Review of RJM adjustable clutch pedal bracket
#122
Vendor - Former Vendor
Yes, I'd be willing to take on a few select distributers now that the product has matured a little and my production capacity has grown. I'm very happy to see you and the guys at Z1 Motorsports are impressed with the difference the AFP System makes over the stock setup
The 370Z and G37 versions will be coming out at the end of the month as well.
#124
Installed mine this past Monday. It does exactly what says it does. My only gripe is that I didn't buy it sooner. It makes it a lot easier to shift and gives you more leeway to make mistakes without the horrible jerk that usually results. I kept it at the 75% that was recommended in the instructions and it works great for me. Definitely a great buy for anyone who wants an easier time shifting.
#126
resident25 congrats on the successful install! Very happy to hear your enjoying your new clutch feel
hyuk28719 thanks. I couldn't have done it without the great bunch of guys like yourself who had enough faith myself & my product to take part in the tester group buy in the early days of this adventure
I'm proud to be part of such a great community here at My350Z and look forward to continuing with more exciting new products and super customer service for years to come.
#127
Excuse my n00bness, but a few things aren't clear to me.
1. Will this product help someone with a stock clutch? All the rave reviews seem to be from people with upgraded hard-to-drive clutches.
2. Everyone talks about adjust-ability as the key to both fast shifting and long smooth shifting. Would I adjust it one way for aggressive driving and then another for smooth, or is there a sweet spot that makes everything better?
3. I have the crappy 03 tranny that grinds 3rd and is harder to shift when cold. I have the stock clutch that either yanks or doesnt go at all. Should I try other things to improve my shifting experience before getting this? (can't afford a tranny swap just yet)
#128
#1 Yes this is 100% for everyone who drives a 6MT. I myself designed the product because I was sick of the factory clutch feel and my stock clutch is 100x better feeling now. The adjustability of the system allows it to be tuned for any clutch from stock to heavy singles to twin & triple disk setups.
#2 You pretty much set it and forget it. There is no need to go back and forth with changing setups. Better clutch control smooths out daily driving and makes you more consistant and easier when driving hard too. See Faiz23's review (another forum) where he's working with AcidJake (a Mod here) on his competitive drift car and just installed my product for testing last week.
#3 I would caution against doing this mod before getting your car fixed and sorting out your existing problems. My product makes amazing gains in clutch feel, control and smoothness but it can't fix a bad clutch or transmission with synchro issues.
#131
on
Thanks Ryan,
I just installed the clutch bracket. Car feels amazing. I set it around 75 percent and to me it feels perfect. It's so much more pleasant to drive the car. The install is pretty straight foward. The only hard part is that you're working in such a small area. I've been driving only a few hours so I'm sure I'll fine tune it. I was an idiot and shorted something under my steering wheel and the car wouldn't start. The ignition switch fuse blew. So remember to disconnect the negative terminal haha. But great product. Well worth it.
#132
Rodizzle, You're Very Welcome! I'm happy to hear your enjoying my clutch pedal kit. Sorry to hear you arc'd something under the dash, that's pretty crazy and it's the first time I've heard of anything like that. Good thing it was only a minor repair to replace the fuse.
#134
djamps. Thank you for your order.
I would let some of the guys running more agressive clutches answer this as well, but I've had multiple reports of it smoothing out the shudder on agressive clutches.
On my own car it's reduced it by about 90%. My factory clutch used to shudder and shake horribly when trying to slip it nicely off the line. After the mod its greatly reduced and the few times it does still shudder its barely noticable now.
#135
#136
Resmarted, No I wouldn't have any worries installing the product along with a fresh clutch and/or transmission install. Even if you did run into problems to diagnose the A.F.P Slider can be set to the stock fulcrum point distance and will function exactly like the stock brackets except with the assist spring removed. Doing this is about a 10 min change once installed or could be done at the time of install and changed up later once everything else is proven.
I was just commenting that if you already know your clutch is toast or your synchro's are trashed and grinding gears then the product won't help make things better.
#137
Also as hyuk28719 noted in his review, hill starts are sooooo much easier with the product installed as the friction point is right there about 1" up. You can feather the clutch for a real nice roll out without needing gas to keep from stalling or rolling backwards and then just progressively roll into the throttle while getting off the clutch.
#138
AFP Settings Explained
While I'm at it I get questions all the time about the A.F.P setting and how it works. Well in the simplest of terms the AFP setting is how much wider the engagement window is OVER Stock.
If you're at 0% AFP the slider is all the way down and the fulcrum length is equal to stock. Feels like the stock brackets with spring removed.
If you're at 50% AFP the slider is set right in the middle of it's travel and gives you about 50% wider engagement window over stock.
If you're at 75% AFP the slider is 3/4 of the way towards the top of its travel and gives about 75% wider engagement window over stock.
Above 80% it becomes hard to get full disengagement on a stock and aftermarket clutches. This area is only recomended for those with really short disengagement clutches. For example those that require a stop plate be installed to limit pedal travel. For people with these clutches running above 80% can restore a more normal pedal travel and eliminate the need for a stop plate.
"Engagement Window" I define as the total amount of pedal travel from just finding the friction point to the point where the clutch is fully engaged and no longer slipping. As the engagement window gets wider, the friction point gets lower towards the floor. This is due to the fully locked point always remaining fixed near the top of the pedal travel as with any hydraulic clutch system.
Hope that helps explain the AFP settings and the talk of engagement window a little better for those who haven't already had a chance to install the product and play with these settings a little.
#140
Does that make sense? Let me know if there are other questions. Mine is set at about 75%.
Thanks.
