VQ Oil Analysis and Info - Page 60 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 06-08-2016, 12:03 PM   #1181
tukeeg35
Bumping an old thread, my first UOA! Been running Castrol Edge 0w-30 with a Purolator Pure-One PL14610 filter since boosted at 61,xxx miles, this is my second change with this setup. (Didn't think to get the first one tested ). Switched to a Mobil 1 M1-110 filter and will compare the two on the next change.
tukeeg35 is offline   Reply With Quote
Old 09-14-2016, 01:04 PM   #1182
VQdriver
Default Does anyone have any new data? Used oil analysis might not be all that great...
https://540ratblog.wordpress.com/201...-test-ranking/
A decade or so ago everyone was on the GC 0W-30, M1 0-40 and Rotella T6 kick because of the internet forum sensation created for them from enthusiasts using lab test results. I ran up on the article above a number of months ago which more or less claims to debunk this thread and many like it as myths rather than truths. It's a lengthy read, but my take on it is as follows:
For the best stock 5W-30 off the shelf full synthetic I'd run M1 5W-30. I just switched my racecar to Quaker State Ultimate Durability 5W-30 because of it's ultra high test ratings under higher than average heat which the turbo in my S13 could be subjected to.
For personal daily drivers such as my almost 11yr old G35 (now with 110k) I will run Pennzoil High Mileage 5W-30 because of the greatest test rating compared to Valvoline and Castrol High Mileage oils in 5W-30 weights respectively and cheaper price.
If you scroll down you will see that our beloved GC 0W-30, M1 0W-40 and Rotella T6 are near the bottom of the rankings! I'm not even sure I'd use eurospec oil in my parent's BMW anymore. For it's next change I would probably use almost any other oil near the top. Maybe Pennzoil High Mileage 5W-30 again for convenience. Seriously, why are we running diesel oil in our cars requiring "5W-30!"
Lastly, the article recommends oil change intervals at least every 5,000mi regardless of whether the oil is synthetic or conventional. There's no point in exposing your motor to more grit and dirt with extended oil change intervals considering the low cost of these highly ranked off the shelf oils. Anyway, I hope this opens people's eyes to another perspective and saves wasted money on lab testing results.
VQdriver is offline   Reply With Quote
Old 09-14-2016, 01:16 PM   #1183
F2CMaDMaXX
F2CMaDMaXX's Avatar
What point are you making again?
UOA is to see what state the oil is in and read into foreign contaminants from the engine.
F2CMaDMaXX is offline   Reply With Quote
Old 09-14-2016, 10:45 PM   #1184
VQdriver
Article said that "UOA" (which apparently is not proper oil engineering terminology) is virtually useless and it says nothing about how well a particular oil protects your engine. He goes on to test dozens of oils to evaluate their actual protecting ability. Our popular oils such as GC 0W-30, M1 0W-40 and Rotella T6 are nowhere near the top of the list. Try #149 for GC 0W-30 and #100 for the old formula Mobil1 0W-40. Rotella T6 5W-40 is ranked #156 lol. Go back to my post and I picked out some of the best stock 5W-30 full synthetic and semi synthetic high mileage oils according to said article. Just trying to help out.
Old 09-14-2016, 11:17 PM   #1185
VQdriver
This dude recently updated his article. The new king of the hill for absolute wear protection is...Mobil1's new 0W-40 "FS" European formula. FTW!
The Following User Says Thank You to VQdriver For This Useful Post:
F2CMaDMaXX (09-15-2016)
Old 09-15-2016, 08:41 PM   #1186
F2CMaDMaXX
F2CMaDMaXX's Avatar
Alright, unfortunately i don't have the time to read it right now, but i covered the intro and it looks worthy of a read, thanks.
The Following User Says Thank You to F2CMaDMaXX For This Useful Post:
VQdriver (09-16-2016)
Old 09-16-2016, 07:29 AM   #1187
nizmo_0385
Quote:
This is a great oil using in the Z and plan to use it in the G.
it has helped raise my oil pressure which nissan said was in range about 5 psi at HOT.
nizmo_0385 is offline   Reply With Quote
The Following User Says Thank You to nizmo_0385 For This Useful Post:
Old 09-16-2016, 05:19 PM   #1188
VQdriver
This is what he had to say about a recent reformulation of Mobil 1 0W-40:
"3. 0W40 Mobil 1 “FS” European Car Formula, API SN, synthetic = 127,221 psi
This new oil replaces the older version called, 0W40 Mobil 1, European Formula, API SN, synthetic. See below for the older version’s ranking position.
zinc = TBD
phos = TBD
moly = TBD
This new “FS” version was tested in Summer 2016. This oil produced the highest psi value ever seen in my testing, from any motor oil just as it comes right out of the bottle, with no aftermarket additives. Very impressive.
I also went on to test this oil at the much higher temperature of 275*F. At that elevated temperature, any hotter and thinner oil is expected to experience a drop in Wear Protection Capability. This oil did have a 16% drop in capability. But, even at that elevated temperature, it produced an impressive 106,876 psi, which still kept this much hotter and thinner oil in the INCREDIBLE Wear Protection Category.
I also tested this oil to find out its onset of thermal breakdown, which was 280F."
This is the oil I would use on any turbo car just because it's dirt cheap and has a very low drop off when the heat is really on:
"11. 5W30 Quaker State Ultimate Durability, API SN, GM dexos 1 approved, synthetic (gold bottle) = 113,377 psi
zinc = TBD
phos = TBD
moly = TBD
This was the latest current version of this oil when tested at the end of 2015. The psi value of this oil, which came from testing it at the normal operating test temperature of 230*F, put it in the INCREDIBLE Wear Protection Category.
However, I went on to also test this oil at the much higher temperature of 275*F. At that elevated temperature, any hotter and thinner oil is expected to experience a drop in Wear Protection Capability. But, this oil only had a very small 3.7% drop in capability. And even at that elevated temperature, it produced an extremely impressive 109,211 psi, which still kept this much hotter and thinner oil in the INCREDIBLE Wear Protection Category."
This is what I'd run on all of the family daily drivers, including my G35C which are currently older than 10yrs old 100,000mi. It currently outranks Valvoline HM and Castrol HM 5W-30 and is cheaper than them as well. I will stick to 5,000mi OCI upon recommendation by said author about ALL oils:
"30. 5W30 Pennzoil High Mileage Vehicle, API SN, conventional = 102,402 psi
High Mileage oils are formulated for older engines with over 75,000 miles on them. And High Mileage oils include “Seal Swell” chemicals to help reduce oil leakage in those older engines.
zinc = TBD
phos =TBD
moly = TBD"
The Following 2 Users Say Thank You to VQdriver For This Useful Post:
350zjason350z (11-10-2016), F2CMaDMaXX (09-16-2016)
Old 09-16-2016, 06:56 PM   #1189
F2CMaDMaXX
F2CMaDMaXX's Avatar
Per his notes, i wouldn't use a high mileage oil unless you've got leakage through rubber seals (not ring blow-by) as he says, they contain seal swellers and that's not recommended if you don't need it.
Technically the non HM version of the same oil should be fine, but his testing should show that.
Old 09-16-2016, 08:30 PM   #1190
VQdriver
Yea, I've used both Castrol GTX 5W-30, then the HM 5W-30 on my G35. Next change might be just basic GTX or this Pennzoil HM 5W-30. I'm still not sure. The GTX HM bottle claims it's better for catalytic converters if zinc is lowered. Not sure how big of a deal it it though. The G is the only car that doesn't leak anything yet (knock on wood). The 4th gen Max has a small leak on the crank pulley, valve cover and the ES 330 has a tiny bit through the valve cover. Still hanging in there lol.
Old 09-16-2016, 08:34 PM   #1191
F2CMaDMaXX
F2CMaDMaXX's Avatar
I find GTX and PYB to be about the same in the 350, if i go to PP (good oil) it's too thin and it burns it
Old 01-04-2017, 03:19 AM   #1192
Swaglife81
Is there anything up to date on oil analysis info on vq35's like the OP from 2007-2011. Formulas I'm sure have changed in a good amount of oils. I was leaning towards Castrol Syntec as my go to oil. I want to make my decision off of science, not just this because it's popular.
Swaglife81 is offline   Reply With Quote
Old 01-04-2017, 07:59 AM   #1193
F2CMaDMaXX
F2CMaDMaXX's Avatar
It's a good oil, but it was far too thin for my engine, burned it.
Old 01-04-2017, 03:12 PM   #1194
Swaglife81
I have a used engine in my car, oil stays cleans but I have no idea how many miles are on it. I haven't had to add any oil and I'm at 2500 miles in 3 months but I just bought the car so I have no idea what oil is in it. It's not consuming any, were you running 5w30, if you were eating through it I say try the same brand but go up to 5w40 and that should be good. I know in 03 Ford moves to 5w20 over 5w30 for better Gas Mileage. I know that's Ford and we're Nissan but still oil I think is what the person wants. 5w20 for max gas mileage, 5w30 for lower mileage, DD, and 5w40 for high mileage or oil consumption with 5w30
Old 01-04-2017, 03:15 PM   #1195
F2CMaDMaXX
F2CMaDMaXX's Avatar
You'd have to test it, it's going to be dependant on the engine's life and current condition.
I'm just talking 5w30 here, some are thinner than others within the same spec, i run PYB or GTX will work fine too.
Thread Thread Starter Forum Replies Last Post
Up to Date Coilover Review/Recommendations for a balance of track/drift/slam Lt_Ballzacki Brakes & Suspension 13 10-24-2015 08:56 AM
Oil change with aftermarket oil cooler XM 1 Engine & Drivetrain 11 10-01-2015 10:44 PM
oil pressure drops after a run session? apex locator Autocross/Road 6 10-01-2015 03:47 PM
My350z Featured Car of The Month? Tochigi_236 Feedback & Suggestions for Our Forum 8 09-27-2015 03:40 PM
Tags
350z, 40, analysis, chain, forum, horsepower, measured, microgreenfiltercom, multi, oil, quaker, results, state, temperature, timing, uoa, vq, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
