Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 11-06-2009, 08:32 PM   #1
OrangeZYa
Points: 3,067, Level: 34
Points: 3,067, Level: 34 Points: 3,067, Level: 34 Points: 3,067, Level: 34
Today's Activity: 0.3%
Today's Activity: 0.3% Today's Activity: 0.3% Today's Activity: 0.3%
Default Clutch knocking or ticking sound
Was hoping to get a little diagnostic advice on a potential clutch issue on my 05 Z with roughly 50,000 miles...
Recently when I depress my clutch I have been getting a sound that sounds kind of like someone is knocking on my dash from under the hood. The sound goes away when I release the clutch pedal. It doesn't matter what position the shifter is in--depressing the clutch will cause this noise to happen, even if the shifter is in neutral. I mostly notice it at low speeds, but that's probably because the exhaust drowns it out at higher speeds.
I've done some searching but haven't been able to find anything that matches these symptoms exactly. Some similar symptoms I've found deal with a bad throwout bearing--is it possible that is what I could be looking at?
The sound is pretty difficult to describe... I'd call it a knocking or ticking sound. The ticks are pretty rapid and short with probably 3 or 4 ticks per second.
Thanks in advance.
OrangeZYa is offline   Reply With Quote
Old 11-06-2009, 08:54 PM   #2
s31t8n8
s31t8n8's Avatar
Points: 2,671, Level: 31
Points: 2,671, Level: 31 Points: 2,671, Level: 31 Points: 2,671, Level: 31
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
could be a problem with the throwout bearing or pressure plate
__________________
PROAGO
s31t8n8 is offline   Reply With Quote
Old 11-07-2009, 07:44 AM   #3
Guilty1s
Points: 1,188, Level: 18
Points: 1,188, Level: 18 Points: 1,188, Level: 18 Points: 1,188, Level: 18
Today's Activity: 2.5%
Today's Activity: 2.5% Today's Activity: 2.5% Today's Activity: 2.5%
is it a stock clutch/flywheel cause most aftermarket tend to have an annoying chatter.
Otherwise a throwout bearing is the most likely problem.
__________________
2005 Daytona Blue | NISMO |H|K|S| Borla | APS | JWT | EXEDY! | Dunlap | Hotchkis | SPL | Whiteline | Pioneer | Polk | Alpine
Guilty1s is offline   Reply With Quote
Old 11-08-2009, 06:08 PM   #4
OrangeZYa
Thanks for the replies. It's a stock clutch.
Is this something that I should worry about getting replaced or is it just an annoyance? I've seen differing opinions when searching around on here and on google... I had the car at the dealer a month or so ago and told them about the noise but they "didn't hear anything."
My350Z
350 Z
Paid Advertisement
Tags
350, 350z, brakes, clicking, clutch, cluth, depressing, engine, g35, infiniti, knocking, makes, nissan, noise, releasing, sound, stops, ticking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
