removing AC?
Old 11-30-2005, 03:22 PM
idrmofs7
idrmofs7's Avatar
if i removed the belt for the ac would i loose my heater as well ( i know sounds like a dumb question )
Old 11-30-2005, 04:51 PM
Jime
Jime's Avatar
No absolutely not.
Old 07-15-2015, 08:33 PM
calibredz33
calibredz33's Avatar
sooo, I noticed my AC belt is torn... idk wtf **** happen but i was planning on changing the belts anyways...
can I just cut the belt until the weekend? I don't use my AC anyways
Old 07-15-2015, 10:50 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
sooo, I noticed you responded to a thread that is 10 years old...cut the belt...wgas
Removing the AC will yeild you approximately 40lbs off the front axle...35lbs for the compressor and 5lbs for the condenser + lines...***** aluminum you know...don't expect magic or anything...
Old 11-09-2022, 12:57 PM
Iam_LAZ
Iam_LAZ's Avatar
Originally Posted by itsjoshufocker
has anbody done this? how much weight does it save and all that other stuff? do you guys regret doing it? im thinking of doing it to help reduce weight... i myself dont use it, i just open the windows.... so i thought this might be a good place to start weight loss
I have
i removed the AC compressor along with the AC condenser if you do that you have to get a smaller belt which is the k070505 with also removing the idler pulley , it’s an unnecessary pulley. I noticed a slight difference in power.
Old 11-09-2022, 05:23 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
Originally Posted by Iam_LAZ
I have
OP hasn’t been on here for 9.5 years. Somehow I don’t think s/he cares anymore. 😆
But let me make an observation…. Cutting the belt is relatively useless without also removing all the weight. Also, if you ever want to use the AC again, the compressor will likely need to be overhauled because without movement in the system, all the seals and o-rings will dry out and crack.
VOE…. Did this very thing close to 50 years ago in one of my hot rods. Thought it’d be “cool” (sorry, dad pun) to remove the AC. Big mistake, turns out the best thing about that car was the AC system. Reinstallation did not go well for the above reason. Shoulda listened to my pop, the engineer (one of his specialties: AC systems for submarines and carriers). He never said “I told you so.” But I bet he was laughing inside…. “Dumb boy, how is he my son?”
Old 11-23-2022, 12:28 AM
martin231_day
martin231_day's Avatar
if you dont want to do a perminant removal... just cut the AC belt and you will have a faster revving motor too...
NewOrleans350z
06-30-2016 07:12 AM
james12345pt
07-27-2010 10:38 PM
CAB350z
03-18-2010 04:02 PM
Dr. Venture
01-28-2010 11:53 AM
Mr_pharmD
03-05-2006 04:10 PM
Quick Reply: removing AC?
