'Merica! Go big or go home = installing LS engine into drift car
#101
So this happened when we put it on the dyno. The guys just laughed, thought it was really cool.
The GTX4088R with twinscroll config and the S-Empire equal length tubing, with E85 and very safe timing actually produced way more power than we had anticipated. That's a pretty happy surprise. We actually had to backpedal and settle down at 8 psi of boost with literally not even starting to push the timing bc anything else seemed like it would be not necessary anyway at this point and that gives us less risk on the stock internals LS2 block than to take too much hp from it right now. At 8 psi and super soft timing still a serious and 685 rwhp (or 830hp crank if you calculate the drivetrain losses). Can't wait until we have some forged internals and push it up to 12-14-16 psi and mix in a bit of timing as well...
#104
on
Mr. White,
Great build!! Just wanted to say Thanks! For what you ask, post#34 picture 2 - the motor mounts! Todd sent me them marked correctly but the "Legs" that goes to the frame were reversed sides. Your pic saved the day.
Again Great Build!! An inspiration,
Chris
Chris
etkms
06-19-2022 06:30 PM
ILoveDrifting
09-07-2015 03:15 PM
