High Clutch? want to lower your clutch engagement point?
Old 09-08-2005, 05:24 AM
  #141
JLS2005
JLS2005's Avatar
WOW!!!, I can actaully drive my car now! I turned rod about 2 times, and now my clutch travel is only half a foot, compared to a foot before. I use to drive my car real jerky (My first manual), but now the shifts are smooth and precise! I highly recommend this mod for first time stick drivers. It's a hell of a difference! Also, I dont see how this can have any wear on the clutch plate down the road. When I did this adjustment, there was no rubbing, rattle, or any other noticeable signs of unwanted clutch engagement. Stop being paranoid, and drive your car for what it is.
Old 10-12-2005, 08:59 PM
  #142
Amiricanmade
Amiricanmade's Avatar
how long does it take to do this?
Old 10-12-2005, 09:15 PM
  #143
PhxBlue
PhxBlue's Avatar
Ehhhh 10-20 mins depending on whether or not you move the dead pedal and the plastic cover next to it.
Old 10-13-2005, 07:33 AM
  #144
dgz32
dgz32's Avatar
I did this about a month or so ago and loved it. Now it's back up where it was before. Is there something that auto-adjusts the engagement point back to factory? I know I haven't put that much wear on my clutch since then...
Dave
Old 10-13-2005, 07:54 AM
  #145
TXSTYLE
TXSTYLE's Avatar
I believe my has raised up/back as well. And yes I believe it is auto-adjusting.
Old 10-13-2005, 12:49 PM
  #146
Tackett
Tackett's Avatar
Well, my cruise control button has definatley moved...it wont work now, Im going to have to lower it back down.
Old 10-13-2005, 01:14 PM
  #147
undrgnd
undrgnd's Avatar
There is no way it can move. You had to 'physically' turn a yoke around a threaded rod and then tighten a lock nut. The one on my car is prevented from moving back by this arrangement. I don't know about wear on the clutch however...
Old 10-13-2005, 01:23 PM
  #148
350Zenophile
350Zenophile's Avatar
The cruise control button is adjustable. And I would fully expect the clutch pedal height to change as the clutch disk wears, but this should be minimal and is likely the reason why the factory pedal height is set so high to begin with from the factory.
Old 10-13-2005, 02:42 PM
  #149
Yellow Stealth
Yellow Stealth's Avatar
Well, you can overdo it for sure. I lowered my clutch so much that I could hardly get into first or second gear anymore with my foot on the clutch pedal. I raised it back some and now it is OK.
Old 10-14-2005, 05:35 AM
  #150
Art Vandaleigh
Art Vandaleigh's Avatar
Are you guys having the clutch pedal "stick" when you release it from the floor? The main problem i had besides the cruise control not working, was everytime i would shift, putting the pedal half way or two the floor, and releasing, the pedal would kinda stick and not return fully upright. This annoyed the hell outta me which is why im back to the stock height, but hate it. Its difficult to shift smoothly when the engagement point is so close to the top.
Old 10-14-2005, 05:57 AM
  #151
dgz32
dgz32's Avatar
All I can say is that when I set mine initally, it was perfect. Engaged right off the floor. Now, it's back to where it was before. And I turned the screw 4-5 times. Though it's actually been longer than a month, two to three or so...
I'll try adjusting it again this weekend.
Old 10-14-2005, 11:31 AM
  #152
TXSTYLE
TXSTYLE's Avatar
Old 10-15-2005, 12:33 PM
  #153
PapaTango
PapaTango's Avatar
Originally Posted by Badfish25
yeah I did this as soon as i saw this thread, I had to turn counter clockwise as well. (05 z) Clutch engages much nicer now. I Only turned it about 1 time counter clockwise and I couldn't even get it to go anymore.
Same here. '05's must be different. I turned mine clockwise (4x) and ended up with a horrible feeling clutch pedal. Very tight when starting to depress the pedal and then it just seems to fall to the floor. The clutch engagement was higher than before. Tried to return it to the original setting but the rod refuses to be turned back counterclockwise to the original position more than 1 or 2 turns. Looks like a trip to the dealer. Hope I can convince them the clutch just suddenly went out of adjustment.
When will I learn to leave well enough alone?
Old 10-15-2005, 02:16 PM
  #154
johnoppa
johnoppa's Avatar
I turned it in 2 turns and it feels perfect on my 03' and the crusie control works perfect. I think I'll leave it like this for a while.
Old 10-16-2005, 04:45 AM
  #155
NEWMXZ
NEWMXZ's Avatar
I did this last night and did a short test drive, much better. I was about to take it to the dealer to have them adjust the clutch down it was getting so bad, thanks for info.
Old 10-16-2005, 03:27 PM
  #156
DanOnTheRoad
DanOnTheRoad's Avatar
Seems everyone is different. I did this to my 05 ages ago (look back a few pages) and I love it. They only problem I've developed now is that the clutch doesn't fully release at the very top, but it's nothing to worry about.
Old 10-18-2005, 06:38 PM
  #157
Aloharacing
Aloharacing's Avatar
just wanted to say that i had a chance to drive tonight after doing this modification...and it's a world of difference.
Old 10-24-2005, 01:49 PM
  #158
dchi_t
dchi_t's Avatar
i did this mod on the weekend, i didn't turn the pin that many times, but i do feel a difference in pedal travel....but it feels weird, how do you know if it is not fully engaging?
Old 10-24-2005, 09:31 PM
  #159
jakesford
jakesford's Avatar
i just did this tonight in 30* weather but omg my 03' is now a much better car, don't know how much i adjusted it, kinda guessed and checked my way through. Couldn't be much since my clutch pedal is still slightly higher than the brake and my cruise required no adjusting...
BTW those that have the "throwout bearing" rattle with the clutch out in neutral it makes it easy to adjust. I sat on the ground with the car running and worked the clutch with my hand and i can hear exactly when the clutch was starting to engage with the rattle sound, i have it about 3" above the floor and no problems with it not releasing all the way or what not...
Great free mod, from start to finish is about 20mins to get it adjusted perfect
Old 10-25-2005, 04:05 AM
  #160
DanOnTheRoad
Hmm, I think my second gear is getting increasingly harder to get into. Well, at least there's a "notch" feeling to it now. Now all of the time, but enough to cause me to worry. I'm going to adjust my clutch back a turn before I store the car for the winter... We'll see what that does. Mind you, I was only in 2 turns at max.
Quick Reply: High Clutch? want to lower your clutch engagement point?
