cp piston direction?
Old 03-30-2011, 12:19 PM
the_coupe
the_coupe's Avatar
Default cp piston direction?
so the cp pistons i got have no markings giving direction upon install. the only thing i can differentiate is how the bottom of the skirt is notched on one side, but all 6 pistons are done the exact same. i waitin on a response from cp and having a problem gettin ahold of a tech on the phone. any help cuz im waitin to put my rods/pistons in til i find this out. thankss
Old 03-31-2011, 06:35 PM
Nathan
Nathan's Avatar
Are the valve relief cutouts in the pistons a different size for inlet & exhaust valves?
If they are then it's easy
Old 03-31-2011, 06:38 PM
350zion
Professional
350zion's Avatar
True^
Old 03-31-2011, 06:47 PM
baker0308
baker0308's Avatar
no its the same....
u have to look at the bottom of the piston, it has a cut out for the oil squirters..... ull know if u installed it backwards/wrong cuz as soon as u turn the crank by hand it will break them off
Old 04-01-2011, 03:30 PM
Nathan
Nathan's Avatar
Originally Posted by baker0308
no its the same....
Well now it's even easier, as the valve reliefs are all the same size & all the pistons are identical you assemble with the cutout to clear oil squirters
Old 04-02-2011, 12:43 AM
winchman
winchman's Avatar
Are the notches in the pistons needed to clear the crankshaft when the piston is near bottom dead center? If so, some will go forward and some will go aft depending on the location.
Old 05-26-2014, 09:15 PM
Bpb713
Newbie
Bpb713's Avatar
Sorry to revive the dead but this post wasted my whole weekend. Rather than calling CP Friday afternoon, I went off the info above, stating they will only work 1 way and that if its wrong it'll break off the oil squirter. WRONG!!! They will work either way on either side. My previous pistons were JE and they were stamped L/R & INT. Anyway I'm gonna call CP soon as they open back up from memorial day weekend... Oh and the notches cut would only work for one bank but not the other.
Old 07-09-2015, 11:06 AM
fridaytech21
fridaytech21's Avatar
Did you figure out what the orientation was? I called CP this morning and they were saying that the side that is not notched is the intake side and the side that is notched is the exhaust side. But my machine shop is telling me the opposite. What did CP tell you?
CP needs to mark their pistons, JE all the way next time!
Old 07-09-2015, 11:33 AM
travlee
Master
travlee's Avatar
Received 9,043 Likes on 6,509 Posts
you responded to a thread that hasnt been touched in a year, and 3 years since the original post
Old 07-09-2015, 03:08 PM
350zjason350z
Know it all
350zjason350z's Avatar
I have cp Pistons ... There are 2 sets of notches on the piston ...
Old 07-11-2015, 07:34 AM
fridaytech21
Yeah I know it was an old thread, was installing the pistons and saw differences but CP does not include any orientation guide as to what direction they go. Thanks 350zjason350z, after talking to CP the next day the cleared it up for me. The pistons have the "oil squirter cut out" which is very noticeable, this goes toward the intake side on bank one. Then the other side has a much smaller cut out for the squirter called a "cam cut". It was just tripping me out that the pistons are completely symmetrical. Dealt with other companies pistons that are well marked and are asymmetrical.
Old 04-22-2022, 02:34 PM
renanbiro
renanbiro's Avatar
Sorry to revive the topic but I have the same "problem". What was the solution for installing CP Carrillo pistons?
Old 04-24-2022, 03:19 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
Typically marked pistons have offset wrist-pin bosses - so if there are no marks, the wrist-pins are centered, and the skirts are the same than it does not matter. I would tell you to install them all the same way for each cylinder.
Old 04-24-2022, 04:42 PM
renanbiro
renanbiro's Avatar
OK, but the 6 pistons are identical, they have the notches on the same side, so only one bench will have the notches directed towards the jet oil
Old 04-24-2022, 05:43 PM
bealljk
bealljk's Avatar
Install them and see if they hit the squirters
Old 04-25-2022, 11:32 AM
renanbiro
renanbiro's Avatar
I've already done this test and it doesn't catch on the squirters, but only one side is apparently "correct"
04-22-2021 09:42 PM
sales@czp
09-23-2019 03:30 PM
Tochigi_236
09-27-2015 03:40 PM
hardkicks
09-20-2015 12:28 PM
Quick Reply: cp piston direction?
