make the 350z more fun
Guest
Posts: n/a
im wondering how to make the 350z into a more tossable car, im looking for mods that will make it corner with no body roll, and feel alot more balanced, i want my z to be more of a race car than a street car, i dont care about comfort i want performance
on
Re: make the 350z more fun
on
um.. have you been driving your 350Z lately? I have thrown the damn thing into turns and it eats'em up like chicken katsu.
Get some better tires.
S-03's
And uh BTW - there is no substitute for less weight... only less weight
S-03's
on
thow on a bigger rear sway bar and turn off vdc... butt should slide out more....
or even better bigger rear sway bar. Kaaz or somesort of mechanical LSD and lots more torque.... then you'll be sliding in no time... just be carefull
my old car had
apex N1 pro coilovers, cusco (solid mount) tension rods, ST sway bars, pillow mounts, kaaz lsd. The thing turned into a go-kart, very uncomfortable but handled unbelievably
my old car had
on
Strip the interior. Remove the A/C. Remove the stereo. Install some 6lb carbon fibre racing shells. Get some BFG G Force T/A's. Get the Nismo or Tein suspension kit.
on
do a search for dwnshifts posts. he reported the weights of the whole interior after having stripped it.. i believe he said that the whole interior carpet seats plastic all of it was only like 150 pounds or so
not much gains to be had here...... however.. the exhuast and cats weight quite a bit.. exhuast is like 57 pounds an dhte cats are probably 10-15 pounds a piece
the wheels are heavy, same w/ the stereo take it out and the speakers ,, move battery and whatever use you can to the back.. but really i dont think your gonna be losing much weight.. i think the best thing you can do is try to balance it out more and move the weight to better locations.
take a look at the new cusco bars commin out and the tein suspension.. get some lightweight wheels and some grippy rubber and i think youd be fairly set to go
TIRES!!!!!!!!!!!
If you want to get get closer to 1G and truely want a race car style setup then put some R compound tires on there. Next up, suspension and a strong enough LSD to stand up to all that new found traction. Also, keep your wheels light, no 19" Chrome BLING BLING stuff. 17's or 18's only. Go coilovers and maybe stiffer sway bars and a nice agressive alignment. You'll be stuck like glue. Oh and don't forget brakes.
