Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old 04-05-2014, 05:15 AM
  #1481
Quamen
Quamen's Avatar
Originally Posted by razor1965
This my LQ4 with a 4L80E transmission. Almost done
Looking good! Auto is a blast with an LS in the Z.
Old 04-08-2014, 10:14 PM
  #1482
sidewaysracin
sidewaysracin's Avatar
So i may be switching to an auto trans. So if anyone is in the market for a built t56, SFI hardend flywheel, Mcloed RXT twin disc, and all the wilwood slave and master cylinder stuff ill be putting everything up for sale as a package. Pm me for details.
Everything has been used for about 600 miles......
Old 04-13-2014, 01:06 PM
  #1483
midz350
midz350's Avatar
Guys, where do you get your switched power from? The IPDM or the J/B?
Old 04-26-2014, 03:05 PM
  #1484
350zsunshinefl
350zsunshinefl's Avatar
what makes u want to go auto?
Old 06-02-2014, 02:46 PM
  #1485
cslithergo
cslithergo's Avatar
Default Another Way to get your LS2 / T56
A lot of questions came up about where to obtain an engine / trans for your conversion with a lot of good sources mentioned. I went another route and purchased an '06 GTO from Copart. I picked it up for $6700 about the same price as a drop out from LKQ or Ebay. I took a few months and located one with low miles (68K) was running and "drivable" and had a lot of salvageable parts. I have sold most of the parts that were removed and returned a little over 2K back in my pocket. The other advantage is that I know where every little wire went to and kept ALL the parts I might need or want as all of you know there are many ways to do the conversion. After pull everything off the car it was chopped and carried to the scrap yard for some more $$
some shots of the start of this project...
Attached Thumbnails The Official LS Swap Info/Questions Thread-front-pass.jpg   The Official LS Swap Info/Questions Thread-z-car-009.jpg   The Official LS Swap Info/Questions Thread-img_1438.jpg   The Official LS Swap Info/Questions Thread-img_1443.jpg   The Official LS Swap Info/Questions Thread-img_3375.jpg
The Official LS Swap Info/Questions Thread-img_1444.jpg   The Official LS Swap Info/Questions Thread-img_1484.jpg   The Official LS Swap Info/Questions Thread-img_3393.jpg   The Official LS Swap Info/Questions Thread-img_1501.jpg   The Official LS Swap Info/Questions Thread-img_1502.jpg
Old 06-05-2014, 03:48 PM
  #1486
bigcloud
bigcloud's Avatar
Wow you could effectively have traction control as most LS swapped Z's don't have it when they swap. Good move.
Old 06-06-2014, 01:31 AM
  #1487
Lightning Guy
Lightning Guy's Avatar
Haltech has traction control if you wire all the stuff in, pretty Motec does as well. unsure if the haltech for a GM motor would read the data on the Nissan Canbus.
CANBus is a standard as far as the data layers and signal interface, and perhaps even the addressing schema, but the actual address of the information might have to be remapped.
IF you wired the hall -effect sensors directly to the haltech you should be able to use the traction control feature. you would need an additional sensor on at least one wheel to indicate ground speed verses engine/transmission speed.
We had something close on the racecar, where we controlled boost by the front wheel speed sensor, car didn't have ABS though
Old 06-18-2014, 08:06 PM
  #1488
cslithergo
cslithergo's Avatar
Waiting on FR to send me some parts.....
Attached Thumbnails The Official LS Swap Info/Questions Thread-engine-b-gone-.jpg
Old 06-22-2014, 07:11 AM
  #1489
QTB
QTB's Avatar
Selling my sikky kit if anyone is looking.
https://my350z.com/forum/showthread.php?t=595066
Old 06-22-2014, 07:30 AM
  #1490
Royal_T
Royal_T's Avatar
Getting closer and closer
Build Thread here: https://my350z.com/forum/engine-and-...nuff-said.html
Old 07-20-2014, 09:12 AM
  #1491
Dayhoff35
Dayhoff35's Avatar
Anyone know if the Sikky shifter has been updated? Ordered my kit before i saw the shifter issue, and don't wanna drill into it before I know it still needs to be done.
Old 07-22-2014, 01:29 PM
  #1492
Royal_T
Royal_T's Avatar
They have a new design for the shifter now.. You should be good..
Old 07-23-2014, 07:33 AM
  #1493
Dayhoff35
Dayhoff35's Avatar
Sweet, glad I asked didn't see anything on it so I figured I'd ask. Thanks!
On a side note been following your build here and on tech and you need to get that thing done! Lol its an awesome build though.
Old 07-25-2014, 12:14 PM
  #1494
CMyTailsBlink
CMyTailsBlink's Avatar
Default .
Figured I would drop this here since this thread has a good following. My car is officially up for sale. I'm waiting on my sale thread to get approved, but hopefully it will be up soon. I hate to see it go, but I'm getting ready to move soon and I have a lot of traveling in the next few months. Now's the chance to own the baddest LS Swapped Z out there
Old 07-26-2014, 02:42 AM
  #1495
Lightning Guy
Sad to see you get rid of her Nick. Before you start 'traveling' lets hook up and grill a dead animal.
Old 07-27-2014, 02:49 PM
  #1496
CMyTailsBlink
It'll be a sad day for me when the car is sold, but someone else will have an awesome Man Toy. We will definitely get together before I leave, Bryan. It's been too long.
https://my350z.com/forum/zs-and-gs-f...l#post10432688
Old 08-01-2014, 11:33 AM
  #1497
bbs350z
bbs350z's Avatar
quick breakdown, im most likely getting a new harness as im unsure of the work done on this one. which one should i get? what needs to be wired where? if i recall i was told most harnesses (using just gm ecu) requires only 4-5 wires to wire in.
Old 08-04-2014, 11:41 AM
  #1498
drunkinmonkey
drunkinmonkey's Avatar
Mann I absolutely love this thread I'm taking in all the info I can get. I'm in the process of buying a 350z and doing this build and I'm wondering if it matters if the 350z is an automatic or standard to do the swap? I would gladly appreciate the help thank u.
Old 08-16-2014, 01:02 PM
  #1499
Cass007
Cass007's Avatar
Originally Posted by Armed Ferret
Ah. Yet another track only car. Shame cass doesn't respond to emails or messages on the site or id have had an answer months ago.
Back from the dead now and will try and be much more active ... not sure I could be less active
I will offer any advice and help I can. My car is still up and running solid, zero issues other than one I created myself when we changed from closed loop idle control to open loop, so it takes an idle dip coming off full throttle as it searches for the correct idle parameters.
Seeing Cmytailsblink Z for sale has my full attention ... hmmm.
Old 08-16-2014, 03:45 PM
  #1500
CMyTailsBlink
Someone needs to buy this car from me. I really don't want to sell it to just anyone. It's gotta go to someone who will appreciate it.
Quick Reply: The Official LS Swap Info/Questions Thread
