You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Well since there are alot of fast Z/G's that drag alot, where are people getting their drive shaft loops.
Technically you need them for all RWD cars running 13.99 or quicker with slicks and 11.49 or quicker with street tires must have a retainer loop 360 degrees
of enclosure, 1/4-inch minimum thickness and 2 inches wide, or
7/8-inch x .065-inch welded steel tubing, securely mounted and
located within 6 inches of the front universal joint for support of the
driveshaft in event of U-joint failure.
After pushing my car into the garage with the driveshaft hanging, its easy to see how that could pogo stick your car if it wasnt looped.
So post up the pics, or info on what you are using
__________________
VQ38DETT with SFR Twin 6262 on ProEFI128 Corn Fed
Every time I go to Capital there is 1 tech who threatens to not let me run since I don't have one, but he always lets me go. He is the only one who has ever brought it up.
__________________
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
SP runs at tracks that don't give two shts about tech. They might have one - I have no idea on that, but Byron Dragway, GLD, and US41 Dragway (the tracks that they run at, not sure if they ever run at RT 66 but I doubt it) all don't even make you pop your hood, let alone check under the car for a driveshaft loop.
There are like 3 braces and the exhaust which all sort of act like a driveshaft loops anyways. Between that fact and the fact that you aren't making huge power, it's not something I'd worry about in the slightest.
__________________
95 Maxima 11.7 @ 121 - ET Streets - 12.1 @ 123 - Nitto DRs - Stock VQ30 tuned by me on pure 93 - www.deatschwerks.com
We have a bolt in / bolt on solution that requires no modifications and no removal of the driveshaft for install. Call us to order: 859-224-0461.
__________________ Phone: 859.230.9027. We are a performance parts distributor, with services including
dyno tuning, high performance engine building, and turn-key packages from 400-1000+whp Like us on Facebook for shop news and sales!
...not to mention the Z's driveshaft is carbon so in the case of a driveshaft failure, it would shatter well before it would pogo stick your car in the air.
Why are you pushing your car around with the driveshaft hanging??? If you nick up the carbon you can compromise the physical integrity of the shaft and are asking for failure.
Why aren't you using a drive shaft loop? why even take the risk for a $50 part? And not everyone lives near a track that doesnt tech the cars properly.
__________________
Well then get yourself a driveshaft loop. (I didn't know you had a G35)
Have you seen the underside of a Z? You can hardly see the driveshaft because of everything that's bolted on under it. There is NO WAY that thing is getting out of there if it broke and like I said before it would just shatter anyway.
