RevUp Oil Consumption TSB and discussion
#1161
on
I just took my enthusiast 06 to the dealership for the 27,000 service and to start the oil consumption tests. They found that it was 2qt low and documented it on the service order. 700 miles and test again. The previous oil was replaced less than 2500 miles ago.
#1162
Professional
on
Originally Posted by antennahead
I left a nasty voicemail yesterday with a rep at Nissan (BBB, attorney, you know the drill, but I was serious, I did speak with my attorney), the only one who has actually talked with me................. until today. The regional rep called again and I spoke with her for the first time. She spoke with the dealership and confirmed that I qualified for a new handbuilt engine. I then spoke with the head mechanic who was working on getting the order placed on their "techline". IT'S ABOUT TIME!!!!!!!!
For you guys who have received the new handbuilt engines, once the order was placed how long did it take to come in?. The regional rep told me that there was a waiting list now and it might take a little while to build and ship.
John
John
#1163
on
I have been complaining about oil consumption for over 2 years finally took th e car to a dealership that admitted to the problem. Any chance of getting nissan to buyback the vehicle?
#1164
on
what is up with this new hand built engine.. i spoke to a nissan rep who said they have confirmed the problem but there is no fix yet..i have documentation by nissan im sucking 3 1/2 quarts every 3000 miles and for me to call the bbb for help.... this is coming from a nissan rep.....
#1165
on
Originally Posted by Theatrix
It took roughly two weeks from the call from Nissan to receiving the motor at the dealership in my case.
John
#1166
Professional
on
Thanks. How long ago was this? I think there may be a longer waiting list now.
John
John
#1169
on
They called me on the 9th and the car went in this past Tuesday. Will be ready Monday.
John
#1170
on
I spoke to soon
Originally Posted by ZmaXimus
Its official, no more oil consumption for me. Hand built from Japan corrected the issue.
#1171
FYI Make your car as stock as possible
I wouldnt/didnt have any aftermarket items on my ride when it arrived at the dealership because of a blown motor.
Last oil change was 1700 miles and it had NO OIL IN IT!
Cover your azzzzes and save yourself a 10K bill. I few hundred to install the OEM equipment is far less than buying a new block, or having some punk warrantee advisor deny your claim because of a spacer or headers, HF Cats.
I have heard that the cold air intake (the ones that grab cold air close the ground), have been known to grab water....they wanted me sign a doc that said if water was found in my engine, i would foot the bill. I was like I have a short ram intake (350z tube and K&N on my G35 coupe) so there is no way. I told them to pull the block apart, then call me, I aint signing shizzil.
Bottom line, new engine, handbuilt from Japan fixed the issue. A guy with the exact same car,same dealership two months prior, didnt get the same motor and his still burning oil after only 2500 on new engine.
There is hope, but the fight maybe long.
#1172
on
My car is still consuming oil with new Jap engine. I have no choice but to go to arbitration. This should be interesting.
Mine did burn a bit at first, but seems to have stopped. Also, the dealer failed to put the proper amount in it at first and I had to add a lot of oil at the beginning.
This again is just my experience so far and I am still watching it to see what happens.
#1173
on
If you mean total miles 18314. I have about 1345 since they installed the new engine. You make a good point. At this point, its about 1/2 a centimeter under H. Im not sure what that equates to as far as oil. Also, I did check it after it sat overnight.
#1174
on
#1176
on
One full centimeter if half way between L and H. Since I am 1/2 a centimerter, if what you say is correct, I guess I am down .25 of a quart.
#1177
on
No Im am half of that. I am one half of a half a quart down. Either way its going to the dealership tomorrow and they can figure it out. Also, isn't there someone who posted that said they were on there 3rd engine?
#1178
on
I believe it was Theatrix, but I think he is on his first "v2" engine.
I'm hoping that this engine will not burn anymore oil, but it it one of those things that will come to fruition over time. I just hope for the best and will take it for consumption testing if the problem comes back.
#1179
on
Argh!
Well, I decided to go get the paper and check my oil since I have been talking about it today.
Here is what I found.
376 miles since the change and I verified it was full the next day. It is now 1/2 qt down! It seems like things are not so well.
