 05:15 PM   #3
d1mon3k
Points: 1,705, Level: 24
Points: 1,705, Level: 24 Points: 1,705, Level: 24 Points: 1,705, Level: 24
are you stomping on it or easing into the launch with the gas pedal?
__________________
570z/ Work Wheels/ LS1 Engine/ Sikky Engine Mount kit/ Sikky 1 7/8 inch LT Headers/ TSP Custom Cam and Cylinder Heads/ LS6 Intake Manifold/ 406 whp All-Motor
d1mon3k is offline   Reply With Quote
Old 08-24-2009, 06:03 PM   #4
str8dum1
Points: 3,964, Level: 40
Points: 3,964, Level: 40 Points: 3,964, Level: 40 Points: 3,964, Level: 40
Today's Activity: 33.1%
Today's Activity: 33.1% Today's Activity: 33.1% Today's Activity: 33.1%
the guys that hook around here can run 7s with low 90 mph trap. my best is 8.47 @89. I've done a few 8.6's at 87 mph
driver mod is worth more than anything else at this point
__________________
VQ38DETT with SFR Twin 6262 on ProEFI128 Corn Fed
str8dum1 is offline   Reply With Quote
Old 08-24-2009, 07:39 PM   #5
widerisbetter
Well Im gonna try and take some pressure out of my tires to maybe help a bit.
As for the throttle. I was trying a variety of things, from rolling into it, to hammering the **** out of it.
__________________
Old 08-24-2009, 07:40 PM   #6
widerisbetter
Ill cant post the slip, but ill write the times down.
__________________
Old 08-25-2009, 03:33 AM   #7
ET looks like naturally aspirated.
Trap speed is certainly forced-induction.
1/4 trap speed will be 114 MPH plus.
BTW you did a hell of a lot better than these dyno racers: http://my350z.com/forum/forced-induc...p-25-list.html
__________________
Old 08-25-2009, 05:27 AM   #8
widerisbetter
So what do you think this car should run? my time slip is as follows
reaction---------.0121
60ft-------------2.5761
330ft------------6.214
594ft------------8.412
1/8 et-----------8.950
1/8 et-----------91.27mph
__________________
Old 08-25-2009, 05:40 AM   #9
JTinFL
The owner of that last car on those same tires went 12.5 at 125 his first time down the track. You just need to baby it a lot more.
Better drag racing tires next time because with the tires you have you arent going to be able to floor that car till at least third gear at the track. It has too much power unless you are on really low boost.
I wouldnt waste any more time also at an 1/8th mile track with a built motor twin turbo Z unless you are on full slicks.
JTinFL is offline   Reply With Quote
Old 08-25-2009, 05:48 AM   #10
JTinFL
Sorry but this time slip needs A LOT of practice. Practice makes perfect with the right setup.
On good tires, that 1/8th mile should be close to 2 seconds faster than that. That would be about 20 car lengths or so at the track. The mph is not horrible but should definitely be higher. The 60 foot means you just sat there and dumped it and spun then probably short shifted to second because you were banging the rev limiter so much.
Keep practicing and get some better tires for straight line and you will improve ten times as much. Have fun and let me know if you have any questions.
Old 08-25-2009, 06:30 AM   #11
S8ER95Z
Points: 3,473, Level: 36
Points: 3,473, Level: 36 Points: 3,473, Level: 36 Points: 3,473, Level: 36
Ouch... on a 2.1 60ft I'm hitting 8.6 @ 85mph... I would say you should be seeing 7s in the 1/8th for sure and the mph is suffering as well so expect that to pick up with a better launch. To hard to say for certain though... need to practice getting a clean smooth launch and just watch the numbers drop.
__________________
2001 Z28 M6 - 13.19 @ 108.59mph (Stock) - Best Trap 109.33mph (FRA/LID)
S8ER95Z is offline   Reply With Quote
Old 08-25-2009, 07:06 AM   #12
My dial in is 8.8 seconds. And you are running 8.9 seconds? Shame on you. Just kidding. I could never make 91 MPH. That's where your horsepower shows. As I mentioned, 1/4 trap speed will be 114 MPH plus.
__________________
Old 08-25-2009, 07:31 AM   #13
widerisbetter
Im thinking of going again this friday for t&t. Ill try to part throttle it a lil better and see where we end up
__________________
Old 08-25-2009, 07:46 AM   #14
widerisbetter
BF Goodrich KDW-2 265/35 front, 295/35 rear
These are the tires...should they be heated or just spun to clean them ?
__________________
Old 08-25-2009, 07:53 AM   #15
widerisbetter
Hey Justin, I got your PM btw. Car is great, im just now gettin to play with it some. I dont want to change to much because I like autox and road course better, But just wanted to play a bit.
If were to do slicks, I would need an axle upgrade and the Diff braced.
Hows the new shop?
__________________
Old 08-25-2009, 08:50 AM   #16
Its going to be addictive. 200 or 400 pounds of torque - everyone has traction concerns.
You can feel the tires bite when you transfer weight from the front over the rear tires. Then hit the gas.
__________________
Old 08-25-2009, 08:54 AM   #17
No need to burnout street tires. W rated tires resist heating. Just a quick spin to throw off water and dirt.
If possible go around the water box.
__________________
Old 09-06-2009, 12:38 PM   #18
binder
Points: 3,717, Level: 38
Points: 3,717, Level: 38 Points: 3,717, Level: 38 Points: 3,717, Level: 38
Today's Activity: 7.4%
Today's Activity: 7.4% Today's Activity: 7.4% Today's Activity: 7.4%
Send a message via AIM to binder
ya, your 60' is killing you. you should be under 2 seconds on that.
we race the 8th here locally. Mid 7's is a good number for a car in the 8th. That keeps up with the average rider on a stock 600cc bike.
binder is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
350z, 60, afb, drag, eglin, improving, racing, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
