Oil pan spacer diffuser plate?
Old 08-19-2012, 10:02 AM
350Z86
350Z86's Avatar
Default Oil pan spacer diffuser plate?
So I installed my wolf tech oil pan spacer and the diffuser plate that was inside didn't fit with the pick up tube extension. I just left the plate out when I put it back together. While cleaning up the garage I saw on the back on the instructions there is a cut out template for the diffuser plate to make it work.
Do I need that diffuser plate or can I just leave it out?
Old 08-19-2012, 10:38 AM
Ruthless18x
Ruthless18x's Avatar
If you track the car you need the plate. If you just DD you're fine, but I would replace it at your next oil change.
Old 08-19-2012, 05:05 PM
350Z86
350Z86's Avatar
Well I'm supercharging it and only drive it to and from the drag strip. I'd reinstall it before I even drove the car.
Old 08-19-2012, 10:29 PM
AnnLindel
AnnLindel's Avatar
07-10-2022 07:44 AM
burglapfd
12-06-2020 01:04 PM
Quick Reply: Oil pan spacer diffuser plate?
