engine oil cooler temp.
Old 01-09-2013, 07:08 PM
JDMStanced
JDMStanced's Avatar
Default engine oil cooler temp.
hi, i have the high capacity oil pan but planning to change to oil cooler.
Would oil cooler lower the temp. of oil too much for DD? i only take it to drifting once in awhile.
i'm looking at AMS cooler
Old 01-09-2013, 08:10 PM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
Nope, oil and temp will usually stay pretty close. I run at around 150 degree oil temp during normal street driving and have a large cooler mounted with a bigger pan.
Old 01-09-2013, 10:08 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
add the oil cooler…I'm sure you can cool your oil too much but I'm not sure how…
consider this…what cools your block? your coolant and radiator…what cools your internal engine components? your oil…now what's cooling your oil? that 24" of steel tubing - not very much it's not...
Old 01-09-2013, 11:18 PM
tcode
tcode's Avatar
Just use sandwich plate with thermostat and don't worry about under cooling.
Old 01-10-2013, 03:10 AM
e30cabrio
e30cabrio's Avatar
Received 2,578 Likes on 2,037 Posts
I have a large capacity pan, larger aluminum radiator with 12 & 13" spal fans and a decent sized oil cooler. Oil never got over 180 during the Az summer when it was never under 100 and now with 40-60 degree temps my gauge that starts at 140 takes almost 20 minutes to move, then settling at about 150.
Coolant temp sits about 190 and at idle gets no higher than 210.
Old 01-11-2013, 04:20 AM
JDMStanced
JDMStanced's Avatar
150 degree is normal temp for engine oil?
I can't remember 100% but mine reads like 180 degree normally.
Old 01-13-2013, 02:05 AM
JDMStanced
JDMStanced's Avatar
mine does run 180 -190 degrees normally for both oil and water temp..
Old 01-13-2013, 04:22 AM
e30cabrio
e30cabrio's Avatar
I was wrong about my gauge. It starts at 100.
Friday it was in the 40s. I drove 20 minutes on the freeway. It only moved from 100 when I was parked after about 2 minutes.
Old 01-13-2013, 11:57 AM
jerryd87
jerryd87's Avatar
80 degree weather daily my oil temps usually read about 140-160 driving around town about 140 highway, not even high enough to get oil to the cooler. only time they get higher is repeated high boost runs it will hit 180. coolant typically stays about 170-180
get a mocal thermostat and it wont even open till 180
Old 01-13-2013, 01:20 PM
terrasmak's Avatar
Its really cold in Vegas now and my gauge has only been hooked up for a few weeks. I dont have an oil thermostat , it goes to the cooler at all times. A few weeks ago, the max oil temp i hit at the track was 185 , but it was also 40 outside.
If you beat on your car, you want an external cooler. Plain and simple
Old 01-13-2013, 01:27 PM
e30cabrio
e30cabrio's Avatar
I have the mocal & it is cold here but it rarely gets above 140 right now.
Old 01-13-2013, 01:30 PM
taywan
taywan's Avatar
Dang e30- nice guage setup and I like it on the head unit also!! I've been procrastinating on an oil temp guage for the longest.
Old 01-13-2013, 01:38 PM
e30cabrio
e30cabrio's Avatar
The HU is a Kenwood DNX9980HD running Garmin NAV which accepts Bluetooth OBDII data. It can show pretty much anything OBDII feeds.
lapham3
10-07-2022 03:15 PM
07-10-2022 07:44 AM
apex locator
07-23-2021 02:27 AM
SharX59
09-27-2015 09:23 AM
Quick Reply: engine oil cooler temp.
