Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
How to equip my Z33 to drift?
Old 02-15-2015, 07:08 PM
blizzdr
blizzdr's Avatar
Smile How to equip my Z33 to drift?
Hi guys, I just wanna know what i have to do for drift, right now im starting with the tires and wheels, and the next one will be the suspenssion overcoils, what i have to do in the next ones? Please, plz guys help me
Old 02-15-2015, 07:18 PM
Conway_160
Conway_160's Avatar
Just go do it, you will be fine.
Old 02-16-2015, 06:53 AM
waldo36
waldo36's Avatar
You'll need this to help with sideways wind turbulence. Those smaller fins in the middle help keep the rear end from sliding too far out by providing just enough air resistance and downforce.
http://www.bodykits.com/Chargespeed/...2GTRWC/845011/
Old 02-16-2015, 07:59 AM
92K1500
92K1500's Avatar
After the wing you'll want to pull the weak VQ engine out and swap it for a supercharged LS and a T56.
Old 02-16-2015, 08:19 AM
BH!
BH!'s Avatar
For serious though.
Coilovers,
LSD (hope you have a VLSD already)
Camber arms, Toe arms
Steering rack spacers
a new clutch and flywheel after you blow yours up
pretty simple.
Old 02-16-2015, 09:23 AM
mr. sparco
mr. sparco's Avatar
Driver mod > car mods.
driftsucky (09-03-2015)
Old 02-16-2015, 01:58 PM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
Wheels , extra tires , then a rollbar, seat and harness. Once you have that stuff, time for a diff.
Thru the above process, keep hitting drift days.
Old 02-16-2015, 03:58 PM
RobPhoboS
RobPhoboS's Avatar
Maintain and service the car properly first.
Then get lessons at a track with a decent tutor.
Lastly, stop typing in stupid large fonts as nobody else does.
HAVE FUN !
Old 02-17-2015, 04:33 AM
driftsucky
driftsucky's Avatar
Sit in the seat. Turn the car on. Put the car in forward gear. Drive.
Old 02-20-2015, 05:46 AM
OhioStyles
OhioStyles's Avatar
smh guys. seriously? all u have to do is disable the VDC system. thats it. go out, have fun. if you still like it then start throwing money at it.
Old 03-05-2015, 02:01 PM
BH!
BH!'s Avatar
Here's me. No power mods, just suspension, a good alignment, a bucket seat, and the VDC 50 amp fuse removed.
DO NOT TRY WITH VDC DISABLED, yaw control will still be active and try to correct you causing massive unpredictable understeer. Pull the fuse. The button won't do the trick.
Album: http://imgur.com/a/1LJmD
The following 2 users liked this post by BH!:
driftsucky (09-03-2015), ohisofly (08-31-2021)
Old 03-05-2015, 11:03 PM
350z-Helsinki
350z-Helsinki's Avatar
You don't need much. You can easily drift a stock Z. I would start with sway bars to control excessive roll and remove understeer. Then maybe coilovers and lsd. When you start to get a hang of it tein inner and outer rod ends with a spacer to increase steering angle. My car is supercharged and it made it easier to hold the drift. However NA engine mods should be the last thing to consider.
It helps if you get some tires that aren't too grippy. Some 225 section tires worked well for me when I was na. It helps you to maintain drift, reduces speed and makes things easier. Also cheap tires are good for your budget.
Just get out there and have fun!!
Old 04-13-2015, 11:46 AM
bluz370
bluz370's Avatar
I took my 350z drifting for the first time this weekend, I have coilovers and a welded diff. That is it.. The car ran flawlessly and I had loads of fun. All you really need is a few sets of tires and seat time.. then you just kind of assess things as you want more out of the car.
Old 09-02-2015, 08:38 AM
nichols
nichols's Avatar
coilovers, welded diff or 2 way, remove the vdc or unplug the vdc system (keeps brake lights), cut down bumpstops and go sliding. arms for better alignment, seat, ebrake, and wheel should follow but the z slides pretty easily stock. also throw some angle mods when you can too. tie rods or steering rack spacers do a pretty good amount of angle for cheap
Perches666 (02-03-2016)
08-06-2021 06:19 AM
sales@czp
09-23-2019 03:30 PM
11-01-2015 05:25 PM
Quick Reply: How to equip my Z33 to drift?
