03 with rev up swap - MY350Z.COM Forums
Thread Tools Search this Thread
Old 04-11-2009, 04:48 PM   #1
jacky ngai
Default 03 with rev up swap
Hello,
I have a 03 track with a vortech supercharger. Yesterday found out the car has a lots of white smoke when it's boost. So my mechanics think it might be the piston rings or crack cylinder wall.
And i have a 06 rev up spare long block in my garage. Anyone knows what parts i need to swap the rev up into my 03 track or it's direct bolt on?
Thanks
Jacky
jacky ngai is offline   Reply With Quote
Old 04-13-2009, 08:02 AM   #2
Xlr82x
Xlr82x's Avatar
it is possible but i am not 100% sure. Haven't heard of an upgrade like that.. Probably less of a hassel to pull yours and rebuild. Most likly you fried your rings..
Xlr82x is offline   Reply With Quote
Old 04-13-2009, 08:09 AM   #3
ZU L8R
Viper Sellout
ZU L8R's Avatar
If you take the heads off your revup spare longblock you'll be able to swap shortblocks without needing anything except for some gaskets. If you want the revup heads on your car you have to start swapping lots of things. ECU, wiring harness, etc...
ZU L8R is offline   Reply With Quote
Old 04-13-2009, 08:55 AM   #4
jacky ngai
Quote:
So the rev up shortblock will direct bolt on to my non rev up motor with some new gasket?
What do i need if i want to put the whole rev up long block in my 03? Ecu, engine harness or somethings else?
Thanks for help. I appericate.
Old 04-13-2009, 08:56 AM   #5
jacky ngai
Quote:
Because i already have the 06 rev up long block in my garage. That's why i wanna do the upgrade.
Thanks for help.
Old 04-13-2009, 09:19 AM   #6
ZU L8R
Viper Sellout
ZU L8R's Avatar
Correct, the shortblocks are the same. All you'll need is some new headgaskets.
I know you will @ the LEAST need a ECU and engine harness to swap the whole thing.
I wouldn't put that 06 motor in my car without getting is checked out 1st. Many 06 motor's had oil consuption issues which is why you can find them cheap.
Old 04-13-2009, 03:55 PM   #7
bbs350z
bbs350z's Avatar
i just swapped my old de for a built 06 revup. you will need the revup ecu/harness (roughly $800), 2 extra cam sensors (roughly $70 each), and a nissan dealership to reprogram your key fob to your ecu (they charge for 1 hour--$105 and your car has to be there)...imho just build your 03..or if worse comes to worse, use the 06 block but swap heads, and +1 for zul8r's point on oil consumption
bbs350z is offline   Reply With Quote
Old 04-13-2009, 04:14 PM   #8
superchargedg
Damn Noobs
superchargedg's Avatar
I really hate to say this but there is so much useless info put out here by members.So if you didnt know white smoke indicates coolant getting in the cylinders and being burned and it comes out the exhaust as white smoke.
superchargedg is offline   Reply With Quote
Old 04-13-2009, 10:51 PM   #9
jacky ngai
Thanks for the reply. I got the engine from a good friend of mine. But i would like to check it out for the oil consumption. Do you know how to check it?
Thanks
Old 04-13-2009, 10:53 PM   #10
jacky ngai
Quote:
Thanks for the reply. Do you know where i can get the 06 ecu/harness for good price? My friend works at nissan so reprogram the key will be no problem for me.
Thanks
Old 04-13-2009, 10:54 PM   #11
jacky ngai
Quote:
So what do you think what's wrong with my engine?
Thanks for help.
Old 04-13-2009, 11:01 PM   #12
350zfun19
350zfun19's Avatar
^ could be a head gasket...
350zfun19 is offline   Reply With Quote
Old 04-15-2009, 12:54 PM   #13
Citrus
Citrus's Avatar
Its blowing white smoke
Citrus is offline   Reply With Quote
Old 04-15-2009, 01:07 PM   #14
KPierson
I have an '05 rev up ECU for sale from a G35 - should be close enough to work.
Does the motor not have the harness on it?
bbs350z - If you already have a rev up motor why would you need two more cam sensors? The cam sensors should already be on the motor.
KPierson is offline   Reply With Quote
Old 04-17-2009, 10:19 PM   #15
jacky ngai
I think 05 harness and ecu are different than 06. isn't it?
Thanks
Old 04-18-2009, 07:29 AM   #16
KPierson
According to my '05 G35 service manual and my '06 350Z manual the plugs are the same. That of course doesn't mean they are, but that is the only way I have to check.
Old 04-19-2009, 10:21 PM   #17
jacky ngai
OK. let me ask my friends to check the part number at nissan to comfirm. PM me for the price you are selling please.
THANKS
Old 04-21-2009, 09:07 AM   #18
bbs350z
bbs350z's Avatar
i bought a built one and the guy swapped in a stock one so took the pulleys/etc everything else with it
Thread Thread Starter Forum Replies Last Post
My FI friends, im at a loss of whats causing my issues. i turn to you. Colombo Forced Induction 29 10-10-2015 03:31 PM
Aftermarket Thermostat? SharX59 VQ35HR 5 09-27-2015 10:23 AM
Tags
03, 2003, 350z, de, engine, rev, revup, swap, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
