Welded Diff Oil Recommendation?
I just had my open diff plate welded at PBM and I'm deciding on an oil to pour into it. The car is used 50/50 between street and drift miles. I'm looking for an oil that will happily survive the high temps found in a Z33 diff while lubricating the ring and pinion well. Being as it's not an LSD, friction modifiers are irrelevant. This means I want an open diff fluid. Very few people drive open diff Z's on tracks etc. so it's hard to find a well-tested open diff oil.
I see that Redline makes a 75W90NS gear oil, which is the same as the 75W90, but with no friction modifiers. In my searches I found many people liked Motul 300 as well.
What would you recommend? Bonus points for opinions from people who run welded diffs.
General & DIY Moderator
I used to run a welded R200 diff in my GT5 Nissan racecar. I found a synthetic 75-90W handled the high heat better than a conventional oil. In my case, Valvoline 75-90W synthetic worked well (particularly as they were a sponsor) and I would swap it out every other race.
Yes- GT5 was a small-bore sedan class that transitioned to GT Lights (GTL) several tears ago. I currently run T3 in a 350Z, but don't use a welded diff in that class.
