FS: ZSpeed Wilwood "V2" HD Clutch Master Cylinder Kits Now Available @ ZSpeed !
The OEM 350Z master cylinder is known to fail over time and cause poor clutch release or cause the pedal to drop half way to the floor or stick to the floor completely.
Our all new Wilwood V2 Updated kit is Stronger, Better and longer lasting + It is rebuildable!
Improved Piston Design makes this kit more durable, offers a more accurate pedal feel and makes bleeding a snap!
Available for 2003-2006 DE models as well as 2007-2008 HR Models!
2003-2006 350Z, 2003-2007 G35 Coupe, 2003-2006 G35 Sedan
2007-2008 Model Years HR
This will cure the pedal drop issue these cars are know for esp when upgrading to a aftermarket clutch and also makes the system much easier to bleed due to its higher quality design.
Comes complete with PVC Coated braided stainless steel hose assy.
Only mod needed to install is to trim the stock reservoir fluid hose.
Professional installation recommended, Proper clutch pedal/master cylinder rod adjustment is required after installation.
