2006 Rev-Up Motor on 03-05 Questions
Old 08-05-2012, 12:51 AM
mcsoap
mcsoap's Avatar
Default 2006 Rev-Up Motor on 03-05 Questions
Should be getting my hands on a 06 rev-up for free, only problem is i think its got rod knock. Planning on ripping it out, and checking the actual damage as to whats still usable. Depending on condition on everything, will start off building the bottom end, and slowly building the engine. Until i decide to swap it into my car. Couple concerns, from what ive been reading.*correct me if im wrong* i need the 06 harness, not sure if i can use my 03 ecu (possibly use a stand alone on top of the 03 ecu or is a 06 ecu required as well.
i know its silly to put a rev-up in a non rev, but im getting it for free, and could use a nice little project. any suggestions, ideas, thoughts, questions are welcome. If everything works out, ill start a lil build thread for you guys if you want.
Old 08-05-2012, 06:09 AM
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
You have 2 choices , convert the rev up to a normal de or add the proper electronics. My spare motor is a rev up , mostly converted to DE now.
Old 08-05-2012, 11:48 AM
thisishk350
thisishk350's Avatar
If you're going to build it just put your Non revup heads on it and it'll drop right back in
Old 08-05-2012, 01:45 PM
terrasmak's Avatar
http://www.injectedperformance.com/i...for350zg35.htm this is easier , let's you use the rev up heads for DE
Old 08-05-2012, 05:16 PM
mcsoap
mcsoap's Avatar
mmm interesting, so by swapping my de heads to the new engine, no need for additonal electronics, or i can just put those exhaust cam sensor plugs in on the rev up heads. am i right in thinking that the only difference between the rev up and de heads, is the increased rev limit?
Old 08-05-2012, 07:40 PM
bbs350z
bbs350z's Avatar
im selling my flashed rev up ecu for cheap. pm me. i've done the revup swap into my de car.
Old 08-05-2012, 07:51 PM
terrasmak's Avatar
You also need to run DE cams , then you should also run the DE timing cover you already have.
Old 08-05-2012, 08:22 PM
clubhopper
clubhopper's Avatar
option 1: convert fully to rev-up..buy a new harness and ECU for 06'...at this point its a straight motor and harness swap.
option 2: create a standard DE from your rev-up short block by mixing the two.
(a)swap over your old cams to the revup heads, plug the hole for the exhaust (outboard) cam sensors on the revup heads, swap over your DE inner and outer timing face covers, swap over the exhaust cam gear...
(b) just grab the entire head off the old DE and bolt it on to the revup shortblock and call it a day. you'll still need to transfer over the inner and outer timing face covers while you are at it.
Old 08-08-2012, 02:58 AM
mcsoap
mcsoap's Avatar
thanks, all this info has been really helpfull. now i just need to sit and wait to see when he gets the new motor, and HOPEFULLY the damage isnt too bad........
07-10-2022 07:44 AM
04-22-2021 09:42 PM
04-04-2016 07:52 AM
Quick Reply: 2006 Rev-Up Motor on 03-05 Questions
