Sikky 350z/G35 LSX swap
#563
on
I would just go with the LQ4 or LQ9 6.0 and put the L92 heads on it from a 6.2 with a L76 GTO intake manifold and LS3 valve springs. That should sit you right around 500-550hp w/GM OEM parts and around $2500-$3000 price wise. I have a friend that works at LKQ and can get a 6.0 for around $1400-$1600 with harness and computer and a rebuilt 6.0 with all forged internals for around $2800-&3200ish.
#566
on
Yea that's the 6.0 right out a car or truck with harness and computer, I have seen the 6.2 heads going for around $800-900 and then the intake and springs. That will put you around $3000 or so if you do everything your self. My friend picked one up and put it in his 1970 Chevelle and is putting 465ish to the ground.
#567
on
Hotrod magazine did a 6.0 build a Lil while back with the 6.2 heads GTO intake and LS3 springs and put the motor on the dyno showing the fuel injected setup did 550hp and the carburated setup did 500hp
