High Clutch? want to lower your clutch engagement point?
#381
on
Well after try to adjust the clutch about 4 or 5 times my pin and nut are stripped. When I get it to a normal clutch push and release everything is fine but third gear grinds for the most part. When I get it to where all gears are fine and 3rd doesnt grind the pedal is mushy, doesnt always return properly and then self adjusts. So frustrated.
#382
on
I just did the adjustment on my nismo yesterday. Works great. I didnt count the turns or mark it, but my guess is about 3. Then re adjusted the cruise switch. The clutch pedal only has about a 1/4" of free play up top, but after its warm it seems to fully come up all the way when im off it. Engagement is about an inch off the floor or so. No movement in 1st gear with the clutch floored. It seems to start to disengage about and inch and a half below full up. I should take a look at how many threads i have showing tomorrow.
Also of curiosity, how many threads should be showing in the OEM position (is the pic on the first page OEM height yet?) or how far was the OEM clutch height off the firewall? Like i said I didnt count the turns cause, i started adjusting the clutch when all hell started breaking loose weatherwise. So i just finished up and gave it a quick test before the skies opened up.
#383
on
I've just done the adjustment, and the new engagement point is just right. I do have one question though -- while driving, I have tried nestling my foot on the clutch pedal to feel for any differences, and the vibration is much more prevalent compared to stock.
My clutch pedal is about .25" lower than the brake pedal. Are any of you experiencing similar results? The clutch engages just fine, with no stalling whatsoever.
#384
on
I returned mine back to stock. The second day out with the adjustment, the clutch felt....a little strange on engagement. Now its fine again.
Just gonna get do a JWT flywheel/clutch when i get the chance.
#387
on
Not sure if i'm the only one but after installing my new JWT combo, I noticed the clutch engaged when put like 1/4 inch off the floor and after reading this my friend did what this post said cause to me the car was undriveable cause there was like inch's of play before the clutch would engage and disengage. We did this mod and I was able to drive it perfectly for about a week, then I took at trip roughly 300 miles to a huge car show and noticed when i pushed the pedal in and let it come back out it did so but if i put my foot just under the pedal i could move it up a little higher with my foot like the pedal wasn't returning to the original position.
Seems somehow the pedal adjustment actually had me with the clutch some what engaged all the time! When we stop half way down all i could smell was clutch and thought it was my friends car next to mine. Now 4200 miles later my clutch engages very high like it did before I replaced it.
Is there some way this mod could have done this?
I had the pedal re-adjusted back to where it is stock and it works fine just the clutch is very high and only has to be pushed down 1/4 the way to disengaged.
#388
on
^^^^ This is how my clutch pedal was after that adjustment before my trip but i was able to pull the pedal back up at .25" after ever time I pushed the pedal in.
#389
on
Being adjusted lower than the brake pedal is probably too much... I would suggest back it up more just on the safe side; not necessary back to stock position but to a point that it's still showing improvement, even if just a little
#392
on
I just got back from the infamous Tantrum's house. He helped me make the adjustment to my 2008 and it is a world of difference. It is so much more comfortable and fun to drive. The rest position of my foot is now so much more relaxed. Before it felt like my toe was parallel with my shin!
When I was first test driving the car (about a month ago) I had texted him saying that the clutch felt so long. It was like my Jeep Wrangler's clutch. He told me you can adjust it pretty easily, so I did not worry too much.
Before and after the adjustment, I took it out to Red Rock Canyon's scenic loop (lots of good turns and undulations) and it made flying through the gears so much easier.
Thanks Tantrum!
Thanks Tantrum!
#393
Just tried this mod after reading this thread...
Not sure if i have done this correctly as I am trying to lower the engagement point..
I turned 2 turns clockwise from lying on my back position..ended up seeing less thread on the rod..
Did not feel much of a difference, not sure if it is to do with the fact that I have an after market clutch and flywheel..
Also, my clutch pedal is abt. 1/4" higher then my brake pedal..is this normal and anyway to lower it to be at the same level as the brake?
#395
on
#397
on
You personally haven't had any problems (up to this point) but other people have. I just want to avoid premature clutch and synchro wear, so until there is some sort of proof it doesn't cause this, I'm avoiding this mod.
#399
on
I was told that when going to an aftermarket clutch, the engagement point has to be adjusted otherwise the clutch will not engage/disengage all the way and can lead to future problems, like in my case (a new slave cylinder). it's hard to say if the stock clutches are engaging properly since there is so much clutch play, the only way to find out, would be to have your cars tranny and clutch looked at by a performance shop. All I know is what I was told by S & R performance, only time will tell for sure.
#400
To test for disengagement, jack up the rear of your car and put it in first gear with the clutch pedal pushed down. If the clutch is dragging on the flywheel your tires will spin.
I don't think this "mod" is very useful long term because as the clutch wears the pedal rises back up to compensate. No doubt a lot of people are overdoing it with the adjustment if it's below the brake pedal. If you can lift up your pedal and it stays up in a higher position until you press it down again then you've probably lowered it too much.
