Installed a Mishimoto fan shroud today...
#41
Hey STL350Z or any electrical guys,
Having issues but not cause of the write up it was great.
My issue is my car still overheats after installing the fans months later.
I spill free funnel burped the system, but the divers side fan doesn't turn on at all.
Only the passenger fan is operating either when it gets hot or when I turn on the AC.
I switched the connections assuming the drivers fan would work but once again the passenger side is the only one that works exactly the same way as I previously stated.
Even if gauge for temp goes above half way still no drivers fan.
Any clue why?
Wiring, bad fan, or bad relays?
I would assume wiring is good since swapping plugs didn't change anything...
Any clue why?
#43
The drivers side just refuses to kick on at all even if temp gauge rises above normal to almost max temps.
And it did it today and temps are 95 degrees outside today...it should have had both fans running since it was idling and overheating with AC on.
Could I have a bad temperature sensor and does the sensor actuate the second fan to come on could that be the issue I am having or am I way off about the temp sensor?
#44
Either the fan motor is blown, of the fuse is blown...
check the fuses...there are 2 separate 40 amp fuses for each fan in the fuse box by the battery....
Also, as a shortcut, if you turn the AC on with the engine running both fans should turn on immediately no matter what the water temp is...
#45
OMG YOU HAVE GOT TO BE ****ING KIDDING ME
In my previous complaints about the tabs on the shroud not allowing it to press up against the radiator flush (post#39), the rubber seal that you put around the shroud came off and got all wrapped around fan #2 and killed it.
I finally got so fed up last night after rewiring twice to verify I did it right and second guessing if I remember fan #2 ever working I pulled the shroud and found the rubber seal in there.
So at 2am I went to Amazon and ordered a new 12in fan overnight to swap out.
Thanks for all your help guys now I know the entire cooling system including electrical inside and out on this car cause of this LOL.
#53
Well.....I had a fan go out. Got pissed at stock shroud.......cut it where I thought wouldn't matter....but now something is off. Running a bit hotter than it was. Probably the AMazon fan motor I used (got it in two working days compare to week for OEM) Knew it was temporary.
Tearing into things this week and wanted to upgrade. Waiting for Z1 to respond to email....
#58
on
Hey all, I've got to dig up this thread to find some help. I haven't been able to drive my car for 2 weeks.
I have a fan setup like all the ones pictured with 2 SPAL fans wired the way described in this thread, but I'm having issues. Both fans are getting power, the driver side comes on with the AC, etc. So it seems to be working right. But the problem is my car is in "limp" mode or something. I can't drive over 2500 rpm above 35 mph.
What do I need to do to fix this? I've tried rechecking the wiring and swapping the driver and passenger plugs, tried disconnecting my battery, tried clearing codes (it didn't even throw one), and even reflashing my ECU with UpRev. I'm out of ideas and about to go back to the factory fans if I can't figure this out.
Thanks for any help guys.
#59
SO you think the fan install has something to do with your car going into limp mode? Or was the limp mode there before the instal and you thought the fans would solve it?
Don't for get to search other areas of this sight for info on getting the car out of limp mode. FI might not be the best place to find that info. expand a bit.
good luck
good luck
#60
on
good luck
good luck
I get them installed and changed my oil at the same time (didn't think about disconnecting the battery). Then I pull out onto the highway and can't drive over 2500rpm over 35mph in any gear.
Whatever happened was onset by something I did that day. I checked all the radiator fan fuses I could find. Not sure what's going on. I'll look into the limp mode threads, but I was hoping someone might know off the top of their head here.
