Injector size
on
Originally posted by Guru
Stock is 300cc/min. Power Enterprise has 380cc and 510cc available.
on
300 CC/min should be good for close to 350 crank horsepower, should be enough for typical CAI,chip, cat back exhaust mods. You'll only need more if you go forced induction. Calculate your injector flow needs here:
http://www.rceng.com/technical.htm
PS Injectors with too much flow for your power output will give you all kinds of driveability problems. This can not be corrected with mapping. The injectors will only work down to a certain minimum pulsewidth, if that is too much flow you are screwed.
