Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Drift
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 09-22-2008, 06:08 PM   #1
Nevaland90
Nevaland90's Avatar
Points: 1,832, Level: 25
Points: 1,832, Level: 25 Points: 1,832, Level: 25 Points: 1,832, Level: 25
Today's Activity: 1.4%
Today's Activity: 1.4% Today's Activity: 1.4% Today's Activity: 1.4%
Default Im pretty sure i killed my VLSD
so i kinda saw this coming...at first the diff was perfect...i could slide around in 2nd all day, then i started noticing after the diff got hot it would peg leg if i dumped it in 2nd from a stop. I figured the dif was just over heating and getting old...ive had VLSDs in my S13 before, no biggie. Then i started worrying when powering over, the diff started peg legging. Now the diff wont work at all, if i jump on the power early thru a turn itll just light up the inside tire. Also from a stop it just spins one tire
I just had the car aligned and also changed the diff fluid to synthetic from the dealership about 5k ago everything was perfect but now im convinced that my diff is dead. what do i do now? Will the dealership cover this under warranty, if so how do i go about telling them about my problem? I dont even think i want another VLSD has anyone heard about the dealer replacing with a nismo diff + the difference in cash?
any input would be great, ill try posting this in the motorsports section also.
Thanks-Jason
__________________
Wrap up, stance down www.facebook.com/stickygarage
Nevaland90 is offline   Reply With Quote
Old 09-22-2008, 06:53 PM   #2
USANA Z
USANA Z's Avatar
Points: 1,943, Level: 26
Points: 1,943, Level: 26 Points: 1,943, Level: 26 Points: 1,943, Level: 26
Today's Activity: 0.2%
Today's Activity: 0.2% Today's Activity: 0.2% Today's Activity: 0.2%
i would just get a tomei, kaaz, or nismo 2way. i never heard of nissan replacing a vlsd with a nismo one under warranty.
USANA Z is offline   Reply With Quote
Old 09-22-2008, 06:58 PM   #3
RMichael
Points: 476, Level: 9
Points: 476, Level: 9 Points: 476, Level: 9 Points: 476, Level: 9
Today's Activity: 99.7%
Today's Activity: 99.7% Today's Activity: 99.7% Today's Activity: 99.7%
How many miles on the car? The viscous pretty much reverts on its own at a certain mileage even in normal driving. It should be covered if you're under warranty. You may want to switch to a 1.5 (a 2 is dicey if you're not used to it) if you're trashing the stock.
RMichael is offline   Reply With Quote
Old 09-22-2008, 07:56 PM   #4
Nevaland90
Nevaland90's Avatar
Quote:
the car is a 04.5 with 37k on it.
what do you think the best way to describe my diff problem to them would be?
__________________
Old 09-22-2008, 08:04 PM   #5
RMichael
I'm here for routine maintenance. BTW, can you check the back of the car...it's making an odd sound. I don't know much about this stuff but it sounds like it's coming from that big round thing in the middle.
Old 09-23-2008, 07:33 PM   #6
o.g.darkdrifter
o.g.darkdrifter's Avatar
Points: 1,385, Level: 20
Points: 1,385, Level: 20 Points: 1,385, Level: 20 Points: 1,385, Level: 20
Today's Activity: 4.6%
Today's Activity: 4.6% Today's Activity: 4.6% Today's Activity: 4.6%
If your vlsd is worn and you want a cheap solution you could always shim it. You could get the results of a 1way all the way up to virtually having a welded. If you shim it to react like a welded I'd reccomend getting a nismo diff cover to handle the heat. I have friends who have done this to their car and havent had any problems with it for about 6 months now. Daily driving duties, drift events, and 9 hr trips out of state, no problems at all.
Otherwise just get an aftermarket clutch type lsd.
o.g.darkdrifter is offline   Reply With Quote
Old 10-05-2008, 07:07 AM   #7
Audible Mayhem
My350z
Send a message via AIM to Audible Mayhem Send a message via MSN to Audible Mayhem
try changing the fluid first then drive it around normal for a bit.
Audible Mayhem is offline   Reply With Quote
Old 10-05-2008, 08:23 AM   #8
TRYNALIVEPRO
TRYNALIVEPRO's Avatar
Points: 2,411, Level: 29
Points: 2,411, Level: 29 Points: 2,411, Level: 29 Points: 2,411, Level: 29
Today's Activity: 1.6%
Today's Activity: 1.6% Today's Activity: 1.6% Today's Activity: 1.6%
Thanks-Jason
I'm surprised it even lasted this long
TRYNALIVEPRO is online now   Reply With Quote
Old 10-05-2008, 09:18 AM   #9
j.arnaldo
j.arnaldo's Avatar
Do you have a heavy foot, Nevaland? Did you race your Zee hard and/or often? I have an 'O4 Touring Coupe with a f-l-a-w-l-e-s-s AT, 17+k, &, so far, it's been a sweet experience!
Since I'm 59, MTs don't appeal to me any more. I got this nice deal with my Zed:
'O4 Touring Coupe with 13k, for $2O,5OO (these beaZts are very expensive down here)!
Good luck on your VLSD odyssey.
j.arnaldo is offline   Reply With Quote
Old 10-05-2008, 09:53 AM   #10
TRYNALIVEPRO
I've witnessed this car sideways going down a hill, I give it to him, he can drive.
Old 10-05-2008, 03:27 PM   #11
Nevaland90
Nevaland90's Avatar
Quote:
i changed it for nissan synthetic ish like 9k ago...it worked good for about 100 miles...w.e its dead the nismo shop has a pretty sweet deal going on right now
__________________
Old 10-05-2008, 03:28 PM   #12
Nevaland90
Nevaland90's Avatar
Quote:
when did you see my car?
__________________
Old 10-12-2008, 04:01 PM   #13
matix101vz
matix101vz's Avatar
Points: 2,043, Level: 27
Points: 2,043, Level: 27 Points: 2,043, Level: 27 Points: 2,043, Level: 27
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Send a message via AIM to matix101vz
ive been in it going sideways ... he can drive
__________________
03 BRICK | Full LED Conversion | CF Duct | CF Chin | Borla Exhaust | Top Speed Test Pipes | Avic-F700BT | EVO-R Shift Knob
matix101vz is offline   Reply With Quote
Old 10-17-2008, 11:15 PM   #14
amg55driver
amg55driver's Avatar
Send a message via AIM to amg55driver
so, little off-topic,
but. if i weld my vlsd (touring model), will it throw any code? (slip or vds off)
amg55driver is offline   Reply With Quote
Old 10-18-2008, 12:18 AM   #15
m3inaz
Newbie
Points: 2,540, Level: 30
Points: 2,540, Level: 30 Points: 2,540, Level: 30 Points: 2,540, Level: 30
How do I know if my VLSD is having issues? I have noticed lately My car seems to feel like less power is getting to the wheels than whats coming out of the tranny/motor.
Also, Whenever VDC is off, I will break loose much easier than i used too..the tires are getting worn with 22,000miles on them, any input?
m3inaz is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
2008, 350z, changing, drift, fixing, fluid, for, g35, good, infiniti, miles, s13, shim, shimming, vlsd, welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
