VQ Oil Analysis and Info - Page 10 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 08-30-2007, 06:31 PM   #181
lilquazyvietboi
ok, i tried reading everything in this thread.... but i got bored of some of the "re-answered" so i skim over some of it.
i gotta say...... i'd read prolly... 70% of every1's post.
and....... i got a headache, and dehydrated.
ok soo..... let's just make my question simple for resolute.
i..... go to the drag strip about once every...... 6weeks or so... and.... i push my car pretty hard on the highway sometimes especially on the highway ramp.
what is a good oil for me to get. mobil 1 0w-40? or this amsoil 0w-30 ... or this schaeffer's xW-xx .... plus, u also gotta tell me where to get amsoil and schaeffer... i dont wanna get scammed.
u sir... are the best
lilquazyvietboi is offline   Reply With Quote
Old 09-05-2007, 08:31 PM   #182
IP05G35
Amsoil ATM 10W-30, 2005 G35
IP05G35 is offline   Reply With Quote
Old 09-06-2007, 11:20 AM   #183
Resolute
Resolute's Avatar
Thanks for posting, I'll add it to the comparison charts on page 1 of this sticky. Looks good. So much for Amsoil bashing other companies for using moly in their oils. I love those marketing guys.
Will
Resolute is offline   Reply With Quote
Old 09-08-2007, 12:42 PM   #184
Nismospeed4life
Nismospeed4life's Avatar
Default Many, many thanks!
Resolute,
This thread is simply ama"Z"ing!!! Many many thanks! You are a gentleman and a scholar. This has to be the best sticky in any forum I've ever visit...
I am currently using Amsoil's 5W-30 And after reading this through the whole threads I am now considering switching to Perhaps Amsoil 0W-30 Or Mobil 1's 0W-40. My VQ35 D.E. Revved-Block is stock and I live in Florida. Please enlighten me with with your thoughts on this. Which one should I choose regardless of the price?
Thanks.
Nismospeed4life is offline   Reply With Quote
Old 09-09-2007, 04:35 PM   #185
Resolute
Resolute's Avatar
If you're not heavily tracking the car, then any of the oils on the recommended list will be a great choice. Between the M1 0W-40 and Amsoil 0W-30, it's your personal preference. There's very little to distinguish between them.
Will
Old 09-09-2007, 06:59 PM   #186
Nismospeed4life
Quote:
Will
Great! I will try them both.
Cheers!
Old 09-10-2007, 10:10 AM   #187
Old Chuck
In looking at the Amsoil European formula, it states it meets BMW LL-04. Is this the same as the BMW LL-01 or referring to a different standard such as low sulfate ash.
Old Chuck is offline   Reply With Quote
Old 09-10-2007, 05:27 PM   #188
Mike Wazowski
Mike Wazowski's Avatar
Royal Purple 10w40 on my VQ35DE with 106,000 miles. Next UOA for this vehicle will be Valvoline 10w30 MaxLife high mileage oil
comments and second column were removed as the confused 2 of my vehicles
Mike Wazowski is offline   Reply With Quote
Old 09-11-2007, 10:03 AM   #189
Resolute
Resolute's Avatar
You said they confused your vehicles, so was this on your TT Z? or do you have another VQ35DE vehicle that this sample is from?
Will
Old 09-11-2007, 10:11 AM   #190
Mike Wazowski
Will
another VQ35DE vehicle. Non-turbo/non-built block
Old 09-11-2007, 10:16 AM   #191
Resolute
Resolute's Avatar
Good to know. That was going to be the most impressive TT oil sample I've ever seen from the VQ. The RP 10W-40 looks like the best formula from RP yet, only the copper looks high. Everything else seems within average. The iron is very low, too bad the lead isn't any lower for the mileage. Thanks for posting this, I'll add the results to the comparison chart on page 1.
Will
Old 09-11-2007, 11:22 AM   #192
QuadCam
QuadCam's Avatar
do you reccomend get a VOA along with the UOA? I still have some virgin Moutl 300v 5W40 that I can send along with my used oil sample.
QuadCam is offline   Reply With Quote
Old 09-11-2007, 11:37 AM   #193
RBlover69
RBlover69's Avatar
im using 0w40 mobile 1 and got no oil consumption in my revup v2 engine and i did some research and its one of there most researched oils . Loving the 0w40 in my revup Z resolute thanks for the analysis man. respect
to the OP in florida , use this oil very good results and remember to get there syn filter also.
RBlover69 is offline   Reply With Quote
Old 09-11-2007, 01:14 PM   #194
mario23
mario23's Avatar
Just picked some Mobil M1 0w40 and M1-110 filter.
Question on the filter...the only M1-110 I could find was the Mobil 1 Extended Performance Filter. Is that the right one?
Thanks and nice write up...
mario23 is offline   Reply With Quote
Old 09-12-2007, 11:13 AM   #195
Resolute
Resolute's Avatar
Quote:
Don't bother with the VOA. I've got a VOA of Motul 300V 5W-40 on file already. When you post your UOA, I'll post the VOA data for comparison if you want.
Will
Old 09-12-2007, 11:27 AM   #196
Robert_K
Didn't Go Cheap
Robert_K's Avatar
Will,
I'm going to be trying out the Mobil 1 OEM weight when I get home Friday. Will send out the RP that is in there now. Let you know the results.
Robert_K is offline   Reply With Quote
Old 09-12-2007, 11:34 AM   #197
Resolute
Resolute's Avatar
Quote:
It's not the same, but I don't know the exact changes. Some message boards have posted about this, but I haven't seen anything concrete from BMW, and I don't take message board rumor as facts. So.. I don't know for sure what the difference between LL04 and LL01 are.
My guess would be that BMW made a similar change as MB in updating their specs for compliance with stricter emissions controls. Lowering ash content would certainly fall into that catagory. The MB 229.51 upgrade also reflects this, along with maintaining extended drain performance. I don't buy the whole "newer is better" theory on regulation changes. As an example, the API SL certified oils contain much more anti-wear additives than the newer SM oils, because the SM change was a new regulation against older AW/FM additives that can harm catalytic converters. I prefer the older SL oils myself, since converter life is not as important to me as engine protection on the track. So, I would not worry about oils that don't meet the newer LL-04 BMW spec, just like I don't care if an oil meets MB's newest 229.51 specs. It's not necessarily a change towards better performance that creates the need for a new spec.
FYI, none of Amsoil's oils are on the official approval list for BMW. Amsoil claims to meet or exceed these specs, but is not actually certified for use in those vehicles. It's another way in which I find their advertising to be crooked, along with the claims half their dealers make. But, it is good oil and I don't doubt their products would meet the certification if they shelled out the big bucks for manufacturer testing to meet those OEM approvals. The 5W-40 is on the MB 229.5 approval list, though.
If you were looking for an oil to meet the newer MB 229.51 and BMW LL04 specs, then there are several out there. But they are hard to find. Mobil1 has a 5W-30 and 5W-40 labeled as "ESP formula". Valvoline Synpower MST 5W-30 is another.
Personally, I look for an oil that meets these three certifications: BMW LL01, Porsche, and MB AMG. This is not to say that an oil that meets all of these is going to be the best oil in the world, but it is a good place to start if you're looking for a new oil to try that doesn't have a UOA from the VQ yet. If the oil meets API SL, then it's even better, IMO. Examples of this that I have yet to try are Valvoline 5W-40, Pennzoil Platinum/Q Horsepower/Q Advanced European Formula 5W-40 (these are all the same rebadged Shell Helix Ultra oil), and Castrol Syntec 5W-40.
Will
Old 09-12-2007, 11:37 AM   #198
Resolute
Resolute's Avatar
Quote:
Originally Posted by Robert_K
Will,
What weight RP will is it, and how many miles did you actually get on it? I would save the money and not bother with a UOA if I were you. That car sat for so long without being warmed up and driven far, that the moisture that invariably built up will cause adverse readings. Unless you're just curious, but it's not going to be very indicative of what most people would get, so I won't bother putting it in the comparison chart if you post the UOA.
Will
Old 09-13-2007, 09:22 AM   #199
Old Chuck
Default Resolute
Thanks for the info on Amsoil European formula (and BMW-04) meeting or not meeting the new MB, BWM, VW and Porsche specs.
Their literature says they meet these and others in their European formula ads.
I realize that they may but just not be on the manufactures' approved list.
I appreciate your candor and taking the time to answer my questions.
They have a good product in their TSO and most likely their European formula but wish they would not state things that could be seen as false advertising. Meeting the specs is different then being approved by the companies. However, in re-reading the information it just says it meets the specs and does not say it is approved by any of the companies.
Old 09-13-2007, 09:43 AM   #200
4SHIZZIL
4SHIZZIL's Avatar
Truth in advertising is out the window.
4SHIZZIL is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Up to Date Coilover Review/Recommendations for a balance of track/drift/slam Lt_Ballzacki Brakes & Suspension 13 10-24-2015 08:56 AM
Oil change with aftermarket oil cooler XM 1 Engine & Drivetrain 11 10-01-2015 10:44 PM
oil pressure drops after a run session? apex locator Autocross/Road 6 10-01-2015 03:47 PM
My350z Featured Car of The Month? Tochigi_236 Feedback & Suggestions for Our Forum 8 09-27-2015 03:40 PM
Tags
350z, 40, analysis, chain, forum, horsepower, measured, microgreenfiltercom, multi, oil, quaker, results, state, temperature, timing, uoa, vq, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
