Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
Hydro ebrake writeup
Old 02-26-2012, 10:03 AM
SLIdEwAyZ25
SLIdEwAyZ25's Avatar
Originally Posted by nismo_ninja
I'm in the process of this right now and have a ? For anyone who can help I have a touring so my block is different (abs) than the one pictured two of my lines come out the side and two on the top with that said there isn't enough room to switch the lines around I know I could extend the factory lines and make it work but my question is.....
If I take the secondary side plumb it into the handle and back to a tee with the two rear lines hooked up and take the primary and run it to a separate tee aswell but have the fronts hooked up to it effectivelyeliminating the factory abs box will this cause me any other issues? Thanks
I have they same issue did you ever figure it out??
Old 02-26-2012, 04:22 PM
nismo_ninja
nismo_ninja's Avatar
I just took the secondary line off the ms and ran it to the handle. Then from the handle to the abs block, I had to swap the lines at the block so the secondary was just the rear and the front was on the primary line. Then i disconnected the abs and that works I heard that bypassing it does too but I haven't done it yet. Hope that helps
Old 02-26-2012, 04:24 PM
nismo_ninja
BTW if you eliminate the abs block completely you'll have no speedo
Old 02-27-2012, 12:58 PM
SLIdEwAyZ25
Lol no speedo would be badd for street car. I appreciate the fast response. I'm going to have to get on this before the next event.
Old 02-27-2012, 01:26 PM
Royal_T
Royal_T's Avatar
who needs speedo.....lol
Old 02-27-2012, 02:02 PM
nismo_ninja
did you pick up one of the pbm max angle kits yet? if so what are you doing for front wheels? size 0ffset spacers ect?
Old 02-28-2012, 05:22 AM
Royal_T
Royal_T's Avatar
Yes I did pick up the PBM SAK, just waiting on the tie rods from them. As far as wheel specs go. I have been talking with Dan at PBM about whats needed to fit to achieve full lock. He was stating that Ryan Kado placed a 17x10+15 on the front for mock up and needed about a -10 for it to clear. With that being said he went on saying that anything with a -8 will be good, rather you go with a 18x9.5 -8 or -10 or a 18x10 -8.. Me myself is going with a either a 18x9.5 -18 or a 18x10 -10...
Hope that helps some..
Old 02-28-2012, 11:41 AM
nismo_ninja
I talked to them after purchasing and receiving my kit and they told me to get s14 tie rods... So are they sending you the pbm rods included in the kit or will you have to buy them separate? I have to say I was kinda disappointed they said to use s14 rods...and not something like ours are coming out soon...
Old 02-28-2012, 12:54 PM
Royal_T
Royal_T's Avatar
Well I am in the same boat as you... I will have to use the S14 rods.. but they are working on a set for us. Wish it was already done, but rods are not that expensive..
Old 02-28-2012, 02:21 PM
nismo_ninja
Word... Your z is dope man.
Old 05-21-2012, 07:10 PM
Nackers
Nackers's Avatar
I'm using Z33 tein inners on my setup. I haven't experienced any issue.
Also, like I said elsewhere, I'm running 18x9.5 -1 and do have a bit of rubbing on the inner fender at full lock. I don't mind that though for now.
Old 05-23-2012, 08:47 AM
Royal_T
Royal_T's Avatar
Thanks for the info Nackers,, They were telling me that you can use the Z33 inners but have more adjustablity with the S14 inners. But glad to see you are not running into any major issues..
Old 07-14-2012, 10:49 AM
chucks_1st_z
chucks_1st_z's Avatar
how long did it take you guys to bleed yours? i just have to run my lines to the wheel well and bleed them. i do have a power bleeder that i will be using. im just wondering cause people are telling me cause i have tcs it will take longer. ive got an 06 enthusiast by the way.
Old 07-14-2012, 11:14 AM
nismo_ninja
I had to bleed mine a second time but it just takes a little longer than normal because there is just a little more line if you do it the way I did...
Old 07-14-2012, 11:54 AM
chucks_1st_z
im assuming that you used a power bleeder or did it manually? i plan on bench bleeding it first to save from having to fill it by bleeding. we talking maybe a couple hours or not that long? im trying to get it done before a local event tomorrow. trying to see if i can get it done before then or not
Old 07-14-2012, 12:54 PM
Johnnyone
Johnnyone's Avatar
It's pRetty strait fwd to bench bleed but as u know with cars anything can go wrong. I would wait till after the event.
Old 07-14-2012, 01:37 PM
chucks_1st_z
ya i guess you are right. better safe than sorry. at least i can go and show my car. well thanks for the input guys. ill be back if i have any problems or questions
Old 10-17-2012, 06:30 PM
  #38
hybridcmk
hybridcmk's Avatar
do you know what size diameter the lines were? I order a asd ebrake and i need to get lines for it. does it matter if its steel braided or rubber?
Old 10-17-2012, 06:37 PM
  #39
GLRacing
GLRacing's Avatar
This is cool
definitely something i would do if i were to get serious with drifting
Old 10-18-2012, 07:43 PM
  #40
theianmcdougall
theianmcdougall's Avatar
i got stainless steel lines from summer racing.
2 1x10 to 3 an fittings
http://www.summitracing.com/parts/EAR-592032ERL
2 72" 3 an lines
http://www.summitracing.com/parts/EAR-63010172ERL
hooked up to my PBM ebrake, works gangsta
Quick Reply: Hydro ebrake writeup
