Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > Motorsports > Drift
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 02-09-2009, 06:23 PM   #1
Nackers
Points: 1,072, Level: 17
Points: 1,072, Level: 17 Points: 1,072, Level: 17 Points: 1,072, Level: 17
Today's Activity: 0.8%
Today's Activity: 0.8% Today's Activity: 0.8% Today's Activity: 0.8%
Send a message via AIM to Nackers
Default Handbrake modification (not a tighten post)
I was wondering if anyone has played with the idea of adding a shaft to lengthen the factory handbrake giving you more leverage and put the handbrake in a better location?
I've been thinking about using some pipe we have at work and putting a small kink bend into it so it clears the interior trim and leave plenty of room to get a hand in there. Also, I was going to drill a hole in it, insert a small metal rod and weld it in place so once the added shaft was installed, it would act as a "drift knob" holding the release in. I'm not really worried about keeping the car all mint or anything, so I was thinking I could attach this by removing the boot and drilling 2 holes through the factory handbrake lever and using 2 long bolts/nuts to hold the shaft on. Something easily removeable so I can DD and park like I'm used to.
Anyone have something simular to this or possibly a better way of going about it besides for upgrading to a hydraulic handbrake?
The thing I'm sorta worried about drilling 2 holes through the factory lever is that at least on the 240sx the handbrake lever is thin sheet metal and I'm worried with only 2 small long bolts it may tear or something.
Feedback?
Nackers is offline   Reply With Quote
Old 02-09-2009, 07:38 PM   #2
KS0385
Be same and go with like 5 smaller bolts. Some 1/4-20 maybe. And putting holes into the original metal will weaken it a lot.
__________________
2008 PPW Base - Fast Intentions
KS0385 is offline   Reply With Quote
Old 02-09-2009, 08:53 PM   #3
albinobob
Points: 1,200, Level: 18
Points: 1,200, Level: 18 Points: 1,200, Level: 18 Points: 1,200, Level: 18
I think I heard about somebody switching it out with one from a 240. I had the same Idea you had though: Basically a pipe bend at the end that slides over the handle putting a bolt the through it to engage the button and threading a couple of holes to torque some nuts down on the handle to keep it all in place. The trick is making it look pretty (that if you care, if it's a strait drift machine all is good) Post some pics if you go through with it I'll do the same.
albinobob is offline   Reply With Quote
Old 02-11-2009, 02:48 PM   #4
Nackers
On my 30min lunch break today I took a pipe that just happened to fit and this is what I did:
Cut it 12" Long
Drilled a 3/8" hole 4 1/4" from the end
Put a 3/8" steel rod in and tacked it for now
I don't know the ID of the pipe, but it slides over the handbrake lever with the leather still on it. It was a really tight fit so I didn't bother trying to actually mount it and decided to see if it would work.
Unfortunatly, it was raining today but I gave it a shot anyway. It worked really well, but I think that 12" is a bit too long. I was able to grab it fine and so long as I wasn't in first gear, had no problems with the gearshift being in the way. The worst part for now is that my handbrake is already sorta loose so when I pulled it, it seemed really sloppy.
I'm still trying to figure out a better way to mount it rather than just drilling a hole through the factory boot. I thought about stich welding a hose clamp on the end and using that as insurance to make sure it doesn't slide around. Even though, the way it is now, I just made sure to pull back and hold down and didn't have any problems. I'm just hesitant to permently mount this thing so I'm trying to make it easily removable for street driving.
I'm waiting for my project mu pads to show up and then once I put them in, I'll give an update.
BTW, its not pretty, but it works. I do plan on cleaning it up and painting it black.
Maybe if I get tired of this I might make a nicer one, but I doubt it. Though I would like to heat this thing up and give it a very slight bend away from the gearshift and slightly upwards, but idk.
Function > looks
Old 02-19-2009, 04:07 PM   #5
Nackers
So a little update before I install the project mu pads.
3rd gear + feint + handbrake = nice.
Found a dry area today that I previously had problems with the handbrake locking. Using my new handle, everything worked perfectly. I can't wait to try it out with the new pads installed. Hopefully it'll be this weekend. Anyway, I should have some details with that setup after the first midwest drift day at gateway. 240's running 3rd gear so I'm expecting top of 3rd or maybe 4th. Should make for some fun times.
Old 05-15-2009, 10:55 AM   #6
B.Young
When I started drifting I used to duct tape my ebrake button down, but the handle was still too far back to grab as fast as I wanted. I stripped the ebrake boot and plastic, then removed the button and other internals. the tooth that locks onto the gear is free floating now. I set the tooth back as far as possible, then drilled a hole where now when I put the cotterpin through it, it will hold the tooth away from the gear. Next I took a basic decent size flat tip screw driver and jammed it into the opening where the buton was. I duct taped the screwdriver to the body on the handle. Oh yeah that made a HUGE difference. After some adjusting of the ebrake cables, I was high speed longsliding no problem (for a while). This will work good if ur doing low speed parking lots and just having fun. The bad thing about the stock ebrake system in the Z is that it was never meant to stop a fast moving car. One night while practicing, I entered a longslide at 80+ and when I pulled the ebrake handle a loud popping and clinking noise emitted from the driver rear wheel. I found that the pin that holds the ebrake pad to the slit in the dustplate was ripped out! the metal was fanned out and broken. We tried using other drum brake kits and bolting the pad in place with the slack it needs for operation, but it never was the same. I looked into the Project Mu 350z shoes, but it doesn't solve the issue of how its mounted. The pins will rip out again. After talking with Chris Forsberg and doing some research, the second caliber for the ebrake alone was the best solution. A custom hydraulic handbrake with its own calipers is what all the pros went to after going through the same thing I did. We are in the process of building the Custom Hydraulic handbrake system now. Sorry for the long reply. I hope this helps.
B.Young is offline   Reply With Quote
Old 05-18-2009, 01:35 AM   #7
Nackers
Way ahead of you.
Just a staging brake, but say what you want, the handbrake being used while braking isn't a big deal.
Thanks for trying to get back to me on this. After I had to weld my adjustment bolt back on I said **** bothering with the factory system unless its parking the car. So my project Mu's are doing a good job of that and my endless pads are taking care of the important things:
Old 05-18-2009, 03:28 AM   #8
Royal_T
Royal_T's Avatar
Points: 4,087, Level: 40
Points: 4,087, Level: 40 Points: 4,087, Level: 40 Points: 4,087, Level: 40
Today's Activity: 5.0%
Today's Activity: 5.0% Today's Activity: 5.0% Today's Activity: 5.0%
^^ Nice, once I saw this thread I was thinking about Hydraulic handbrake systems, and was going to suggest this.
Nice job with yours, do you have any more pics and what set-up did you go with?
__________________
DPE Wheels Sales Rep.. edafe@dpe-wheels.com
Royal_T is offline   Reply With Quote
Old 05-18-2009, 08:48 AM   #9
Nackers
Old 05-18-2009, 10:11 AM   #10
Z33_SPL
Z33_SPL's Avatar
Quote:
Originally Posted by Nackers View Post
Good stuff man. Hope you don't mind asking, but how much did you pay for everything. Also, any issues when stepping on the brake pedal and pulling on the hydro brake?
Z33_SPL is offline   Reply With Quote
Old 05-18-2009, 11:22 AM   #11
Royal_T
Royal_T's Avatar
Nackers,
Nice, really good write up. Ok but how did you make the ball shifter handle? Over all a really clean look..good job
__________________
Old 05-18-2009, 11:37 AM   #12
JasonZ-YA
JasonZ-YA's Avatar
Points: 30,508, Level: 100
Points: 30,508, Level: 100 Points: 30,508, Level: 100 Points: 30,508, Level: 100
Today's Activity: 3.2%
Today's Activity: 3.2% Today's Activity: 3.2% Today's Activity: 3.2%
Send a message via AIM to JasonZ-YA Send a message via Yahoo to JasonZ-YA
Awesome Nackers........that was my thoughts exactly on where to "tie in" in my drift 101 sticky (post 34)........glad to see it out there and working.........cool...
The connections you made with the two tee's are in the FRONT passenger wheel wheel right?
-J
__________________
04 PPW Touring - My favorite mod is my short Dodge Avenger antenna
JasonZ-YA is offline   Reply With Quote
Old 05-18-2009, 11:41 AM   #13
JasonZ-YA
JasonZ-YA's Avatar
ahh. i get how you did it now...that kills your abs from working properly though...
then again, on a drift only car that doesn't matter....just some FYI...
oh and i love your e-brake handle placement coming up through the shifter boot.......awesome!!
-J
__________________
Old 05-18-2009, 11:49 AM   #14
JasonZ-YA
JasonZ-YA's Avatar
See it looks like you tied into connection p/n ( 46313 ) on the passenger side, by makeing two lines into one, you killed ABS. (which is all good if your okay with that).
This set up should allow for ABS to be retained as the willwood master res "is" a master and doesn't use the cars master for pressure.
http://my350z.com/forum/drift/399634...ml#post6587128
-J
__________________
Old 05-20-2009, 07:35 AM   #15
JasonZ-YA
JasonZ-YA's Avatar
Here we go...
updated from my post 34 on drifting 101 thread....
-J
__________________
Old 05-22-2009, 02:55 PM   #16
Nackers
ABS was still working before I disconnected the plug. It didn't work when I pulled the handbrake but in the wet with a hard foot brake it was still working. Same with the VDC.
All in all it cost around $200 with the cnc staging brake, lines, and fittings. Just a lot of work.
Old 05-23-2009, 05:38 AM   #17
JasonZ-YA
JasonZ-YA's Avatar
^ ya, the ABS has 4 dedicated lines going - one to each wheel, it will not work properly on the road with two lines Tee'd to one - then to hand brake - then back tee'd to the two lines back to the rear......that means, coming out of the ABS block they are NO LONGER 4 dedicated lines? get it??
with your hydro set up, your ABS WILL NOT work correctly. The Z has cross braking - activated by ABS.
With this set up, if your daily driving and you come to a sudden braking situation, only ONE of your front wheels will activate during ABS and your car will jerk you to one side.
be aware....
oh, and read this thread, and my post/replies on there - This guy has a very similar set up as you............i know how it was installed - http://my350z.com/forum/brakes-and-s...too-early.html
-J
__________________
Old 05-23-2009, 08:12 AM   #18
Nackers
Oh I get ya. I didn't lock it very long but noticed the pedal jerk and the abs light.
Old 05-25-2009, 08:49 PM   #19
JasonZ-YA
JasonZ-YA's Avatar
Next time your at the track, try hard braking and engaging the abs and with light hand pressure on the steering wheel see how the car pulls with ONE front wheel engaging?? might be good to know so you can know how to react....
Do you drive with ABS one? daily drive the car or only track?? Or do you pull the ABS fuses and disable when on the road? Cause that can be dangerous like Kevin8086 learned.....
-J
__________________
Old 05-26-2009, 08:21 PM   #20
Nackers
I've been driving with the "Big grey plug" disconnected since the last event. I've never had abs before so I'm pretty used to it, though I know abs is better for daily driving.
I'll reconnect it and give it a test run on a closed course.
My350Z
350 Z
Paid Advertisement
Tags
240sx, 350z, boot, brake, drift, hand, handbrake, handle, installation, lever, modifications, nissan, stock, style, tips
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
