You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hi, If you want something with more grab but still smooth on take offs I can recommend the Southbend OFE, Killer street clutch, Very accurate, Very predictable and just a blast to drive.
Couple this with a SBC billet steel flywheel and you will have a combo that will last much longer and feel/drive better than any other kit available.
I also have the Nismo flywheel available for a great price. Not on the site yet as I just got them in.
Why is this better? Feramic linings last 3-5 times longer than organic, Pressure plate is built off the Exedy race engineered plate, Disk has the "dual rivet" premium grade linings, 12 month, 12,000 mile warranty
i heard the JWT has more clamping force and is still good for dailydriving.
which i will be doing.
All you mention is daily driving.......no occasional track time or anything or future power builds........and to some extent on those I would recommend the JWT clutch and flywheel.
I cant directly comment on the others but I will note that the JWT clutch is as most reviews on this forum depict it.
The other thing when talking flywheels is that the JWT flywheel has a replaceable contact surface.
Notice how the friction plate surface is screwed on:
I track my car quite often........and a clutch and flywheel is a wear and tear item in my mind.........
that being said..... I would much rather replace a $65 dollar friction plate surface (which is quick and can be done easily)....Than replacing flywheels or removing the fly, running to a machine shop and resurfacing and then reinstalling *(down time and running around bites).....
-J
__________________
04 PPW Touring - My favorite mod is my short Dodge Avenger antenna
-J
All valid points but...
A steel inserted flywheel like you have mentioned will significantly reduce clutch life.
Inserts have a very high chance to warp with heat.
Since the friction surface is very hard and thin, The heat produced by the clutch builds on the surface and has no where to go but into the friction material which burns up the clutch material, in a solid billet flywheel the heat is absorbed and dissipated better leading to much longer clutch life.
Most serious track and road racers use solid steel flywheels for their durability, High burst strength and longer clutch life.
Only cost approx $20-25 to have it resurfaced VS $65 + shipping to replace the insert and those screws holding the insert on can be a real PITA to remove at times.
An steel inserted flywheel like you have mentioned will significantly reduce clutch life.
yes i agree..........i felt it good to bring this point up as he said he was more using his Z for daily driving.......
weekend worry track guy.....or once a month track z owner should be fine as well......
serious track Z, i agree...they also most likely dont care about down time to go get a flywheel resurfaced......since its not a daily...
-J
__________________
I've driven both the JWT HD and currently own the Southbend OFE Stage 3.
I think perhaps the JWT might be easier to drive. The Southbend has a more sensitive and higher engagement point, but nothing too crazy that would make it not streetable. The southbend one I have is a great price for the power it can hold.
Engagement point can be changed simply by adjusting the clevis rod at the pedal.
Give it more free play and it will engage lower to the floor, Higher pedal requires less free play. Somewhere in the middle to top range is a good spot as it will release well and fully engage.
I prefer about 1" of free play at the top of the pedal travel when the car is fully warm.
Anytime you change your clutch you may have to adjust the pedal height/engagement point slightly or to your liking.
I daily drive my Z, no tracking or anything like that, and I use the ACT Heavy Duty Street Clutch, with the ACT ProLite Flywheel. I've been completely satisfied with it. Haven't really looked at the JWT or the Nismo or any of the others. Just read up on it, and decided that's what I wanted to get. Was the cheapest at the time iirc...
__________________ Understeer -- n. [uhn-dur-steer] "Why isn't this $h1t turning!?" Oversteer -- n. [oh-vur-steer] "Oh, $h1t!!"
