People with 260+whp on de motor
Old 08-20-2012, 09:46 PM
KingBaby
Hardest Setting
KingBaby's Avatar
you have more stock horses to unleash
Old 08-20-2012, 09:54 PM
TuckerE36
TuckerE36's Avatar
no, i was just mentioning that Mustang dynos don't usually show inflated numbers and tend to read more accurately.
Old 08-20-2012, 10:00 PM
KingBaby
Hardest Setting
KingBaby's Avatar
roger roger
Old 08-22-2012, 05:18 AM
BoomerZ33
BoomerZ33's Avatar
290whp on a DD on my 04 DE
Osiris Uprev
Nismo CAI
Greddy turbo TIC
Stillen SS headers
Berk HFC
Motordyne 5/16
Motordyne MREV2 ported
ARC oil cooler
Old 08-22-2012, 08:29 AM
graffkid732
graffkid732's Avatar
Osiris Uprev
Nismo CAI
Greddy turbo TIC
Stillen SS headers
Berk HFC
Motordyne 5/16
ARC oil cooler
How much power did the Oil cooler give ? You have dyno sheet? That power on a DD seems high no? On a DJ that would be about 320whp+
Old 08-22-2012, 08:36 AM
BoomerZ33
BoomerZ33's Avatar
because racecar. and Jas has my dyno sheet. anymore questions?
Old 08-23-2012, 04:49 PM
Fryrot3
Fryrot3's Avatar
Originally Posted by Mcutali
Cel goes away with defoulers. They back the o2 sensor up a bit so its not directly in the stream of exhaust gases. Cel light will go bye bye. I have a 04 touring with AMS Crank Pulley, Z1 headers, Z1 test pipes, Xo2 Catback,Nismo short ram(Jwt heatshielded)K&N,Motordyne 5/16th, Cosworth phenolic spacer, Mild Port Polish of Upper Lower Plenums Chopped front runners down,TurboXs Utec tuned. 288whp 272tq Dynomite by Land&Sea
Not bad at all man, you ever run that?
Old 08-24-2012, 03:32 AM
NAbuilderZ33
NAbuilderZ33's Avatar
Osiris Uprev
Nismo CAI
Greddy turbo TIC
Stillen SS headers
Berk HFC
Motordyne 5/16
ARC oil cooler
Damn bro, I have an 03 DE as well and im not putting out that much power. I have K&N Short Ram, GTM 3inch MAF housing, MD 1/2 spacer and Mrev2, Stillen Pulleys, Fidanza flywheel, Test pipes, MD XYZ and Momentum 3'' Single Exhaust and Osirus tuned and im only doing 250whp 230ft.lbs on a Dynapack. Smh, when i saw my numbers i was real depressed...
Old 08-24-2012, 03:40 AM
e30cabrio
e30cabrio's Avatar
Received 2,578 Likes on 2,037 Posts
Osiris Uprev
Nismo CAI
Greddy turbo TIC
Stillen SS headers
Berk HFC
Motordyne 5/16
ARC oil cooler
How much torque?
Old 08-24-2012, 06:13 AM
thekinn
thekinn's Avatar
Mrev2, 5/16 spacer, HFC, Motordyne single shockwave.. UpRev tune by Hal on the heartbreaker of all heart-breakers.. 248.2hp.
good luck!
Old 08-24-2012, 08:08 AM
Jairen
Jairen's Avatar
Hitting 260 is gonna depend on the dyno. Some read higher and lower. For instance, I hit 260 with just a spacer and exhaust (revup) on a dyno dynamics.
Old 08-24-2012, 04:26 PM
NAbuilderZ33
About the Dynos reading differently, thats soo true sir, cause when I went to another Tuner with a DynoJet, I was 268whp, 245 torque the next day lol
Old 08-25-2012, 01:12 AM
SE5spd
SE5spd's Avatar
What WHP did it make stock?
What'd it run in the 1/4 mile?
Old 08-29-2012, 07:49 PM
jes1888
jes1888's Avatar
quick question here, i'm about to buy megan downpipes, i wanted to know if they will throw a cel without defoulers, does anybody have them?
Old 08-29-2012, 08:00 PM
Z_on_TE37's
Z_on_TE37's's Avatar
Megan resonated test pipes come with built in defoulers
Old 08-29-2012, 08:43 PM
jes1888
jes1888's Avatar
i didnt mean test pipes, i meant downpipes, like these ones, or do these ones have it too?: http://www.ebay.com/itm/360457151300...84.m1438.l2649
Old 08-29-2012, 10:41 PM
SE5spd
SE5spd's Avatar
you mean test pipes?
Old 08-30-2012, 06:25 AM
  #38
Z_on_TE37's
Those are test pipes. on a 350z, the downpipe is the cat. make sure theyre the new version with the flex pipe and the nonfouler.
Old 08-30-2012, 12:25 PM
  #39
Michla22
Michla22's Avatar
261hp / 250tq
On a 2003 DE with 175k miles:
JWT intake
MREV 2 Manifold 5/16 spacer
Berk test pipes
JIC y-pipe
Nismo exhaust
UPREV tuning - Important
Old 07-25-2014, 05:43 AM
  #40
Bellisima_Z
Bellisima_Z's Avatar
Originally Posted by e30cabrio
271/262 on an 06 revup with everything in my sig minus the stroker.
What was on your mod list at the time you pulled these numbers?
Quick Reply: People with 260+whp on de motor
