How do you tell if the synchros or transmission is bad?
Old 08-27-2012, 07:21 PM
Jbakes727
Jbakes727's Avatar
Default How do you tell if the synchros or transmission is bad?
i bought my 04 350z a few months ago, it currently has about 80k miles on it. I was wondering how to tell what shape the tranny is in. When i am driving in 2nd or 3rd and when i let get off of the gas my car makes a noise (kinda like a whining noise) when im slowing down its like something is forcing it but once i am going slow enough in that gear it stops and slow down smoothly. Is it normal for the car to be noisy like that?
Old 08-27-2012, 07:24 PM
soypinoy101
soypinoy101's Avatar
The transmission in our car is known to be a bit noisy
Old 08-27-2012, 07:36 PM
hookah
hookah's Avatar
No amount of words can explain... Best method is to go to a Z meeting and get an experienced Z driver to drive your Z and tell you if there is something wrong or not.
Old 08-27-2012, 08:04 PM
Jbakes727
Jbakes727's Avatar
alright well i just went for a little test drive with no music and windows down and every gear shifted smoothly the only thing i noticed was that shifting from 1st to 2nd at 3k was fine but when around 5k+ it felt a bit notchy not really a grinding sound but pretty stiff feeling and when downshifting from 3rd to 2nd it definitely sounded like it was grinding a little could this be a big problem or is this somewhat normal?
Old 08-27-2012, 09:14 PM
angelo350z
angelo350z's Avatar
If you grind at the same spot, even with proper shifting, then your synchros are going out. If you need to stay on the clutch a few seconds longer to keep it from grinding, your synchronizers are going out.
I have this problem with my 300ZX going to 3rd, but it shifts fine if I stay on the clutch a few seconds longer.
Old 08-27-2012, 10:47 PM
chelseafc909
chelseafc909's Avatar
if your synchros go out how much is it to get them fixed ?
Old 08-28-2012, 03:12 AM
winchman
winchman's Avatar
You'd probably be better off to get a new transmission or a low-mileage unit with a guarantee from a wrecked Z. Replacing the synchros is a big and time-consuming job that involves removal and complete disassembly of the transmission.
I'd guess around $700, but that's just a WAG.
Old 07-19-2016, 04:24 AM
Dhawk350Z
Dhawk350Z's Avatar
I'm having this same exact problem with third gear as well, would you recommend buying a whole new transmission or just replacing the syncro? Is it possible that I could go to a junk yard and just get the syncro itself rather than trying to grab the whole transmission? If I do replace the syncro what's the life span lookin like?
Old 07-19-2016, 04:37 AM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
look into the labor to replace it... just buy the cd009 and be done. you will need it trying to get your 250whp car to 400 na
btw, you responded to a post from 4 years ago
Old 07-19-2016, 07:03 AM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
Here I go again: before you try doing anything else, do a simple gearbox lubrication swap. Redline MT85 has the correct viscosity for our gearboxes and has just enough friction engineered in for a synthetic lubricant to allow the syncros to function properly. I use it in both my street and race Zs, and it makes a difference.
07ZEKE
08-23-2021 09:15 PM
burglapfd
12-06-2020 01:04 PM
350z82
10-01-2015 06:25 PM
Quick Reply: How do you tell if the synchros or transmission is bad?
