Towing car in first gear, bad for motor?
on
I did not do this, but someone i know was towing their 5 speed manual Honda CRV on one of those stiff tow hooks that attaches to his camper and he left the car in gear, turned off.
He towed it for about a mile and then remembered that he left the car in gear. He then tried turning the car on but the engine would not start and there was oil comming out from around the oil pan?
He asked me to see if i could find out if something like towing the car while its in gear can damage the engine.
thank you
thank you
on
Originally Posted by godmans
If he tow it with the CR-V's front wheels on the road...the engine is gone... you are just over-revving the engine...
imagine being in first gear doing 65mph?
'12 TL SH-AWD
thank you
thank you
So he can kiss his engine good bye.
If nothing else, oil pressure went through the roof. Drain the oil, take out the plugs, turn over the motor to blow out the cylinders. If there is oil blowing out, spray in carb cleaner to flush them til free from oil. Run a compression test. If its cool, add oil and new plugs and give it a shot
Bodyboarder81
09-21-2015 06:23 AM
