High Clutch? want to lower your clutch engagement point? - Page 10 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 11-27-2005, 03:22 PM   #181
En-GLaived
Hmm im going to try this tommorow as I am sick of how this clutch works but I am confused on a few parts, are there three things you can adjust? The clutch engagement point, the clutch height, and the cruise control thingie, right? I got under there and looked but I am confused on this part (as to how many things I need to fiddle with)
En-GLaived is offline   Reply With Quote
Old 11-27-2005, 09:10 PM   #182
rolling
rolling's Avatar
think ill try this thanks for info!!!!!
rolling is offline   Reply With Quote
Old 11-28-2005, 03:31 AM   #183
Havok_RLS2
Havok_RLS2's Avatar
Just FYI. I've already performed this mod about a month ago. I personally would advise against it. Too much adjustment might cause you to burn out the clutch prematurely. After I performed this mod I tested it by attempting perform a few burn-outs. The clutch engagment seems to have just been enough to allow me to drive with no problem at all but when attempting to any type of aggresive launches resulted in major clutch slipping. I rest mine back to stock and dont have that problem anymore.
Again... JMHO
Havok_RLS2 is offline   Reply With Quote
Old 11-28-2005, 05:56 AM   #184
En-GLaived
Quote:
Again... JMHO
How many times did you turn the rod?
Old 11-29-2005, 01:36 PM   #185
gsazabi
gsazabi's Avatar
Just performed the adjustment now.
Strangely though, my pedals won't go in. It's still the same height as
stock.
Only time I did manage to get in inward was when I turned the rod 4+
times, but that also made the pedal stick. It would come out just before
it makes contact with cruise control switch, and the rest of it
i have to manually pull it out.
Does that mean I have to adjust it higher? or just adjust the cruise control
button lower so that it can make full contact where the pedal stops coming up?
Any feedback would be appreciated.
gsazabi is offline   Reply With Quote
Old 12-04-2005, 01:10 PM   #186
rolling
rolling's Avatar
subscribing
Old 12-05-2005, 12:10 PM   #187
gsazabi
gsazabi's Avatar
Damn, after I performed the mod a couple of days ago, I realized that
my pedal isn't working normal.
I tried to put it back to stock position, but I forgot to mark it and I couldn't
get it back to stock position.
I ended up taking it to the dealer where they installed my clutch, but even they
couldn't get it back to what it was.
So far I've tried adjusting it countless times, but with no luck.
The pedal feels like it's back to normal, but I can tell the spring isn't.
Damn I don't know what to do...I should've never touched it.
Old 12-05-2005, 01:29 PM   #188
350Zenophile
350Zenophile's Avatar
Quote:
Originally Posted by gsazabi
The pedal feels like it's back to normal, but I can tell the spring isn't. Damn I don't know what to do...I should've never touched it.
According to the service manual, pedal adjustment isn't even a possibile cause for a spongy clutch pedal. Our cars have a hydraulic clutch, and if you've had yours replaced recently, the installer may have not bled the lines properly (see attached).
Now, it does use a spring to return the pedal to its proper height. If that is what you are refering to then you just need to continue to raise the pedal enough until it can do so on its own. See pages 5-6, adjusting pedal height.
350Zenophile is offline   Reply With Quote
Old 12-07-2005, 01:11 AM   #189
kbiz
kbiz's Avatar
OK so I've read through this whole thread and I adjusted my clutch pedal... and yes it's so much better. But it sounds like a lot of people are having problems down the road. If the clutch is self adjusting and people are reporting their pedals returning to the original positions over time that can only mean one of two things: The clutch has worn a lot... or... the clutch, being self adjusting, has compensated for the difference. Both are bad. If the clutch adjusted itself, it's unlikely you'll be able to adjust your clutch pedal back... much like drum brakes... they can adjust themselves tighter but you have to take them apart to loosen them up again. I don't know this for a fact but it would explain some of the problems people seem to have. Are there a ton of people who have had no problems at all??? I don't mean no problems over the last couple months, but no problems for a while. If Nissan techs are saying there's no adjustments POSSIBLE then what are they saying if there really is. This can't be a secret...
It seems like a simple mod... just reducing the amount of pedal travel... so the same could be accomplished by never depressing the clutch pedal all the way down or putting a piece of wood behind the pedal (just as examples). So would these things cause the clutch to come out of alignment? It doesn't seem that complicated.
Just wondering how people have been doing since making this adjustment.
kbiz is offline   Reply With Quote
Old 12-07-2005, 07:52 AM   #190
gsazabi
gsazabi's Avatar
Well thanks for your input 350Zenophile.
However, I believe my pedal height is pretty close to where it should be now,
but still my spring doesn't feel right.
Another big problem I'm having is that my throttle response is way less.
And my car isn't as loud (And no, I'm not being paranoid). Last time I had this problem was when my clutch
was worn
Old 12-07-2005, 11:17 AM   #191
350Zenophile
was worn
Do your engine rpms rise more than they should when you accelerate? if so, then you clutch is shot. I'm guessing that's what you mean when you say "my throttle response is way less."
Sounds like you just may be rough on your clutch. How many miles did you put on the last one before it went compared with this one?
Old 12-07-2005, 11:29 AM   #192
jct
For almost one year, I have not had any problems (or "self adjustment") on my early-'04. (Early on, I did adjust it several times to get it where I wanted it.)
jct is offline   Reply With Quote
Old 12-07-2005, 12:18 PM   #193
NTRIGUE
NTRIGUE's Avatar
Quote:
04.5 and no problems for approaching two years!
You know what this is a perfect example of...everyone unhappy with the performance is going to immediately claim distress on the forum. Those who love it, OTOH, are going to be out enjoying a much better drive!
NTRIGUE is offline   Reply With Quote
Old 12-07-2005, 12:23 PM   #194
kbiz
kbiz's Avatar
Rock On!!! I love the clutch adjustment! It feels like the right answer...
I couldn't see any reason if you adjust it within reason that there should be any problems...
My favorite mod yet!!!
Old 12-08-2005, 11:32 PM   #195
Z_Driver
Master
Z_Driver's Avatar
I actually, went more than what most people are talking about here. Two things I did that is different. Mod originallly done 12-03.
1) Adjusted it so it would engage 1" off of the floor. Maybe 8 turns.
2) That brought the pedal down and off the stop so I added a return spring to pull it all the way back up to the stop. That made 1" of free play on the top.
I tested this by checking to make sure that the clutch disengaged completely. It wouldn't start to creep forwar until about 1" off the floor instead of the 3" that was stock.
Then I checked to make sure it wasn't causing the throwout bearing to be running on the fingers of the clutch. No feel of clutch fingers or slipage until 1" from the top.
Now with 15K on the adjustment. I have a smooth clutch, adjustment hasn't changed. I haven't smelled any burning friction material and it still lights them up in 1st, 2nd, get a good burn in 3rd. 4th gear chirp can only be accomplished if I dis-weight a tire but I can get one speed shifting into 4th as well in the right conditions.
I don't think you'll have any problems with longevity. However, if this thing burns out, I'm going high performance with a lightened flywheel anyways.
No worries, if it was going to slip it would have done it by now. I hit those gears pretty darn hard at times.
Enjoy the ride.
Z_Driver is offline   Reply With Quote
Old 12-08-2005, 11:55 PM   #196
kbiz
kbiz's Avatar
Enjoy the ride.
Very cool... I didn't go that agressive, yet... but from the factory setting anything is amazing. 1st, 2nd and 3rd are a blast!! How did you test for bearing contact on the fingers? Did you do the rolling with the car off... or putting it in gear and then out, depressing clutch pedal, releasing and putting back in gear?? I love the fact that I can soooo easily control wheel spin now. I can predictably launch without thinking twice... it took me all of a day to get used to it after almost 3 years. Freakin' wheel chirp!! I'm lovin it!
Old 12-09-2005, 01:13 AM   #197
Z_Driver
Master
Z_Driver's Avatar
Well to test bearing contact to the pressure plate fingers. You can actually feel it when you press on the pedal lightly while the motor is running in neutral. You can also hear it buzz the bearing. If you can't feel a difference you might not have enough play in there and are slipping the clutch (prob not) a bit of spinning that bearing when it shouldn't be spinning (really wears fast)
On the release side, while the car is running and at a standstill, you should be able to put the clutch in and shift through all the gears easily. If not, turn off the car and see if you can shift through the gears easily. If so, then you need to adjust it to disengage the clutch a little more.
It takes some playing with. However, there is a lot of a room for play in the Z so it's not so bad.
In my Formula it has to be just right or your not disengaging all the way and syncros start to go from the pressures your putting on them while shifting. Or your not engaging all the way/spinning or wearing that throw out bearing super fast.
Now the only other thing you have to look out for is over engagement. That is where you are disengaging the pressure plate so much off of the clutch disc that it is binding the hydraulic bearing/shift fork in the bell housing. That's not common and isn't a problem generally with our cars unless an aftermarket Clutch Cylinder has been installed.
Old 12-09-2005, 12:03 PM   #198
kbiz
kbiz's Avatar
Super Sweet!!! Thanks for the info... I'm gonna be playin with that some more today.
Old 12-18-2005, 07:01 PM   #199
meshugineh
meshugineh's Avatar
I'm new to driving manual but seem to have way more trouble on my Z then on any other car I've learned on.
This mod looks like it could be the answer but at the same point don't want to
screw up a delicate and important part of the car. I read 10 pages of commentary on this post, obviously my clutch is not operating as smoothly as I would like and it worries me.
Is this mod too risky for someone new to manual cars?
meshugineh is offline   Reply With Quote
Old 01-16-2006, 03:27 PM   #200
eat rice z33
eat rice z33's Avatar
Ok a little more information for this thread, i initially adjusted my clutch a while back, it was very short!! but perfect so when i disengaged my clutch it would fully disengage!! Now after 2 month, i was shocked to feel my clutch pedle at its "stock height" I had the largest WTF face!! Now i just adjusted it for the second time, however this time i adjusted it more aggresivly and now the cruise control switch wont reach the bump ****, I think im gonna have to glue another bump patch onto the stocker!! Anyone have any other ideas?
eat rice z33 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Autocross Brake Pads hajwoj Autocross/Road 27 11-01-2015 05:25 PM
Up to Date Coilover Review/Recommendations for a balance of track/drift/slam Lt_Ballzacki Brakes & Suspension 13 10-24-2015 08:56 AM
Oil change with aftermarket oil cooler XM 1 Engine & Drivetrain 11 10-01-2015 10:44 PM
Enjuku Racing - SPEC Stage 1 Clutch Kit for Nissan 350Z EnjukuRacing Engine 0 09-30-2015 06:55 AM
Tags
350z, alfa, clevis, clutch, engagement, high, hot, lower, pedal, pin, point, porsche, romeo, soft, spongy, spyder
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
