ZSpeed CMAK Clutch Movement Alteration Kit CSC Delete
Old 10-14-2016, 10:20 AM
ZSpeedPerformance
Vendor - Former Vendor
ZSpeedPerformance's Avatar
Bump! In Stock! Ships Today!
ZSpeedPerformance is offline
Old 10-25-2016, 07:18 AM
ZSpeedPerformance
Bump!
Old 12-06-2016, 06:10 AM
ZSpeedPerformance
In Stock!
Old 01-23-2017, 05:26 AM
ZSpeedPerformance
Bump! Fix your Z's clutch once and for all!
Old 06-02-2017, 10:08 AM
ZSpeedPerformance
Bump!
Old 06-06-2017, 08:40 AM
ZSpeedPerformance
Bump!
Old 06-08-2017, 09:21 PM
SD_Nismo
SD_Nismo's Avatar
Still in stock? Is it necessary to purchase an aftermarket Master Cylinder or does it just require a new OEM??
SD_Nismo is offline
Old 06-09-2017, 05:30 AM
ZSpeedPerformance
In Stock, Only requires a master if yours is weak or failing. Not a bad idea to replace it while you have the system open. OE or our wilwood both work fine with it.
Old 06-09-2017, 07:00 AM
SD_Nismo
SD_Nismo's Avatar
Awesome. Thanks for the reply. If this was ordered today, being Friday, whats the typical ETA for shipping?
SD_Nismo is offline
Old 06-09-2017, 07:31 AM
ZSpeedPerformance
We normally ship the same day as long as it's ordered by 3pm EST. Shipping to CA is normally 2-3 days USPS and 4-5 Days Fedex ground. We have Fedex express options on the website as well.
Old 06-23-2017, 10:19 PM
rugbyforlife
rugbyforlife's Avatar
Default Kit question
Was gonna see if I could get a price and if y'all offer this with a clutch kit? Thanks
rugbyforlife is offline
Old 06-26-2017, 07:06 AM
ZSpeedPerformance
CMAK is $449.
You can find our clutch kits or by itself here.
http://www.zspeedperformance.com/ZSp...ories_c482.htm
South Bend kits have the option to add it in the packs.
http://www.zspeedperformance.com/Sou...ywheel_c33.htm
Old 07-14-2017, 10:54 AM
ZSpeedPerformance
Bumped!!!!
Old 09-08-2017, 07:35 AM
ZSpeedPerformance
Bump!
Old 09-22-2017, 10:28 AM
ZSpeedPerformance
Bump! Yes this fits your NISMO!
Old 10-04-2017, 06:36 AM
ukraini9mofo
ukraini9mofo's Avatar
I am planning on going with luK clutch and flywheel (stock dual mass style). I read somewhere that this kit might only work with beefed up clutches and single mass flywheels? Just wanted to check.
ukraini9mofo is offline
Old 10-04-2017, 06:41 AM
ZSpeedPerformance
It works with any single disk clutch/flywheel combo, Only ones it needs adapting to is if you are using a Twin or Triple disk type race clutch
Old 10-13-2017, 06:25 AM
  #38
ZSpeedPerformance
Bump!
Old 11-03-2017, 05:32 AM
  #39
ZSpeedPerformance
Bump!
Old 11-13-2017, 12:09 PM
  #40
ZSpeedPerformance
Bump!
Quick Reply: ZSpeed CMAK Clutch Movement Alteration Kit CSC Delete
