Help, just had Exedy Stage 1 & JWT flywheel installed…chatter box.
Old 12-09-2010, 08:06 AM
thatv35guy
thatv35guy's Avatar
Unhappy Help, just had Exedy Stage 1 & JWT flywheel installed…chatter box.
Hey guys,
Just had my clutch swapped out in my 2003 G35 Coupe…went with an Exedy Stage 1 clutch and JWT Jim Wolf flywheel, unfortunately, first impressions on the clutch haven’t been so great. When getting into first, second, or reverse gears there a lot of chatter. What I mean is there a lot of vibration in the entire car, is that normal? It’s especially bad when you’re in traffic or trying to maneuver in a parking lot, just a ton of vibration with light throttle and the clutch not fully engaged.
I know it’s slightly more aggressive than a stock clutch/flywheel combo and I was prepared for additional noise…but the vibration and shaking is driving me crazy. Any ideas?
Thanks!
Old 12-09-2010, 09:06 AM
Wu-Watt
Wu-Watt's Avatar
I have the same clutch and it chattered too. Now its causing me problems and I gotta replace it after like 15000 miles. Its the tob i'm pretty sure, and now when I start my car the tob makes a grinding/howling noise.
Old 12-09-2010, 11:13 AM
DaveSB
DaveSB's Avatar
My first guess would be the aluminum flywheel. How many miles do you have on it? There's another chance it's not broken in yet. However, Exedy's stage 1 uses an organic disk and those break in very quickly. So probably not.
By chatter, do you mean upon engagement? Like it's jerkey? Or are you taking about the noise at idle or when it's in a low gear, after your foot is off the pedal?
Old 12-09-2010, 11:56 AM
thatv35guy
thatv35guy's Avatar
70 miles on it so far…It’s really jerky when I’m in the process of engaging the clutch, the noise isn’t bad otherwise, just really jerky when changing gears, especially 1st and reverse, all on pedal though.
Old 12-09-2010, 12:14 PM
06g35meister
06g35meister's Avatar
Yeah it sounds like it isnt broken in yet. Mine took around 300 miles to break in and 750-1000 miles to fully break in.
Good luck to ya!
Old 12-09-2010, 12:17 PM
DaveSB
DaveSB's Avatar
Break-in is simple. The best way to break in a clutch is to drive like you're in a parade. No WOT, no agressive starts. Give it 5-600 miles. It should get better.
That being said, losing the DMF will change the characteristics of how your clutch engages and reacts during your normal driving.
Old 12-09-2010, 12:39 PM
thatv35guy
thatv35guy's Avatar
Thanks for the responses! I’m doing precisely that, no WOT, hard starts, etc. I’m hoping it gets better!
Sorry, DMF is…dual mass flywheel?
Old 12-09-2010, 12:40 PM
AcidJake75
Living in 350Z
AcidJake75's Avatar
Check out this post - did you match up the dimple on the fly and on the car..
https://my350z.com/forum/4187263-post2.html
Old 12-09-2010, 12:49 PM
DaveSB
DaveSB's Avatar
Yuppers!
Old 12-09-2010, 12:59 PM
Reality350
Reality350's Avatar
Hey guys,
Thanks!
Get your rev's up a bit higher when starting out in 1st,
It may take a little time for you to get accustomed to the lighter flywheel, but you will be fine once you have...
Old 12-09-2010, 02:31 PM
Not a good combination.
JWT clutch plus JWT flywheel is a better choice.
Exedy clutch plus Exedy flywheel is a better choice. Why members mix brands is beyond me.
Old 12-09-2010, 06:11 PM
djamps
djamps's Avatar
I had the same issue with the comp flywheel and stage 4 clutch; you learn how to engage differently to avoid the clatter/shaking. And when I say clatter/shaking, I mean if you do it wrong the car goes into convulsions. Hint is higher RPM's going into 1st and zero slip going between gears. Either rev match or power shift, no in-between. Don't count on break in making any difference with the light flywheel.
I still get a kick out of watching other people try to drive it. Even a seasoned MT veteran looks like a silly noob trying to engage it the first few times. I can't count how many times people have asked me if something is wrong with the car. It isn't the silky smooth Honda clutch people expect .
Old 12-09-2010, 06:42 PM
Z1 Performance
Former Sponsor
Z1 Performance's Avatar
completely wrong, both are perfectly compatible with one another
lots of things can cause what the OP is experiencing, 9 times out of 10, it's the driver simply getting used to driving this car with a lightweight flywheel
Old 12-09-2010, 06:59 PM
AcidJake75
Living in 350Z
AcidJake75's Avatar
See my post in #8...I have JWT and theres NOTHING like whats specified below..
I only hear the chatter when I let off the clutch in neutral...I dont get no shaking or what not or anything like that.. If thats what chatter is - I dont have ANY...and I have JWT clutch and fly.. Even right after I installed mine..
jblz
jblz's Avatar
+1 Good advice there.
I have an HR and just did an Exedy stage 1 clutch and flywheel. There was a LOT of chatter. The guy who installed it has worked on family cars for 15+ years (Porsches, RennTech MB's, etc... he's not a noob). But there was so much noise, that I took it to a dedicated race tranny shop for a second opinion. They told me to continue going easy on it and bring it back in 2 weeks if it didn't get better.
Like you said no WOT. I think I did 600 miles of "around town" driving and about 300 of highway, all shifting before 4K. It smoothed right out, and now feels/sounds great. Its a long break in period...sucks, but the piece of mind afterward is great.
Like everyone else is saying. Give it a good 500-700 miles of "shifty" driving and see where you stand. GL
Old 12-10-2010, 06:01 AM
DaveSB
DaveSB's Avatar
I have no chatter upon engagement or idle clatter. A very faint (gear roll over) sound in first gear ONLY if I bog the engine upon taking off and only under 2K RPM.
Stage 4 clutch and single mass flywheel
Old 03-17-2015, 06:53 PM
nismodrifter86
nismodrifter86's Avatar
Hello, I'm new to the community glad i found you guys speaking on a topic directly related to my set up and similar issues. I'm a long time Nissan enthusiast I have had my 06' G35 6MT for going on two years now, 125,000 miles on the odometer currently.
I had an Exedy Stage 1 organic disk kit and 18lb chromoly SM Flywheel install around 600 miles ago and I gotta say I am not happy with it so far. I paired this upgrade with an aluminum driveshaft and although the clutches driveability has improved a bit... I cant help feel that something is wrong here. I have had a stage 1 exedy kit with the stock flywheel in my S13 with an SR20 swap for 6 years or so and I never had issues with engagement.
The G just shutters violently into 1st and as mentioned its impossible in reverse and at 600 miles I have ventured into a couple downshifts and the whole car shutters then too. I have gotten use to getting out of gear at a higher RMP and engaging on the uprev with no or very little slip finding the "sweet spot" BUT without being able to downshift though gears without rev matching makes the car not nearly as fun to drive.
Should I expect this will smooth out over the next 400miles or is that just the characteristics of this kind of clutch set up on the VQ cars? Or do any of you think I might have a defective pressure plate, throwout bearing or bad install... I went chromoly to retain some driveability but the flywheel does sound like a cement mixer at low RMP; not that bad though... It does turn heads I have read it does quite down too over time.
Any advise would help! These aren't cheap mods to mess up
Old 03-18-2015, 09:41 AM
Bigsyke
Bigsyke's Avatar
I went from the OE to a JWT setup, and it is just as quiet. After a hard drive on a hot day, there is some chatter at idle and sub 1500 rpms.
Unless it is installation error, I am very confused on this chatter people keep talking about.
Old 03-29-2015, 10:33 PM
nismodrifter86
Default Exedy Stage 1 organic disk kit + 18lb chromoly SMF (1000 Mile Update)
So this doesn't seem to be a popular thread or its just really old, but I would just like to an update; I am at about 1000 miles (approx. 750 street 250 Highway) now and it has smoothed out considerably; I assume the bearable noise and vibration I get at this point is normal for a lightweight flywheel and drive shaft set up since there is so much less dampening inertia... I hope this post is helpful and definitive for anybody Google searching (how I found this write-up) for solutions to this issue, don't run out and replace your clutch; as others have said give it 1000 miles and see where you stand.
Old 06-10-2015, 11:51 PM
KB24MVP
KB24MVP's Avatar
About to upgrade to jwt clutch n flywheel from one our vendors. Seems like breaking it in is the issue of all the chattering.. Afterwards, I'm told by many "it's not that bad" thanks for this thread
04-22-2021 09:42 PM
11-09-2020 10:27 AM
EnjukuRacing
09-30-2015 06:55 AM
Quick Reply: Help, just had Exedy Stage 1 & JWT flywheel installed…chatter box.
