High Clutch? want to lower your clutch engagement point? - Page 6 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 08-08-2005, 07:29 AM   #101
TXSTYLE
Also...... I want to be able to use cruise-control for sure. What exactly needs to be done to retain it's use?
TXSTYLE is offline   Reply With Quote
Old 08-08-2005, 06:07 PM   #102
350Zenophile
350Zenophile's Avatar
I had to lay on my side or else I couldn't move my arms...uncomfortable, but once you get your bearings you're only down there for a bit.
As far as cruise control goes, you simply need to loosen the lock nut for the ASCD switch, screw it in a few turns and tighten it back up so that it is still triggered by the now lowered pedal.
350Zenophile is offline   Reply With Quote
Old 08-08-2005, 08:15 PM   #103
ActionJackson
ActionJackson's Avatar
Cool, gonna give this a try once I've broken in the car! Great pictures to go with the great write up & links.
ActionJackson is offline   Reply With Quote
Old 08-09-2005, 07:45 AM   #104
TXSTYLE
Arrow
Thanks bro. Man.... It is a pain in the azz to try and squeeze down there! I actually had mine a lil' too low and turned it back a full revolution. I haven't had a chance to drive since yesterday when we experienced torential down pours...
Old 08-09-2005, 12:01 PM   #105
Tackett
Tackett's Avatar
I did this and it rocks...but I cant seem to get my cruise to work again. Hope I didnt totally eff something up. Nice diagram btw 350Zenophile.
i guess Im going to just have to go outside in the bleeding heat and stand on my head in my car for another hour to figure this out.
Tackett is offline   Reply With Quote
Old 08-09-2005, 12:07 PM   #106
Tackett
Tackett's Avatar
Quote:
Originally Posted by TXSTYLE
Are you guys laying down on your backs and sliding into the car face up when you do this? I am 6' & 225lbs.
This is exactly what Im doing, and Im 6'6" and 265lbs. It aint fun, nor can I imagine it being very pretty.
Old 08-09-2005, 01:33 PM   #107
TXSTYLE
Lightbulb
Quote:
Damn...! I feel your pain bro. And did any of you drop any tools while working? And have to slide all the way the fok out...
Oh well... Nice mod nontheless.
Old 08-09-2005, 05:22 PM   #108
HokieZ
HokieZ's Avatar
One of the best things I've done to the car in 2+ years. Thanks for the excellent write-up. I set mine to engage just about 1/4 to 1/2 inch off the floor. Best thing I've noticed is it engages and shifts SOOOOO much smoother now. I've driven manuals for 15+ years and had no problems until this one but it seemed as if 25% of my 1-2 shifts were "jerky" for whatever reason. Went out and drove for 10 minutes or so and smooth as silk. It's like a having a new car!
HokieZ is offline   Reply With Quote
Old 08-11-2005, 03:18 PM   #109
HokieZ
HokieZ's Avatar
Adjusting the cruise control took me about 2 minutes. Look up for a white plastic piece and a little plunger that should be hitting it. Adjust the nut above that, thread the plunger down (I pushed on the clutch pedal a little to ensure it was down far enough) and re-tighten. It took me 5 minutes, and that included getting the car out to make sure it would set.
Still my favorite adjustment to the car.
Old 08-11-2005, 05:21 PM   #110
zrdude
zrdude's Avatar
Which mod are you guys performing? The one earlier in this thread, or the one in the other thread linked from this one? I'm confused which one I should try now?
zrdude is offline   Reply With Quote
Old 08-11-2005, 05:58 PM   #111
HokieZ
HokieZ's Avatar
Perhaps I'm being naive but it would seem to me as long as you can shift with the pedal depressed, it's fully disengaged. If you let out on the pedal and can push on it 1/2 or 1" in and it doesn't change the RPM's at a fixed RPM, the clutch is fully re-engaged.
Make sense?
Old 08-11-2005, 06:06 PM   #112
350Zenophile
Quote:
Both accomplish the same thing, I personally felt it would be more difficult to turn the clevis vs. the rod. In retrospect, I don't think I even needed to remove the dead pedal and kick plate.
Old 08-12-2005, 07:54 AM   #113
Zquicksilver
Zquicksilver's Avatar
I would remove the kick plate and dead pedal, it takes 1 min. to take both out. It allows for easy adjustment with the tools. I have a BASE, so no cruise control. I was able to do the fix with tweaking and driving around in 30 minutes. I didn't even know this was possible until I came across the thread. I never liked the slop caused by the cotter/PIN and long movement of the clutch. I probably should have read the directions verse glancing at the three pics. Once under there it all made sense I adjusted the bolt/actuator to lower the pedal flush with the brake at 1.5 turns. At that point I realized the return/stop had to be adjusted. This gave me the opportunity remove the slop caused by the pin, which I always hated. I left 1/2" of play before heavy vibration, which to me is the beginning of the disengagement of the clutch.
All I can say is I LOVE it. It seems it will mesh nicely with my style of driving, which is quick shifts and half-clutching. Before I would press the pedal a full 1.5" before it began to engage. Now I'm already there! This will keep me from occasionally grinding second when attempting blistering speeds off the line
Zquicksilver
Zquicksilver is offline   Reply With Quote
Old 08-12-2005, 08:07 AM   #114
MyZNeo
MyZNeo's Avatar
Made the adjustment in 20 minutes, took longer to get situated than to actually make the adjustment. Such sweeter shifts!
MyZNeo is offline   Reply With Quote
Old 08-12-2005, 08:22 AM   #115
DanOnTheRoad
DanOnTheRoad's Avatar
Hmm, my clutch pedal spring isn't bringing the pedal back to the top. Wondering if there's anyway to fix it. I'm only down 2 turns so it's not that low. Wonder if there's a way to adjust the spring tension.
DanOnTheRoad is offline   Reply With Quote
Old 08-12-2005, 08:55 AM   #116
zrdude
zrdude's Avatar
I just brought my car into the dealership today for a wheel speed sensor issue and spoke with the master tech. He said the only thing that is adjustable on the clutch is the freeplay, and that otherwise the clutch is self adjusting and will naturally get higher as the clutch wears. I mentioned the methods here for adjusting the clutch and he said that is definitely not recommended if you don't want to wear your clutch out prematurely. Could be b.s., but this guy has been really good to me in the past and seems knowledgable. Z Car Garage in San Jose also said there was very little room for clutch adjustment without running the risk of clutch wear. Anyone else have a connection w/a dealership and can confirm?
Old 08-12-2005, 12:26 PM   #117
CorruptedZ
I just did my clutch too ! The difference is unbeleivable. I suggest everyone to do the same. I haven't checked if the cruise control works or not. I'll do that later on and let you guys know if anything is wrong with it.
BIG THANKS TO TANTRUM for the tip
CorruptedZ is offline   Reply With Quote
Old 08-13-2005, 03:46 PM   #118
DanOnTheRoad
Hmm, I'm bringing mine in for it's first oil change soon. I'll ask then. Hopefully others can ask also. I'm still nervous about it. But damn, does it feel nice.
Old 08-13-2005, 07:22 PM   #119
vfr350
vfr350's Avatar
I went 1 full turn, was really easy since i already had a shortened 12mm. My cruise switch was still mechnically operational at that point. Test drive tomorrow...
vfr350 is offline   Reply With Quote
Old 08-14-2005, 01:00 AM   #120
PhxBlue
PhxBlue's Avatar
I did two turns on my 05 G since that seems to be the most common settling point here. Here is my question, is the clutch engagement or travel distance the same from the factory for both the G and the Z, or is the Z a bit shorter? Im just wondering if my 2 turns are equivalent to say 1.5 turns on the Z?
PhxBlue is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Autocross Brake Pads hajwoj Autocross/Road 27 11-01-2015 05:25 PM
Up to Date Coilover Review/Recommendations for a balance of track/drift/slam Lt_Ballzacki Brakes & Suspension 13 10-24-2015 08:56 AM
Oil change with aftermarket oil cooler XM 1 Engine & Drivetrain 11 10-01-2015 10:44 PM
Enjuku Racing - SPEC Stage 1 Clutch Kit for Nissan 350Z EnjukuRacing Engine 0 09-30-2015 06:55 AM
Tags
350z, alfa, clevis, clutch, engagement, high, hot, lower, pedal, pin, point, porsche, romeo, soft, spongy, spyder
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
