Nismo Differential/ Transmission/ oil cooler build
on
-Time attack car drive train build up- Transmission includes fully cryo treated internals, triple cone high carbon synchros, Teflon coating, JWT clutch kit and flywheel, Motul 75-140w. Differential Nismo GT pro LSD, 3.917 final drive, fully cryo treated diff internals, SPL diff bushings, Tilton low pressure oil pump, custom surge tank, custom ducting, A N fittings and lines, AEM oil temp gauge, Derale cooler+fan, Motul 90PA. More to come as we finish up the build.
Nice but i probably wouldn't have run the cooler high like that. I would have gone between the exhaust cans, it would probably supply better cooling that way.
The tow hook is sweet, i'm still in the air on what to do for my rear hook.
