Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 10-30-2009, 08:07 PM   #1
CuztompartZ
MY350Z.COM Premium Sponsor
CuztompartZ's Avatar
Zspeedperformance.com
Points: 2,409, Level: 29
Points: 2,409, Level: 29 Points: 2,409, Level: 29 Points: 2,409, Level: 29
Today's Activity: 16.5%
Today's Activity: 16.5% Today's Activity: 16.5% Today's Activity: 16.5%
Send a message via AIM to CuztompartZ
Default CuztomPartz/Southbend DXD Clutch needs test car 07-09HR/370Z
Hey guys, I have been working with Southbend DXD Racing clutches on getting the clutch kits ready for the HR and 370.
I have worked closely with Southbend clutch for over 6 years on developing killer clutch kits for the Z31/Z32/Z33
We have the highest TQ holding single disk set-up available for all these cars to date holding well into the 800+ TQ range! I have also personally ran just about every clutch in the line-up in my own car for let's say "testing" purposes
We are working on a Solid 4140 Billet steel flywheel as well for both cars that we are trying to get to a "Midweight" to help with the Gear chatter common when going to a very light flywheel but at the same time give you the advantages of the lighter weight and the durability you can only get from a solid billet steel flywheel. These should be ready in the very near future.
Anyway, for now we need a test car for our new clutch set-up(s) for the 07-08 HR and/or 370Z
How I would like to do this as I do not know all of you very well (yet) is I would like you guys to elect a person to try this out for us.
Basically this is what I need.
Must own 07-09HR or 370Z 6 speed.
A well known member of the boards.
Honest
Can do his own work (correctly) within a short period of time, or can afford to pay somebody to do it correctly.
Have a somewhat stock set-up with stock flywheel in good condition. Bolt on mods OK, Intake>Exhaust ect.
This will be a street style full face clutch set-up so no drag racing on slicks.
If you track your car that is fine, Actually a plus!
EDIT>>> I will put you in whatever style clutch you need! If you need a drag clutch, you can have it!
This clutch will be comped (FREE) by DXD/Cuztompartz for testing it out for us.
If you guys can narrow the possibilities down for me I will look into them and go from there.
Thanks!
CuztompartZ is offline   Reply With Quote
Old 10-31-2009, 12:05 PM   #2
Viggy75
Send a message via AIM to Viggy75
whats the hp/torque capacity? i have a 2008 enthusiast with dual cold air intake berk test pipes tanabe exhaust with a custom osyris tune... and im lookin for a clucth actually...
Viggy75 is offline   Reply With Quote
Old 10-31-2009, 12:08 PM   #3
SnyzzleZ
SnyzzleZ's Avatar
Points: 1,549, Level: 22
Points: 1,549, Level: 22 Points: 1,549, Level: 22 Points: 1,549, Level: 22
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
hm. long-time member that doesnt track or race his Z and knows everything about the engine = impossible
SnyzzleZ is offline   Reply With Quote
Old 10-31-2009, 01:46 PM   #4
CuztompartZ
Quote:
Read again Track=OK.
Nobody will recommend drag racing on a full face disk althou it is done. Drag race=6 puck.
And what I mean by Drag is just that, Drag racing at the strip with slicks.
Old 10-31-2009, 01:54 PM   #5
CuztompartZ
Quote:
TQ is really not an issue as we can build a kit to whomevers needs. We have kits from 400ish all the way up to over 800.
Which kit I put a person in more depends on what they do with their car and what they like in a clutch, More grab, Smooth engagment, Easy pedal effort, Stiffer pedal effort, faster shifts, street car, track car ect. TQ is a factor but more depends on what you do.
Old 11-01-2009, 03:37 PM   #6
CuztompartZ
You can elect yourself also! Come on now, it's FREE!
Lets TALK!
Old 11-01-2009, 08:03 PM   #7
musubi
musubi's Avatar
Points: 1,501, Level: 22
Points: 1,501, Level: 22 Points: 1,501, Level: 22 Points: 1,501, Level: 22
Today's Activity: 2.8%
Today's Activity: 2.8% Today's Activity: 2.8% Today's Activity: 2.8%
Any concerns with the CSC giving out?
__________________
08 350Z Nismo #833 , 91 Toyota Pickup
musubi is offline   Reply With Quote
Old 11-02-2009, 04:42 AM   #8
CuztompartZ
Quote:
The bad CSC's were recalled and replaced.
Personally I don't think the problem is as big as everyone makes it out to be, I am also a Nissan master tech and have not seen any of these go bad, Even the ones that were recalled were not leaking and I have probably replaced 100 of them.
The Clutch will not cause any problems with the CSC as it is set-up correctly for the car.
Old 11-02-2009, 09:26 AM   #9
musubi
musubi's Avatar
Thx. Nice to hear feedback from someone with experience. What's the clamping load(s) for the HR clutches you're manufacturing? Also, can the clutches for the 350Z HR be used in the 370Z? Seems similar, but not sure.
__________________
Old 11-02-2009, 09:46 AM   #10
CuztompartZ
Southbend has 2 different clamp loads they use, up to stage 3 use around 200 more lbs than stock. The SS series Stage 4 and up are anywhere from 2500-3000lbs and I have had them build that pressure plate to 3800lbs and it worked well at that but was a little stiff to push at the pedal.
Since all of the DXD kits are hand built I can have them build them to whatever clamp load I request.
They normally don't need to have a lot of clamp load in the kits to hold a lot of power. For instance, The Stage 3 OFE kit is a dual friciton kit, Organic on the pressure plate side and SBC's feramic material on the flywheel side.
Feramic will hold "twice" the TQ as a stock like organic lining at the same clamp load so the need for a heavy pressure plate is illeviated.
The HR and 370 use the same clutch set-up, Flywheels are different thou. The 03-06ish is a different set-up as the HR also.
My350Z
350 Z
Paid Advertisement
Tags
370z, bend, clutch, dxd, hp, levels, pipes, puck, series, south, southbend, ss, stage, test, tzr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
